查看: 350379|回复: 1305
[原创] 启动时提示no write access to或"没有写入权限"的原因和解决方法
发表于 2007-12-29 21:50 | 显示全部楼层 |阅读模式
no write access to X:\...
Please choose another startup directory for trail creation
没有写入权限 X:\...
请为轨迹创建选则另一个启动目录.
对话框如下:
一、引起这个问题的原因
   这是因为你的磁盘采用了 NTFS 分区格式,并且设置了安全性造成的,NTFS 分区内的目录可以设置不同用户对此目录具有不用的权限,比如只读,完全控制,拒绝访问等等。当发生前面所说的错误时,如果你打开错误提示中的那个目录,你可能会发现无发打开,或者能打开但是无法在此文件内创建文件或文件夹。
二、两种解决方法
1、最简单的是更改启动文件夹,方法如下:右击你的 proe 启动快截方式,点“属性”更改下图中的“起始位置”,比如在 D 盘创建一个目录 work ,然后更改为 d:\work ,并确保在更改后的文件夹中可以创建文件夹或目录,更改前可以测试一下。
游客,如果您要查看本帖隐藏内容请回复
[ 本帖最后由 野火 于 2007-12-29 22:26 编辑 ]
本帖被以下淘专辑推荐:
发表于 2008-1-2 09:27 | 显示全部楼层
跟NTFS 分区的权限有关系么?
发表于 2008-1-2 10:13 | 显示全部楼层
看看第二种方法
发表于 2008-1-2 10:34 | 显示全部楼层
先谢谢版主!!!
1、按您第一种方法结果出现以下提示:还是不能成功启动
License request failed for feature PROE_DDiTy: -9:
Invalid host.
Displaying status for license file: D:\PLT\ptc_licfile.dat
License Server: none
                       License    In Use   Free   Version    Expire Date        SCN
                    PROE_DDiTy       Uncounted      27.0         None       07071982 Locked to: <HOSTID>
              MECBASICUI_12345       Uncounted      27.0         None       07071982 Locked to: <HOSTID>
             MECBASICENG_12345       Uncounted      27.0         None       07071982 Locked to: <HOSTID>
              MECSTRUCUI_12345       Uncounted      27.0         None       07071982 Locked to: <HOSTID>
             MECSTRUCENG_12345       Uncounted      27.0         None       07071982 Locked to: <HOSTID>
                MECMOTUI_12345       Uncounted      27.0         None       07071982 Locked to: <HOSTID>
               MECMOTENG_12345       Uncounted      27.0         None       07071982 Locked to: <HOSTID>
              MECTHERMUI_12345       Uncounted      27.0         None       07071982 Locked to: <HOSTID>
             MECTHERMENG_12345       Uncounted      27.0         None       07071982 Locked to: <HOSTID>
             MECINTERFCE_12345       Uncounted      27.0         None       07071982 Locked to: <HOSTID>
              MECTIREMOD_12345       Uncounted      27.0         None       07071982 Locked to: <HOSTID>
                   MECUG_12345       Uncounted      27.0         None       07071982 Locked to: <HOSTID>
                MECEQRUN_12345       Uncounted      27.0         None       07071982 Locked to: <HOSTID>
                 2DGS-OA_12345       Uncounted      27.0         None       07071982 Locked to: <HOSTID>
                 VERICUT_12345       Uncounted      27.0         None       07071982 Locked to: <HOSTID>
              WEBPUBLISH_12345       Uncounted      27.0         None       07071982 Locked to: <HOSTID>
                 FLYTHRU_12345       Uncounted      27.0         None       07071982 Locked to: <HOSTID>
               FLYPLUGIN_12345       Uncounted      27.0         None       07071982 Locked to: <HOSTID>
               FLYVIEWER_12345       Uncounted      27.0         None       07071982 Locked to: <HOSTID>
                 CONCEPT_12345       Uncounted       5.0         None       07071982 Locked to: <HOSTID>
              PROPACKENG_12345       Uncounted      27.0         None       07071982 Locked to: <HOSTID>
               PROPACKUI_12345       Uncounted      27.0         None       07071982 Locked to: <HOSTID>
                    DS_MANAGER       Uncounted      27.0         None       07071982 Locked to: <HOSTID>
                DS_MANAGER-REP       Uncounted      27.0         None       07071982 Locked to: <HOSTID>
                    DS_SERVICE       Uncounted      27.0         None       07071982 Locked to: <HOSTID>
               PROETRAIN_12345       Uncounted      27.0         None       07071982 Locked to: <HOSTID>
         MOCKUPCONVERTER_12345       Uncounted      27.0         None       07071982 Locked to: <HOSTID>
                  MOCKUP_12345       Uncounted      27.0         None       07071982 Locked to: <HOSTID>
               MODELVIEW_12345       Uncounted      27.0         None       07071982 Locked to: <HOSTID>
                   PVIEW_12345       Uncounted      27.0         None       07071982 Locked to: <HOSTID>
              RSDESIGNER_12345       Uncounted      27.0         None       07071982 Locked to: <HOSTID>
                 TMSINDA_12345       Uncounted      27.0         None       07071982 Locked to: <HOSTID>
                     InterComm       Uncounted      27.0         None       07071982 Locked to: <HOSTID>
                    EDAconduit       Uncounted      27.0         None       07071982 Locked to: <HOSTID>
                  EDAconnector       Uncounted      27.0         None       07071982 Locked to: <HOSTID>
Option Chinese_Translation not ordered, please contact your sales representative.
LANG being reset to USASCII
2、按第二种方法还是出现那个对话框,问题没解决
yuanyuany 该用户已被删除
发表于 2008-1-2 16:44 | 显示全部楼层
 楼主| 发表于 2008-1-2 22:05 | 显示全部楼层
4 楼 xnjhon 朋友注意, 你安装的还有问题,请继续看下面帖子:
运行常见错误 License request failed for feature PROE_DDiTy: -8 :-9  解决方法
发表于 2008-1-3 20:21 | 显示全部楼层
我也出现这个问题,回复看第二种方法
发表于 2008-1-5 10:57 | 显示全部楼层
我就是碰到这样的毛病,结果安装了好几遍,光去买光碟的地方更换蝶就5次,都郁闷的要跳楼了,先谢谢,回复后可以学习怎么解决
发表于 2008-1-6 14:31 | 显示全部楼层
同样问题,进来学习一下
发表于 2008-1-6 20:38 | 显示全部楼层
跟NTFS 分区的权限有关系么?
GMT+8, 2025-4-20 06:56 , Processed in 0.157676 second(s), 37 queries .
