查看: 32005|回复: 63
[分享] keyshot 2.0.46
绘图员
发表于 2010-7-28 12:17 | 显示全部楼层 |阅读模式
之前一直在忙,没时间上网,今天特意在论坛里找keyshot 2.0.46,发现没人发布,故自己动手来了
We have been busy! This new update brings significant improvements to the appearance of frosted glass and environment reflections of shiny, rough materials. In addition, we made a number of improvements (aka fixed a number of outstanding bugs). And, as always, we made it even faster. This update is free to all KeyShot 2 customers.
See full list of features and improvements below. Download links can be found at the end of this post.
Note to clients of floating licenses: Please contact license@luxion.com to obtain the latest download links.
New Features
Added "sharp glossy reflections" to the environment option:
This will no longer blur the environment when working with small roughness values on reflective materials.
Added "glossy reflections" to metallic paint:
The roughness value will now have an effect when viewed at grazing angles.
Improved appearance of glossy transmission at grazing angles:
Transparent objects with roughness will look correct when viewed at grazing angles.
Added "Roughness Transmission" to the Advanced Material (advanced mode only):
This will help in creating "milky plastic materials".
Copy and paste materials directly inside a material group inside the Material Library.
Edit materials directly inside the Material Library without the need to apply to an object first
Rename materials directly inside the Material Library
Removed "Keep aspect ratio" from render dialog and respect the realtime aspect ratio
The DPI setting is now remembered in between sessions
Installers now support unattended uninstall.
Added progress bar when saving a scene.
Made the activation dialog input more user friendly:
This will simplify the process of re-activating the license on a different machine.
Display will not turn off during lengthy renderings without any user interaction
Improvements
Significantly improved ground shadow quality when using offline rendering even at default settings
Fixed potential crash when saving files after deleting or hiding parts
Fixed potential data explosion when using plugins
Fixed potential crash upon exiting KeyShot
Fixed potential crash when applying or editing labels
Improvements to IGES ad STEP translators
Rotate imported files by 90 degrees upon import
Improved support for foreign characters in file names
Limit "Roughness" slider to 0.5
Use proper render output folder
Keep rendering window open for 60 seconds after rendering is done
Options dialog and library are dynamically placed when the work area or number of screens change
"Realtime shadow quality" setting is saved in bip files
Show serial code in "About" window
Added warning when program is less than 10 days from expiration
[ 本帖最后由 凡笔 于 2010-7-28 15:02 编辑 ]
参与人数 1威望 +2 金钱 +5 收起 理由
野火 + 2 + 5 感谢分享
绘图员
 楼主| 发表于 2010-7-28 12:17 | 显示全部楼层
破解
方法与2.0.38的一样
  ...         ....................... .......... ......                            NFO : Scorn      ...
  ...      ... . .. .   .,~+?III777$$$$$ZZ7~, .... .. .  ..                                         ...
  ...     .... ....~=++?Z8NMMMMMMMMMMMMMMMMND88DOOI.   .. ...      ......           ......   ...    ...
  ...     .... .+~=NMMMMNMMMMMNMNNNMMMMNMMMNMMMMMNNODM$..................           ......  ....    ...
  ...    .  +~DMMMNMMNMMMMM:.. .    ...   .,:+MMMMMNNNMMN8ND7,.  .....  ...... ............ ..      ...
  ...   . .MNMNMNMNMM$~.. ..... ...    ........  ..+OMMMMNMMDONND?:..  ..  ... ...   .==+?MM.. .    ...
  ...    . .~NMMMMZ  ...,...  .  ......  ... .  ........=MMMNMMMMD8OO88Z7?+++++I??+?IZDMMM .....    ...
  ...       ... ... ...  ......  .. . . ..    .... .. .....:ZMMDMNNMMMMMMMMMMMMMMMMMMNMM8 ...       ...
  ...     ..........  .. ..~+??I7$$ZZZ$ZZO8O7=  .....   ...... ,ZMMNNMMMMMMMMMMMMMMMMM?,. ...       ...
