查看: 10561|回复: 6
[求助] 高手指点什么是MAC 地址
发表于 2010-1-7 21:04 | 显示全部楼层 |阅读模式
我下载了ProEWildfire5.0野火版中文绿色版proeWildfire或Pro ENGINEERWildfire
按用记事本打开CRACK 下的license.dat 文件 ,把MAC 地址全部替换成你的网卡MAC地址就行了
license.dat 里面用记事本打开后
#REPLACE ALL 00-1D-7D-18-8D-56 WITH YOURSELF PTC_HOST_ID
INCREMENT PROE_200 ptc_d 30.0 permanent uncounted \
        EC7498757755369A3446 VENDOR_STRING="VSVER=2.0 \
        LO=(0,3,6,7,9,10,14,16,17,19,21,22, \
        23,24,25,26,29,30,31,32,34,35,36,37,40,41,45,47,48,51,52,53, \
        54,55,56,57,59,60,61,62,63,65,66,67,69,71,72,73,74,77,91,92, \
        93,94,97,100,104,106,108,115,116,117,118,119,120,121,122,123,125, \
        126,127,128,131,133,134,135,137,139,140,141,148,155,156,157,158, \
        159,160,161,163,164,167,168,187,188,189,190,191,192,193,194,195, \
        196,197,198,199,200,201,202,203,204,205,206,207,208,209,210,213,214,218,219,220,221,  \
        222,223,224,225,226,227,228,229,230,235,236,237,238,239,240,241,242,243,244,245,246,247, \
        248,249,250,251,253,254,255,256,257,259,260,261,262,263,264,265,266,267,268,269,270,271,  \
        272,273,274,275,276,277,278)" \
        HOSTID=PTC_HOSTID=00-1D-7D-18-8D-56 SUPERSEDE \
        vendor_info="VIVER=2.0 EXTERNAL_NAME=" ISSUER=Ghost/ZWT \
        ISSUED=30-JAN-2008 NOTICE=ZWT SN=88888888 TS_OK SIGN2="0026 \
        E605 D6D0 3FBD 2114 EEB5 7A87 1D8E DDF0 D3C7 4C49 D153 1E77 \
        DF8C 61A1 091E B91F 662C 15EE EBAA B0F3 0A46 7A57 B345 8BAD \
        D2EB 554D 3A4F C587 7F38"
INCREMENT 2DGS-OA_200 ptc_d 30.0 permanent uncounted 875DED9B1C14 \
        VENDOR_STRING="VSVER=2.0 LO=(19,169,170,171, \
        172,173,174,175,176,177,178,179,180,181,182,183,184,185,186)" \
        ISSUED=30-JAN-2008 NOTICE=ZWT SN=88888888 TS_OK SIGN2="10BD \
        D960 7F82 0F8B E475 E2C9 E8BA A577 3BB8 4E64 1F3B B69B B04E \
        E2D8 DC57 10F5 40DB DCB0 9A8C DF60 20DD 37CA BF30 C0A5 78DC \
        4501 4162 5046 39AC DDC8"
INCREMENT ANIMATOR_200 ptc_d 30.0 permanent uncounted ACFB0E5792EC \
        VENDOR_STRING="VSVER=2.0 LO=(19,73,148,160)" \
        ISSUED=30-JAN-2008 NOTICE=ZWT SN=88888888 TS_OK SIGN2="15A4 \
        E1AA E95D 50FF 702C 153E 1C64 3590 AE0B EF87 3E1B 5942 D42B \
        8E12 CACD 0FCB 9A84 5FE2 038D 782F AEAF 2F4A 5454 21C2 ED67 \
        EC3C A3EB 994E 5369 F7E3"
什么是MAC 地址
1270
发表于 2010-1-7 21:11 | 显示全部楼层
就是网卡地址
热心助人勋章宣传大使勋章优秀会员勋章希望之星勋章
发表于 2010-1-8 08:25 | 显示全部楼层
上面00-1D-7D-18-8D-56就是你得网卡地址。
你可以这样查看
开始→运行→cmd→config/all
绘图员
发表于 2010-1-8 09:52 | 显示全部楼层
楼上写错了,是
开始→运行→cmd→ipconfig/all
发表于 2010-1-8 17:57 | 显示全部楼层
形象一点就是上网的身份证。。。
发表于 2010-1-9 13:37 | 显示全部楼层
键盘WIN+R然后输入CMD   然后输入IPCONFIG/ALL本机ID
发表于 2010-1-9 15:01 | 显示全部楼层
在破衣安装界面上会出现MAC地址的啊。
GMT+8, 2024-9-28 23:24 , Processed in 0.162324 second(s), 32 queries .
