查看: 3623|回复: 7
[求助] 野火4.0C000最低配置是多少?
发表于 2008-5-15 13:49 | 显示全部楼层 |阅读模式
野火4.0C000最低配置是多少?
大家说说看,让我心里有个底,谢谢
 楼主| 发表于 2008-5-15 13:51 | 显示全部楼层
没人知道吗?
优秀斑竹勋章原创先锋勋章热心助人勋章斑竹勋章希望之星勋章
发表于 2008-5-15 13:54 | 显示全部楼层
配置要求不高啊,一般电脑都能跑
 楼主| 发表于 2008-5-15 13:56 | 显示全部楼层
我电脑内存才256M,开的时候好像很慢呢
发表于 2008-5-15 13:58 | 显示全部楼层
现在256内存的电脑不多了吧,再说内存也便宜,加一根咯
静坐常思己过,闲谈莫议人非
发表于 2008-5-15 14:42 | 显示全部楼层
3楼的,请不要烧香好吗,我害怕
我现在用的电脑是845的板子,塞扬2.4的cpu,装了好几次都没装上,不知道是不是电脑配置低
发表于 2008-5-15 15:38 | 显示全部楼层
都可以,但配置不好使用时候较慢而已
发表于 2008-5-15 21:08 | 显示全部楼层
System Requirements
Windows XP, Vista
UNIX
Minimum
Recommended
Minimum
Recommended
Main Memory
256 MB
1024 MB or higher
256 MB
1024 MB or higher
Available Disk Space
Pro/ENGINEER
2.0 GB
2.5 GB or higher a
2.5 GB
3.0 GB or higher
Pro/ENGINEER with Pro/ENGINEER Mechanica Wildfire 4.0
2.0 GB
3.0 GB or higher a
3.0 GB or higher
3.5 GB or higher
Swap Space
500 MB
2048 MB or higher
500 MB
2048 MB or higher
CPU speed
500 MHz
2.4 GHz or higher
See above table for individual vendor processor support
Internal Browser Support
Microsoft Internet Explorer 7.0
Microsoft Internet Explorer 6.0 (SP1 or later)
Browser (Mozilla 1.7.8) is embedded in Pro/Engineer on UNIX platform
Monitor
1024 x 768 (or higher) resolution support with 24-bit or greater color
Network
Microsoft TCP/IP Ethernet Network Adapter
Mouse
Microsoft-approved 3-button mouse
3-button mouse
File systems
NTFS
All vendor-supported file systems.
Misc.
CD-ROM or DVD drive
CD ROM or DVD drive
NOTES
a
For Windows XP only. For 32-bit operating systems, the Windows limit is 2.0GB. For Windows XP you must enable the /3GB switch in order to utilize RAM greater than 2.0GB.
GMT+8, 2024-11-26 06:54 , Processed in 0.150890 second(s), 22 queries .