  ...      ...  . .. . .==+NMMMMMMMMNMMMMMMMNDODND7.... . ..  .., .+8MMMMMNNNMMMMMMM.. ,.....  .    ...
  ...         . . .. ~+=MMMMMMMMMMMMMMMMNNMMMNMMMMN8DM8=...,. . . ..... .,~I7I=:, . .  .  ..  ..    ...
  ...         .....,I7MMMDNMMMI.NMMNMMMMNMNMMMMNMMMMMMN88MN..... . ..... ..... ..... .  . . .. ..   ...
  ...         . .==MMMMMMM~  ,.OM.=MNMMNNM~.  . DMMMNNMNMMMMMOMMO...  . .     .. .... ........ ..   ...
  ...         , +?MMMMMM. ..  .8M +MMMMMMM. ..., . .MMMNNMNMMMN8DD8Z~.   .. ...    ..:=?:M.....   ...
  ...         .IMMMMNM. .... ...MM=MMMMNM8....... ..... ?MNMMNMMNMMMMM8OZ$$$$$$$7III?IZ8NMMMD. ,.   ...
  ...    ..,:I=8MNMM8  , .   ...NMMMNMNMM..... . ....,+:?MMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMM+...   ...
  ...      . ?MMMNM.  .  .........MMMMMM. .  .  .,~==7MMMMMNMMNNMMMMMMMMMMMMMMMMMMMMMMMMMMMMMN...   ...
  ...   . ..NMMNMMM?,....  ......   ... . . ,:+==$MMMMMNMMNMMM7, ..     ..~8MMMMMMMMMMMMMMMMMD...   ...
  ...    . .MNNNMMNN8ZO8OZZ$I?+====+??I?+??7OMMMMNMNMMMMMMZ..,....... ..   ....  .~$MMMMMMMMM,...   ...
  ...      : MMMMMNMMMMMMMMMMNNNNMMMMMMMMMMMMMMNMNMNMM$............      ......  ...   .,~,, ...    ...
  ...    . . ... ..  +$8MMMMMMMMMMMMNMMMMMMMMMMM: . ....... . ...        .. .. ......   ...  ..     ...
  ...   . . ..  .... ... ...MMMMNM:NMMMMMMMMM+ ,.., .  .  .   . . .      ....... ... ..  . ..       ...
  ...               . .... ?,DMNMM?..?MMMMMMMDMI..  ... .  ..       .. ..  .. ~=~.. .....           ...
  ...               . ... +MMNMMMM+,.. ?MNMMNMMNM$.,..  . .. .  .. ...... ,~=ZNDDZMM.  ..           ...
  ...               .....   8MMMNMI .....?MMNMMMMNN8,.,. ..             .Z=MMMMNNNMMM?....          ...
  ...               ...... . MMMMM7..  .   ?MMMMNMNNDM7. . .  ... ..  .. MMMMMMMMNMMNM.. .          ...
  ...                     . .MMMMM$. .   ..,. MMNMMNMNDNM? . .. .. .. ...MNNMNMMMMMMNM  .           ...
  ...                      . ZMMMM$  .    ......8MMMMNMNM8DMO .. .... ...7MNNNMMMMMMMN ...          ...
  ...                     ...=MMMM$.....   . ....  ..ZMMMMMMMMD88NN~. .. .. .+MMMMNNN~  ..          ...
  ...                      .  MMMM$.. .    .   .  ..... ,MMMMNMNMMMD8O$$7IINMMDMMMMN......          ...
  ...                     .. .MMMM$  .            .......  ..?MMMMMMMMMNNMMMMMMMM:. ......          ...
  ...                      ...NMDMZ .            ...  ...  .... .  ,~=?I7??~:.   ..   ...           ...
  ...                     .....+Z=...            .. .  ........... .. .........        ...          ...
                                               .: Amon^Ra :.
