File C:\Program Files\PTC\Creo 3.0\F000\Common Files\mech\x86e_win64\bin\msengine.exe NOT patched - check if you already patched it?
File C:\Program Files\PTC\Creo 3.0\F000\Common Files\mech\x86e_win64\bin\showlic.exe NOT patched - check if you already patched it?
File C:\Program Files\PTC\Creo 3.0\F000\Common Files\mech\x86e_win64\ptc\ptcxfce.exe NOT patched - check if you already patched it?
File C:\Program Files\PTC\Creo 3.0\F000\Common Files\x86e_win64\obj\cpu_id.exe NOT patched - check if you already patched it?
File C:\Program Files\PTC\Creo 3.0\F000\Common Files\x86e_win64\obj\dsq.exe NOT patched - check if you already patched it?
File C:\Program Files\PTC\Creo 3.0\F000\Common Files\x86e_win64\obj\plpf_status.exe NOT patched - check if you already patched it?
File C:\Program Files\PTC\Creo 3.0\F000\Common Files\x86e_win64\obj\protk_unlock.exe NOT patched - check if you already patched it?
File C:\Program Files\PTC\Creo 3.0\F000\Common Files\x86e_win64\obj\xtop.exe NOT patched - check if you already patched it?
有没有高手告诉我在什么回事,怎么解决?
