查看: 51560|回复: 148
[下载] Pro/Engineer Wildfire 4.0 M020/M030 补丁包 by ZWT
发表于 2008-7-19 15:52 | 显示全部楼层 |阅读模式
注意:
1、如果你只是学习 PROE 看红色的部分就可以了
2、如果你还需要 mechanic 那还要看蓝色的部分
其他的不用看。——野火
1> open license.dat then displace all string"00-00-00-00-00-00" with your PTC_HOST_ID(Your netcard physical address) then save.
2> Install your pro/E &Pro/M wildfire4.0 M020 with above modified lic file.Node Locked lic method. No lic server installaion needed.
2.Run patchs!
Put proe-patch.exe under directory :
<Installed location>\proeWildfire 4.0\i486_nt\obj       then apply it.
Put prom-patch1.exe under directory :
<Installed location>\proeWildfire 4.0\mech\i486_nt\bin      then apply it.
Put prom-patch2.exe under directory :
<Installed location>\proeWildfire 4.0\mech\i486_nt\ptc      then apply it.
3.If you want install PTC Distributed Services,access PTC.Setup: other product->PTC Distributed Services, use the modified license.dat at step one with node locked lic method. then
Put prods-patch.exe under directory :
<Installed location>\ptc_distributed_services\     then apply it.
P.S. Regarding embedded Vericut:
Actually, CGtech no longer supports its VERICUT as an embedded software for pro/e and no longer uses PTC lic.FYI, See the CGtech official website said:   http://www.cgtech.com/ptc_update/index.htm  hence don't offer patch for it.
That's all.Enjoy it!
Team ZWT 2008
Crack-4.0(M030).rar
92.14 KB, 下载次数: 12441
热心助人勋章宣传大使勋章优秀会员勋章
发表于 2008-7-19 15:57 | 显示全部楼层
还没用上,不过先学习一下了! 感谢版主提供了
给我一个支点,我可以撑起地球
发表于 2008-7-19 16:09 | 显示全部楼层
谢谢版主~~
版主就是先人一步~
发表于 2008-7-25 21:53 | 显示全部楼层
谢谢了
终于找到破解文件了
发表于 2008-8-1 21:41 | 显示全部楼层
Pro/Engineer Wildfire 4.0 M030 补丁包的帮助是英文,本人外文不好,在同事的帮忙下,还是装上了,谢谢了
发表于 2008-8-2 12:51 | 显示全部楼层
太感谢了
发表于 2008-8-4 10:15 | 显示全部楼层
下了还没装,感谢
发表于 2008-8-4 21:06 | 显示全部楼层
多谢楼主分享!
下来试试看
发表于 2008-8-6 15:57 | 显示全部楼层
谢谢了!!!
发表于 2008-8-6 16:40 | 显示全部楼层
總麼這麼快就有出來的啦,呵呵,咸謝提供
GMT+8, 2025-4-16 11:03 , Processed in 0.152048 second(s), 32 queries .
