查看: 9390|回复: 7
[求助] proe材料库
发表于 2012-3-9 09:47 | 显示全部楼层 |阅读模式
因做力学分析,需要一个材料库文件,主要是钢铁方面的如:Q235,Q345,Q390,Q420,Q460,A572Gr65,603等,系统自带的材料库,弄不懂,谢谢
发表于 2012-3-9 10:30 | 显示全部楼层
为什么不自己新建个,还好用
 楼主| 发表于 2012-3-9 11:20 | 显示全部楼层
不太会弄,而且太麻烦,如果你有的话,给我一个不是很好吗,最好像SW的那种,是中文的,才看得懂。
发表于 2012-3-9 11:34 | 显示全部楼层
哈哈,怎么都嫌麻烦呢,嘻嘻
发表于 2013-4-16 14:55 | 显示全部楼层
别嫌麻烦,自己做的才是好的
下面是45的材料 把下面复制粘贴到记事本 保存为“mtl”格式 就可以了 其他材料你可以查到一些参数 直接再修改就可以了
ND_RelParSet_K01 = {
Name = 45
PARAMETERS =
  Name = PTC_MATERIAL_DESCRIPTION
  Type = String
  Default = '优质碳素结构用钢,具有良好的综合机械性能,广泛应用于各种重要
的结构零件如连杆、螺栓、齿轮及轴类,但表面硬度较低,不耐磨。'
  Access = Full
  Name = TEMPERATURE
  Type = Real
  Default = 0.000000e+00 C
  Access = Full
  Name = PTC_INITIAL_BEND_Y_FACTOR
  Type = Real
  Default = 5.000000e-01
  Access = Full
  Name = PTC_BEND_TABLE
  Type = String
  Default = ''
  Access = Full
  Name = PTC_MATERIAL_TYPE
  Type = Integer
  Default = 9
  Access = Locked
  Name = PTC_FAILURE_CRITERION_TYPE
  Type = String
  Default = 'NONE'
  Access = Locked
  Name = PTC_FATIGUE_TYPE
  Type = String
  Default = 'NONE'
  Access = Locked
  Name = PTC_MATERIAL_SUB_TYPE
  Type = String
  Default = 'LINEAR'
  Access = Locked
  Name = PTC_YOUNG_MODULUS
  Type = Real
  Default = 2.060000e+02 GPa
  Access = Full
  Name = PTC_POISSON_RATIO
  Type = Real
  Default = 3.000000e-01
  Access = Full
  Name = PTC_MASS_DENSITY
  Type = Real
  Default = 7.850000e+00 g/cm^3
  Access = Full
  Name = PTC_THERMAL_EXPANSION_COEF
  Type = Real
  Default = 1.060000e-05 /C
  Access = Full
  Name = PTC_THERMAL_CONDUCTIVITY
  Type = Real
  Default = 5.000000e+07 mm g / (sec^3 C)
  Access = Full
  Name = PTC_SPECIFIC_HEAT
  Type = Real
  Default = 3.000000e-01 mm^2/(sec^2 C)
  Access = Full
  Name = PTC_CONDITION
  Type = String
  Default = '45'
  Access = Full
  Name = PTC_XHATCH_FILE
  Type = String
  Default = '45'
  Access = Full
发表于 2013-10-18 09:47 | 显示全部楼层
楼上说的不错,不如自己去整理,这样记得更深刻,做设计的必须对材料了解。
If you know me,leave a message.
发表于 2018-1-9 14:11 | 显示全部楼层
学习了
发表于 2018-1-9 14:34 | 显示全部楼层
感觉好厉害,但是没弄明白这些公式的意思
GMT+8, 2025-2-3 05:47 , Processed in 0.148466 second(s), 21 queries .
