查看: 40019|回复: 420
[下载] Pro/Engineer Wildfire 4.0 M110 补丁包 by SHooTERS
发表于 2009-10-19 20:57 | 显示全部楼层 |阅读模式
proe 4.0 补丁包 SHooTERS 中英文使用说明 readme.txt 见下帖:
http://www.proewildfire.cn/thread-27677-1-1.html
.boot up your pc with windows
.start pro/e setup
.open ptc_licfile.dat with your fav txt-editor
.replace every occurance of 00-00-00-00-00-00 with the one shown in the bottom left corner of the Pro/e setup
(its your mac-id, format: xx-xx-xx-xx-xx)
.install pro/e - pro/m - pro/ds, i dont care which one or in which order
.on license-config screen select "nodelocked license" and point to edited ptc_licfile.dat
.blalala install
next for pro/engineer:
(if u didnt install the complete package, u get "missing file" errors, accept or bleed)
.run ptc.pro engineer.wildfire.4.0-patch.exe, point to <installdir>\i486_nt\obj folder
.edit <pro/e installdir>\bin\proev.bat
  change "%start_cmd% "%CGTECH_JRE%\bin\javaw" -Xms16m -Xmx64m -Xss4m -classpath "%CGTECH_CLASSES%;%CGTECH_CLASSES%\CGTech.jar" Vericut %argstr%" in
        "%start_cmd% "%CGTECH_JRE%\bin\javaw" -Xms16m -Xmx64m -Xss4m -classpath "%CGTECH_CLASSES%;%CGTECH_CLASSES%\CGTech.jar" Vericut %argstr% PTC_KEY=0"
(add PTC_KEY=0)
pro/mechanica:
.run ptc.pro mechanica.wildfire.4.0-patch.exe
.point to <pro/m installdir>\i486_nt\bin
                                         <pro/m installdir>\i486_nt\obj
                                         <pro/m installdir>\i486_nt\ptc
(in this order, after every "missing file" error)
pro/distributed services:
.run ptc.distributed.services.4.0-patch.exe and point to <pro/ds installdir>\i486_nt\obj
游客,如果您要查看本帖隐藏内容请回复
发表于 2009-10-19 22:13 | 显示全部楼层
回复了。。才能好好了解怎么解决这个问题
发表于 2009-10-19 22:55 | 显示全部楼层
等待下载
发表于 2009-10-19 23:28 | 显示全部楼层
回复 楼主 野火 的帖子
             这个“Pro/Engineer Wildfire 4.0 M110 补丁包 by SHooTERS”正是翘首期待多日而未得的吖!
发表于 2009-10-20 15:54 | 显示全部楼层
感谢。
发表于 2009-10-20 21:21 | 显示全部楼层
非常ganxie,下拉看看
发表于 2009-10-21 08:44 | 显示全部楼层
fdgwretwertwer
twertwrhdfgsdfwertwertw
参与人数 1金钱 -2 收起 理由
yun0336wu -2 违规内容!请您去学习【论坛发贴总则】
发表于 2009-10-21 22:40 | 显示全部楼层
参与人数 1金钱 -3 收起 理由
yun0336wu -3 您复制吾在4#的回帖。违规。去学习【发帖总 ...
发表于 2009-10-22 01:33 | 显示全部楼层
我看看到底好
发表于 2009-10-22 09:29 | 显示全部楼层
这个补丁的作用是什么?谢谢
GMT+8, 2025-4-16 11:22 , Processed in 0.148231 second(s), 33 queries .