                                        C4D Community is NOT Dead
                                            Amon^Ra 4D presents
                                        LUXION KeyShot 2.0.46 32&64 bit
                                            General Information
              Type.................: Rendering
              Platform.............: win 32&64bit
              Serial #.............: n/a
              More Info............: http://www.keyshot.com/keyshot/
                                            Post Information
              Posted by............: Amon^Ra
              Posted on............: 22.07.10
                                            Release Notes
              KeyShot 2 is an all new application built on Luxion's production proven realtime
              raytracing and global illumination technology. We have taken the world's fastest
              rendering engine, and made it even faster. Available for both PC and Mac,
              KeyShot 2 still works on your old laptop without the requirements of an expensive
              graphics card.
              But this is just the beginning. Other key highlights of the new release include:
                  * Significantly faster realtime interaction utilizing a new rapid high-quality
                    shadowing algorithm that takes full advantage of multi-core CPUs, delivering
                    smooth, noise-free results instantly
                  * The entire workflow has been optimized by introducing a brand new user interface
                  * Full visual drag and drop capabilities of materials, textures and envrionments
                  * A scene tree that makes interaction with mulitple parts and models a snap
                  * A new innovative labeling system allows any number of labels to be added to any
                    material including glass
                  * An all new import pipeline supports many more native file formats on both PC and
                    Mac, including KeyShot's own bip files
                                            Install Notes
                 1. Download the application from Keyshot web page.
                 2. Install the Keyshot conect to the internet and start the aplication, from splash
                    screen select try now and get your self an demo license for your hardware ID
                    -"THIS IS WERY IMPORTANT MUST BE CONECTED TO INTERNET"
                 ( install update 46 if u have 38 version)
                 ( if u alredy have a demo license follow step 3)
                 3. Poot the Patch in installed directory & apply the patch!
                 (W7 and Vista users run pach as Administrator)
                 ENYOY!!!!!
[ 本帖最后由 凡笔 于 2010-7-28 15:01 编辑 ]
KEYSHOT 2 PACH.part1.rar
1000 KB, 下载次数: 697
KEYSHOT 2 PACH.part2.rar
1000 KB, 下载次数: 729
KEYSHOT 2 PACH.part3.rar
73.35 KB, 下载次数: 442
绘图员
 楼主| 发表于 2010-7-28 12:18 | 显示全部楼层
绘图员
还是再说一下怎么破解
0、如果你之前已经生成lic了,请跳到第5步
1、安装后运行Keyshot,选Try
2、填入相关信息,注意e-mail要正确,选中间Create request file,生成keyshot2-request.txt,保存到任意位置
3、把keyshot2-request.txt作为附件发到邮箱"license@luxion.com"
4、第二天"license@luxion.com"就会发含有keyshot2.lic 附件的邮件到你的邮箱,把keyshot2.lic 保存到keyshot2的安装目录,一般为"X:\Program Files\KeyShot2\doc"
5、把破解补丁复制到安装目录并运行之
6、完成
备:以上破解方法是以Windows xp sp3为基础,未在其他系统上实验过,如果在其他系统上破解有问题,请告诉我
[ 本帖最后由 凡笔 于 2010-7-29 14:52 编辑 ]
responsibility
宣传大使勋章希望之星勋章
发表于 2010-7-28 12:44 | 显示全部楼层
好的
等你啊
嘿,又有新的啦
发表于 2010-7-28 14:12 | 显示全部楼层
支持楼主,希望楼主能发布一下破解补丁,我下不了 http://www.mediafire.com/?g15x4eiv5el28mi
发表于 2010-7-28 14:31 | 显示全部楼层
我找了好久也米有找到针对046的破解,不过用038的凑合能用
发表于 2010-7-28 14:51 | 显示全部楼层
不是吧,楼上的,
caoxiaofang 该用户已被删除
发表于 2010-7-28 18:19 | 显示全部楼层
发表于 2010-7-29 11:03 | 显示全部楼层
凡笔老大,上次5.0的装了keyshot后就运行不了了,再把它卸载就可以用了,害我马上换回4.0,这次装2.0我不会发生这样的现象吧?
GMT+8, 2025-4-20 03:46 , Processed in 0.175106 second(s), 33 queries .
