查看: 8615|回复: 27
[下载] Pro/Engineer Wildfire 4.0 M100 补丁包 by SHooTERS
发表于 2009-8-23 23:28 | 显示全部楼层 |阅读模式
.boot up your pc with windows
.start pro/e setup
.open ptc_licfile.dat with your fav txt-editor
.replace every occurance of 00-00-00-00-00-00 with the one shown in the bottom left corner of the Pro/e setup
(its your mac-id, format: xx-xx-xx-xx-xx)
.install pro/e - pro/m - pro/ds, i dont care which one or in which order
.on license-config screen select "nodelocked license" and point to edited ptc_licfile.dat
.blalala install
next for pro/engineer:
(if u didnt install the complete package, u get "missing file" errors, accept or bleed)
.run ptc.pro engineer.wildfire.4.0-patch.exe, point to <installdir>\i486_nt\obj folder
.edit <pro/e installdir>\bin\proev.bat
  change "%start_cmd% "%CGTECH_JRE%\bin\javaw" -Xms16m -Xmx64m -Xss4m -classpath "%CGTECH_CLASSES%;%CGTECH_CLASSES%\CGTech.jar" Vericut %argstr%" in
        "%start_cmd% "%CGTECH_JRE%\bin\javaw" -Xms16m -Xmx64m -Xss4m -classpath "%CGTECH_CLASSES%;%CGTECH_CLASSES%\CGTech.jar" Vericut %argstr% PTC_KEY=0"
(add PTC_KEY=0)
pro/mechanica:
.run ptc.pro mechanica.wildfire.4.0-patch.exe
.point to <pro/m installdir>\i486_nt\bin
                                         <pro/m installdir>\i486_nt\obj
                                         <pro/m installdir>\i486_nt\ptc
(in this order, after every "missing file" error)
pro/distributed services:
.run ptc.distributed.services.4.0-patch.exe and point to <pro/ds installdir>\i486_nt\obj
安装在线视频教程:
http://down.proewildfire.cn/video/setup/200908/19.html
SHooTERS.rar
28.03 KB, 下载次数: 702
参与人数 1威望 +1 金钱 +5 收起 理由
yun0336wu + 1 + 5 感谢分享
发表于 2009-8-23 23:35 | 显示全部楼层
回复 楼主 野火 的帖子
辛苦了!
谢谢老大,这在某种意义上说,是“及时雨”尔!
俺正想将4.0 M070换为M100。(5.0不定何时日才得来MXXX版呐)。
发表于 2009-9-8 23:04 | 显示全部楼层
补丁,补了啥东西?英文不懂
发表于 2009-9-12 14:12 | 显示全部楼层
辛苦了!
谢谢老大,
发表于 2009-9-17 20:20 | 显示全部楼层
下载来,谢谢楼主
发表于 2009-9-24 19:30 | 显示全部楼层
就是破解文件了,呵呵
发表于 2009-10-9 13:50 | 显示全部楼层
我下载后解压,杀毒软件将其补丁删除了,只好先暂停杀毒,然户安装
发表于 2009-10-28 11:38 | 显示全部楼层
thank you very much
发表于 2009-11-18 10:23 | 显示全部楼层
谢谢,100的许可还真不好找
发表于 2009-11-20 18:11 | 显示全部楼层
谢谢楼主!
GMT+8, 2025-4-16 11:35 , Processed in 0.167204 second(s), 36 queries .
