楼主: ポ狚尒媿
[分享] 教你如何在PROE4.0上挂EMX
发表于 2008-9-15 21:49 | 显示全部楼层
回复 楼主 的帖子
ddddddddddd
发表于 2008-9-25 22:05 | 显示全部楼层
64位EMX5.0 F000如何安装 QQ354514088
哪位大侠可指教我的64位EMX5.0  F000  怎么挂不上啊?
操作系统64位VISTA, 已安装64位proe 4.0  M040
EMX我下了很多版本,其它的都是32位的,可在32位系统上安装,可现在我用64位系统了,64位EMX5.0  F000  安装了,就不知道怎么设置。。。。crack 文件说明如下,请高手指教:
PTC Expert Moldbase eXtension(EMX) Release 5.0 F000
This version supports the following 9 kinds of languages:
English, French,German, Italian, Japanese,Korean,Spanish,Simplified Chinese and Traditional Chinese.
Installation:
As an extension pack of Pro/E, You should install Pro/ENGINEER WILFRE2.0 or WILDFIRE 3.0 before you install the EMX5.0  F000 extension pack of pro/E and ensure your pro/e license includes the #192 feature< Feature Expert_Moldbase(192)> of pro/e. Of course, prior to rlz lic gen of Pro/e for WILDFIRE2.0 and 3.0 by ZWT includes the feature.
Attention:
   The EMX 5.0 no longer supports lower version of pro/E, the Pro/ENGINEER 2001 and WILFIRE can't run it enven if you have the right lic!
OK, if the above reday, let's go now:
run setup, choose all installation options and the right language which you need and choose an installing location, e.g. c:\ptc\emx5.0 , then Press Next button till finish.
Copy the following file under the installed emx5.0.F000 directory, e.g.:
c:\ptc\emx5.0\text\config.pro
  and paste it into the following installed directory of pro/e:
  e.g. for wildfire 2.0, please paste it into here:
       \proeWildfire 2.0\text
e.g. for wildfire 3.0, please paste it into here:
       \proeWildfire 3.0\text
P.S. for EMX 5.0 F000 command icons:
If you wanna use and show the EMX R5.0 M350 command icons on the pro/e interface,
please copy the following file
  \emx5.0\text\config.win
to ANY ONE of the following directories:
A. Your HOME Directory ( Use DOS command:   SET HOME   to query your HOME directory)
B. The pro/e  "start in" directory (Check your Pro/e startup icon,right click,properties,start in)
C. Your current working directory which you start the pro/e
OK, now run pro/e wildfire2.0 or 3.0, you'll find the Expert Moldbase Extension can work now.
发表于 2008-9-28 14:55 | 显示全部楼层
但我挂的5.0的里面没模架啊,怎么加载
发表于 2008-9-28 14:59 | 显示全部楼层
谢谢LZ!
发表于 2008-9-28 16:24 | 显示全部楼层
我用EMX5.0
M050的也挂的上啊
发表于 2008-9-29 10:45 | 显示全部楼层
proe 3.0 M120 可以挂载嘛??
proe 3.0 M120 可以挂载嘛??  和4.0版本有什么不同的??
发表于 2008-10-18 17:13 | 显示全部楼层
是什么方法
发表于 2008-10-18 23:47 | 显示全部楼层
回复 楼主 的帖子
都不行的,没用啊
发表于 2008-10-20 11:10 | 显示全部楼层
救命啊
无法启动 SmartHolechart。
注册表文件 'D:\Program Files\emx5.0\text\protk.dat' 中的 Pro/TOOLKIT 应用程序 'EMX 5.0' 在日期上先于 Pro/ENGINEER Wildfire v4.0,但并未按使用继承编码进行标记。
发表于 2008-10-23 21:00 | 显示全部楼层
回复 楼主 的帖子
只要是5.0的都行吗?挂上后有不好用的地方吗?谢谢!
GMT+8, 2024-11-17 19:43 , Processed in 0.152202 second(s), 25 queries .
