我在
http://www.proewildfire.cn/forum ... p;extra=&page=1
帖子里面,用迅雷下载了管理员给的“电骡 32 位版本下载”,下载后解压开,里面的补丁包叫做《ShooTERS》,里面的补丁工具和安装教程帖子里面说到的不一样,而且文件夹里面的安装教程,有错别字,而且很难理解,提到的一些文件说需要修改,可是在安装文件夹里面根本找不到。
我把文字复制如下,请资深看一看(红色字体部分为问题点):
------------无奈的分割线----------------------------
.boot up your pc with windows
.start pro/e setup
.open ptc_licfile.dat with your fav txt-editor
.replace every occurance of 00-00-00-00-00-00 with the one shown in the bottom left corner of the Pro/e setup
(its your mac-id, format: xx-xx-xx-xx-xx)
.install pro/e - pro/m - pro/ds, i dont care which one or in which order
.on license-config screen select "nodelocked license" and point to edited ptc_licfile.dat
.blalala install
next for pro/engineer:
(if u didnt install the complete package, u get "missing file" errors, accept or bleed)
.run ptc.pro engineer.wildfire.5.0-patch.exe, point to <installdir>\i486_nt\obj folder
.edit <pro/e installdir>\bin\proev.bat
change "%start_cmd% "%CGTECH_JRE%\bin\javaw" -Xms16m -Xmx64m -Xss4m -classpath "%CGTECH_CLASSES%;%CGTECH_CLASSES%\CGTech.jar" Vericut %argstr%" in
"%start_cmd% "%CGTECH_JRE%\bin\javaw" -Xms16m -Xmx64m -Xss4m -classpath "%CGTECH_CLASSES%;%CGTECH_CLASSES%\CGTech.jar" Vericut %argstr% PTC_KEY=0"
(add PTC_KEY=0)
pro/mechanica:
.run ptc.pro mechanica.wildfire.5.0-patch.exe
.point to <pro/m installdir>\i486_nt\bin
<pro/m installdir>\i486_nt\obj
<pro/m installdir>\i486_nt\ptc
(in this order, after every "missing file" error)
pro/distributed services:
.run ptc.distributed.services.5.0-patch.exe and point to <pro/ds installdir>\i486_nt\obj
.用Windows引导你的个人电脑
.启动pro/e安装程序
.用文本编辑器打开ptc_licfile.dat
.用Pro/e安装界面左下角显示的网卡ID替换其中所有的00-00-00-00-00-00
(你的mac-id, 格式为: xx-xx-xx-xx-xx)
.安装 pro/e - pro/m - pro/ds, i dont care which one or in which order
.在许可配置窗口选择"nodelocked license" 并指定编辑过的ptc_licfile.dat文件
.开始安装
接下来破解pro/engineer:
.运行ptc.pro engineer.wildfire.5.0-patch.exe,定位到<安装文件夹>下的\i486_nt\obj文件夹
.编辑<pro/e 安装文件夹>下\bin\proev.bat
更改 "%start_cmd% "%CGTECH_JRE%\bin\javaw" -Xms16m -Xmx64m -Xss4m -classpath "%CGTECH_CLASSES%;%CGTECH_CLASSES%\CGTech.jar" Vericut %argstr%" 为
(add PTC_KEY=0)
pro/mechanica:
.运行ptc.pro mechanica.wildfire.5.0-patch.exe
.定位到<pro/m 安装文件夹>下\i486_nt\bin文件夹
<pro/m 安装文件夹>下\i486_nt\obj
<pro/m 安装文件夹>下\i486_nt\ptc
(每当提示 "missing file" 错误时,按上面的顺序进行定位)
pro/distributed 服务:
.运行ptc.distributed.services.5.0-patch.exe并定位至<pro/ds 安装文件夹>下的\i486_nt\obj
-----------------还是无奈的分割线----------------------------
首先蓝色字体就有误,应该是license.dat才对,而不是“ptc_licfile.dat”,这个就害我费了点时间。
第一个红色字体部分的“proev.bat”根本就找不到
第二段红色字体部分,不知道是什么意思。
急救啊……下载就下载了整整两天,我把原来的4.0 M050的卸载掉了,现在没得用了……
或者,有没有可以用的补丁包可以给提供以下?
[ 本帖最后由 yydlm 于 2010-6-26 16:33 编辑 ] |
