有 资料可以自己建立材料数据文件,但是单位之间的转换是个问题呀,常用的
这是5.0中的材料文件信息?:
ND_RelParSet_K01 = {
Name = CU
PARAMETERS =
Name = PTC_MATERIAL_TYPE
Type = Integer
Default = 9
Access = Full
Name = PTC_FAILURE_CRITERION_TYPE
Type = String
Default = 'NONE'
Access = Full
Name = PTC_FATIGUE_TYPE
Type = String
Default = 'NONE'
Access = Full
Name = PTC_YOUNG_MODULUS
Type = Real
Default = 1.900000e+07 psi
Access = Full
Name = PTC_POISSON_RATIO
Type = Real
Default = 3.500000e-01
Access = Full
Name = PTC_THERMAL_EXPANSION_COEF
Type = Real
Default = 9.300000e-06 / F
Access = Full
Name = PTC_SPECIFIC_HEAT
Type = Real
Default = 3.248000e+05 in^2 / (sec^2 F)
Access = Full
Name = PTC_THERMAL_CONDUCTIVITY
Type = Real
Default = 1.514000e+01 lbf / (sec F)
Access = Full
Name = PTC_MASS_DENSITY
Type = Real
Default = 7.686000e-04 lbf sec^2/in^4
Access = Full
Name = PTC_BEND_TABLE
Type = Real
Default = 0.000000e+00
Access = Full
Name = PTC_XHATCH_FILE
Type = String
Default = 'CU'
Access = Full
Name = TEMPERATURE
Type = Real
Default = 0.000000e+00 F
Access = Full
这些参数哪些可以不填
哪些是必要的? |
