查看: 2216|回复: 2
[求助] PROE4.0启动问题请帮解决,谢
发表于 2011-3-24 13:52 | 显示全部楼层 |阅读模式
Pro/ENGINEER is running with Unicode string encoding.
get_main_dialog:  no current active dialog (ORDER_DEBUG)
DUMMY - pro_set_input_devices_allowed
DUMMY - putxyres
pglSetStatus: Pgl Session Initialize
DUMMY - putxyres
uit_get_visual_style_low:  Style is Luna (NormalColor) (INFO MESSAGE)
ProCmdSelBufferAttrSet():  Selection Buffer Attribute loaded 40 commands (INFO MESSAGE)
cadds5_link_app_path_name():  NuTCRACKER is not installed (INFO MESSAGE)
check_exec_file_accessible_():  d:\Program Files\proeWildfire 4.0\\i486_nt\obj\SolidWorksConvert.exe not accessible (INFO MESSAGE)
PFSTMakeTypeString:  no zip found (INFO MESSAGE)
pro_locate_colormap ()
located color definition d:\Program Files\proeWildfire 4.0\graphic-library\appearances\appearance.dmt
located color definition d:\Program Files\proeWildfire 4.0\graphic-library\appearances\global.dmt
run mode = 2
check_and_call_init_cb:  setting user agent = Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 5.1; Trident/4.0; .NET CLR 2.0.50727; .NET CLR 3.0.4506.2152; .NET CLR 3.5.30729; Wildfire NoTrail; ProE-Datecode:2902007450), result = 0 (INFO MESSAGE)
set_ie7_zoom:  cmd->Exec for OLECMDID_OPTICAL_ZOOM returns:1 <1> (INFO MESSAGE)
browser_url_cb_:  http://aboutblank/ (INFO MESSAGE)
Exception - code was -1073741571.
118
发表于 2011-3-24 14:46 | 显示全部楼层
没破解完全?
发表于 2011-3-24 21:54 | 显示全部楼层
没错误对话框吗
GMT+8, 2024-11-19 08:22 , Processed in 0.147805 second(s), 28 queries .
