PTC Pro/ENGINEER Wildfire 5.0 Generic Crack for Datecode F000
1> open license.dat then displace all string"00-00-00-00-00-00" with your PTC_HOST_ID(Your netcard physical address) then save.
2> Install your pro/E &Pro/M wildfire5.0 F000 with above modified lic file.Node Locked lic method. No lic server installaion needed.
2.Run patchs!
Put proe-patch.exe under directory :
<Installed location>\proeWildfire 5.0\i486_nt\obj then apply it.
Put prom-patch1.exe under directory :
<Installed location>\proeWildfire 5.0\mech\i486_nt\bin then apply it.
Put prom-patch2.exe under directory :
<Installed location>\proeWildfire 5.0\mech\i486_nt\ptc then apply it.
3.If you want install PTC Distributed Services,access PTC.Setup: other product->PTC Distributed Services, use the modified license.dat at step one with node locked lic method. then
Put prods-patch.exe under directory :
<Installed location>\ptc_distributed_services\ then apply it.
