KEYSHOT2.0终于出来了,先发下载,静等破解了!!
Windows 32bit
http://keyshot.com/install/keyshot_w32_2.0.30.exe
http://keyshot.us/install/keyshot_w32_2.0.30.exe (US mirror)
Windows64bit
http://keyshot.com/install/keyshot_w64_2.0.30.exe
http://keyshot.us/install/keyshot_w64_2.0.30.exe (US mirror)
Mac OS X
http://keyshot.com/install/KeyShot_64bit_2.0.30.pkg
http://keyshot.us/install/KeyShot_64bit_2.0.30.pkg (US mirror)
Trial version limitations:
The trial version you are about to install is a fully functional version of KeyShot except for the following:
1. Your saved images will be watermarked.
2. You cannot save any of the scenes you set up.
3. You trial is limited to 15 days per release (e.g. 2.0, 2.1etc) per machine
Getting started:
1. After installing KeyShot, the software will start automatically.
2. Please select "Try".
3. Fill in the information, and select "Activate".
4. KeyShot will connect to the server and automatically receive a license. Skip steps 5-7.
5. If a server connection can't be established, save the "license-request.txt" file.
6. Send this file to license@luxion.com.
7. You will receive a license file shortly.
Your first rendering:
1. Follow the 6 steps outlined in the quick start guide found under the "Help" menu.
2. KeyShot supports the following file types:
- Pro/ENGINEER
- SolidWorks (PC only)
- Rhinoceros
- SketchUp
- IGES
- STEP
- Obj
- Collada
- 3DS
- FBX
- BIP (KeyShot file format)
In addition we provide direct plugins for Pro/E, Rhino and SolidWorks. Please goto www.keyshot.com/keyshot/plugins to learn more.
System requirements:
Windows specific requirements:
- Windows 7, Vista and XP (32 and 64 bit)
- AMD or Pentium 4 processor or better
Macintosh specific requirements
- Mac OS X 10.5 or later
- Intel processor
General system requirements for KeyShot:
- Minimum 1GB of RAM
- Minimum 500MB of hard disk space
- 3 button mouse
- Monitor resolution of 1024 x 768 or greater
- No special graphics card required
KeyShot 2
KeyShot 2 is here!
KeyShot 2 is an all new application built on Luxion's production proven realtime raytracing and global illumination technology. We have taken the world's fastest rendering engine, and made it even faster. Available for both PC and Mac, KeyShot 2 still works on your old laptop without the requirements of an expensive graphics card.
But this is just the beginning. Other key highlights of the new release include:
Significantly faster realtime interaction utilizing a new rapid high-quality shadowing algorithm that takes full advantage of
multi-core CPUs, delivering smooth, noise-free results instantly
The entire workflow has been optimized by introducing a brand new user interface
Full visual drag and drop capabilities of materials, textures and envrionments
A scene tree that makes interaction with mulitple parts and models a snap
A new innovative labeling system allows any number of labels to be added to any material including glass
An all new import pipeline supports many more native file formats on both PC and Mac, including KeyShot's own bip files
Read below for more detail.
NOTE: All customers who bought after April 1st will receive KeyShot 2 absolutely free!
All new user experience
KeyShot 2 has been completely redesigned to deliver an unmatched user experience. Even easier to use, the new user interface makes the creation of photographic images from 3D data faster than ever before.
Key features of the new user interface are:
Identical look and feel for both Windows and Mac
Cocoa based interface for Mac OS X
Drag and drop of materials, environments, textures directly into the scene with real time feedback
Interactive material and environment adjustments with real time feedback
Library for all assets (materials, environments, textures, backplates and renderings) with visual representation and search capabilities
Dynamic camera interaction with precise position control
New rendering capabilities
The new rendering features in KeyShot 2 allow users to work faster, and obtain even more accurate results than ever before.
Key capabilities include:
Scene tree for better scene management
Light emitting materials with intensity and color control
Merging of previously saved scenes with current scene
Unlimited label placement on any material
Ground caustics without need for physical plane
Significant performance improvements
KeyShot 2 has been further optimized to run even faster on PC and Mac without the need for special graphic cards.
Performance improvements reach up to 50% compared to KeyShot and HyperShot.
Performance improvements include:
Loading of 3D data
Calculation of detailed and ground shadows
Image resolution in realtime
Offline render times
New importing capabilities
KeyShot 2 features an all new data import pipeline for Pro/ENGINEER on both PC and Mac. Unlike before, the importers don’t require Pro/ENGINEER to be physically installed, and therefore work much faster. When design changes are being made to the Pro/ENGINEER model, the model can be reimported into KeyShot with losing any of the materials assignment previously made. This will also work with any other supported file format. |
