查看: 86766|回复: 52
[原创] proe 4.0 补丁包 SHooTERS 中英文使用说明 readme.txt 翻译为中文
发表于 2009-8-24 21:45 | 显示全部楼层 |阅读模式
英文看起来不习惯,翻译了下,供大家参考,翻译不当的地方欢迎指出,原文如下:
.boot up your pc with windows
.start pro/e setup
.open ptc_licfile.dat with your fav txt-editor
.replace every occurance of 00-00-00-00-00-00 with the one shown in the bottom left corner of the Pro/e setup
(its your mac-id, format: xx-xx-xx-xx-xx)
.install pro/e - pro/m - pro/ds, i dont care which one or in which order
.on license-config screen select "nodelocked license" and point to edited ptc_licfile.dat
.blalala install
next for pro/engineer:
(if u didnt install the complete package, u get "missing file" errors, accept or bleed)
.run ptc.pro engineer.wildfire.4.0-patch.exe, point to <installdir>\i486_nt\obj folder
.edit <pro/e installdir>\bin\proev.bat
  change "%start_cmd% "%CGTECH_JRE%\bin\javaw" -Xms16m -Xmx64m -Xss4m -classpath "%CGTECH_CLASSES%;%CGTECH_CLASSES%\CGTech.jar" Vericut %argstr%" in
        "%start_cmd% "%CGTECH_JRE%\bin\javaw" -Xms16m -Xmx64m -Xss4m -classpath "%CGTECH_CLASSES%;%CGTECH_CLASSES%\CGTech.jar" Vericut %argstr% PTC_KEY=0"
(add PTC_KEY=0)
pro/mechanica:
.run ptc.pro mechanica.wildfire.4.0-patch.exe
.point to <pro/m installdir>\i486_nt\bin
                                         <pro/m installdir>\i486_nt\obj
                                         <pro/m installdir>\i486_nt\ptc
(in this order, after every "missing file" error)
pro/distributed services:
.run ptc.distributed.services.4.0-patch.exe and point to <pro/ds installdir>\i486_nt\obj
翻译如下:
.启动您的 window 操作系统
.运行 pro/e setup.exe 安装程序
.使用你喜欢的文本编辑器打开 ptc_licfile.dat 文件
.用 pro/e 安装程序左下角显示的主机ID(格式为 xx-xx-xx-xx-xx-xx)替换每一处 00-00-00-00-00-00
.安装 pro/e - pro/m - pro/ds,安装次序可随意
.在许可证配置界面选择“锁定的许可证文件”,浏览到之前修改过的 ptc_licfile.dat
.然后按向导完成安装
接下来运行 pro/engineer 补丁:
(如果你没有安装所有组件和模块的话,你会遇到提示“找不到文件”的错误,选择“否”即可。)
.复制 ptc.pro engineer.wildfire.4.0-patch.exe 到 <installdir>\i486_nt\obj 下运行
.编辑 edit <pro/e installdir>\bin 下的 proev.bat 文件,将 "%start_cmd% "%CGTECH_JRE%\bin\javaw" -Xms16m -Xmx64m -Xss4m -classpath "%CGTECH_CLASSES%;%CGTECH_CLASSES%\CGTech.jar" Vericut %argstr%" 替换为 "%start_cmd% "%CGTECH_JRE%\bin\javaw" -Xms16m -Xmx64m -Xss4m -classpath "%CGTECH_CLASSES%;%CGTECH_CLASSES%\CGTech.jar" Vericut %argstr% PTC_KEY=0"
(add PTC_KEY=0)
pro/mechanica 补丁:
.复制 ptc.pro mechanica.wildfire.4.0-patch.exe 到 <pro/m installdir> 下的 bin 和 ptc 两个目录内运行
pro/distributed services 补丁:
.复制 ptc.distributed.services.4.0-patch.exe 到 <pro/ds installdir>\i486_nt\obj 下运行
by 野火 2009.8.24
特别说明:
1、灰色斜体字表示的部分为非必须安装和配置的内容,一般无需安装可略过
2、pro/mechanica 原文说要修补3个文件夹,实际上只能找到2个,也许是未完整安装所有组件的缘故,也许原文有误,总之修补2个文件夹后完全可正常使用
发表于 2009-8-27 23:01 | 显示全部楼层
支持老大,这样方便多了!
发表于 2009-10-30 10:57 | 显示全部楼层
急需
找了好久了
发表于 2009-10-30 11:02 | 显示全部楼层
顶一下,谢谢分享!
发表于 2009-11-4 19:16 | 显示全部楼层
这还需要翻译,很简单的
发表于 2009-11-22 18:02 | 显示全部楼层
xieixe
发表于 2009-12-27 13:43 | 显示全部楼层
谢了,这就去试装一下。我没有把补丁复制到相应的文件夹下运行,而是直接在虚拟光驱中运行,然后手动查找它所要的文件。最后似乎也能正常工作。
头像被屏蔽
发表于 2010-1-21 10:34 | 显示全部楼层
发表于 2010-3-3 12:58 | 显示全部楼层
终于找到了
发表于 2010-4-6 22:30 | 显示全部楼层
要装4.0的朋友可以看一下,不一定要下注册码生成器
GMT+8, 2025-4-16 11:27 , Processed in 0.124742 second(s), 29 queries .
