查看: 40498|回复: 20
[下载] proe 野火 wildfire 3.0 M030 crack 注册机下载和安装说明
发表于 2007-10-27 23:38 | 显示全部楼层 |阅读模式
proe 3.0 m030 需要安装许可证服务器。附件里不包含 CGtech.dll 文件,因为我们一般都不用这个功能。只安装 PROE 的话只需要看下面蓝色的文字部分即可。
1.Use the Keygen.exe to generate your PTC HOST_ID license file;
2.Install the PTC License Server with your PTC HOST_ID license file which you got from Step 1;
3.Install Pro/ENGINEER, and select Single Server license type as the Pro/ENGINEER license;
  then fill "your computer name" as the HOSTNAME in the BLANK before the port "7788".
  *If you click the Setup Option" VERICUT (R) for Pro/ENGINEER" when you install Pro/ENGINEER and wanna the VERICUT as the
  *embedded software for pro/e, you should also do the following two steps for the embedded VERICUT:
  *    A. Copy the patched CGtech.dll into the installed directory \proeWildfire 3.0\i486_nt\obj to replace the original one.
  *    B. Find the following file in the installed directory \proeWildfire 3.0\bin\proev.bat and open it with an Editor software,
  *       search
  *          Vericut %argstr%
  *       and replace it with the following string:
  *          Vericut %argstr% PTC_KEY=0
  *       then save the file. the purpose of the step B. is to forbid the VERICUT to use the PTC lic as its lic.Actually, CGtech
  *       no longer supports its VERICUT as an embedded software for pro/e and no longer uses PTC lic.FYI, See the CGtech official
  *       website said:
  *            http://www.cgtech.com/ptc_update/index.htm
4.Install Pro/Mechanica(Structural and Thermal Simulation) like Step 3.
5.Install PTC Distributed Services.this step will automatically get the lic from the lic server installed at step 2.
6.That is all and enjoy it!
[ 本帖最后由 野火 于 2007-10-27 23:41 编辑 ]
PROE M030 注册机.rar
182.66 KB, 下载次数: 3281
发表于 2007-12-5 23:12 | 显示全部楼层
怎么用啊
请高手详细指点一下啊
发表于 2008-1-7 15:10 | 显示全部楼层
正需要哦!
liao108 该用户已被删除
发表于 2008-2-27 18:52 | 显示全部楼层
发表于 2008-2-28 20:34 | 显示全部楼层
为什么我安装后提示无效的LICENSE
发表于 2008-4-29 20:20 | 显示全部楼层
请问pro/machina能用吗
发表于 2008-6-19 10:00 | 显示全部楼层
跟我原来的一模一样
 我原来装来好几次都不行
发表于 2008-10-14 09:44 | 显示全部楼层
安装方法:
Pro/E wildfire 3.0
Pro/E wildfire 3.0安装说明
    1.在CD-ROM驱动器中放入《Pro/E wildfire 3.0》的安装盘,安装程序自动运行后会显示(图1)的界面,如果没有自动运行的话,请在安装盘所在的驱动器双击安装程序Autorun.exe运行;
    (注意:本产品为单机+服务器版,即使你没有网络也能正常使用本产品,条件是必需要有张网卡和装有网卡驱动,这样才能显示出主机PC ID号)
图1
     2.运行Pro/E wildfire 3.0,进入安装对话框, 记住红框内的主机名和PTC主机ID,按[下一个](图2);
图2
    3.将光盘上许可认证目录下license文件夹中的keygen.exe复制到硬盘任何空间并运行(图3);
图3
    4.输入先前界面上记录的ID,按Generate(图4)。
图4
    5.生成license.dat,用记事本打开license.dat将"__HOSTNAME__"改为界面上的主机名;如ID:land然后保存退出(图5)。
图5
    6.将license.dat复制到硬盘的根目录下(不能复制到中文目录中),然后安装 PTC License Server (图6)。
图6
    7.许可证安装,按打开(图7);
图7
    8.打开类型为dat文件,选择先前复制到硬盘根目录下的许可认证文件license.dat;
图8
    9.证明有效后,按[安装]。
图9
        10.正在安装(图10);
图10
    11.插入第二张光盘,按[确定](图11);
图11
    12.插入第一张光盘,按[确定](图12)。
图12
    13.继续安装(图13)。
图13
      14.安装完成,按[下一个](图14)
图14
      15.返回界面选择安装PRO/ENGIEER WILDFIRE 3.0,按[下一个](图15);
图15
      16.选左下角[选项]的三角形,按[安装所有子功能],语种除简体中文外其它都选[不安装此功能]如(图16);注意:英语语言一定要选[不安装此功能]不然安装后是英文的,多选几次,保留简体中文。
图16a
图16
        17.默认安装选项,按[下一个](图17)。
图17
       18.选择OLE设置选项,按[下一个](图18)。
图18
        19.正在安装(图19)。
图19
          20.正在安装(图20)。
图20
        21.插入第二张光盘(图21);
图21
        22.继续安装;
图22
        23.插入第一张光盘。
图23
        24.继续安装(图24);
图24
         25.安装结束,按[下一个]或[退出](图25);
图25
         26.退出,或继续安装Pro/Mechanica和PTC Distributed(图26)。
图26
          27.拷贝第一张光盘上许可认证文件夹中的CGtech.dll至x:\Program Files\ProeWildfire 3.0\i486_nt\obj复盖。
        28.然后在安装目录C:\Program Files\proeWildfire 3.0\bin中找到proev.bat,用鼠标对着这个文件点右键-编辑-,这时会以记事本方式浏览,在编辑上选查找,输入Vericut %argstr%查找,找到后在尾部加个空格打上PTC_KEY=0然后保存,退出。(此时如果运行proev.bat就能启动Vericut系统)
图28
       29.安装全部完成后,运行程序菜单---PTC----Pro ENGINEER-----Pro ENGINEER就可正常使用了,按文件--新建----选择自己需要的项目进行操作(图26)。(注意运行本产品时请关闭其它没必要开的程序,因启动时检测内部程序,等待1分钟就可以进入操作界面了)
图29
发表于 2009-5-30 00:40 | 显示全部楼层
回复 楼主 野火 的帖子
顶一下
发表于 2009-9-8 21:32 | 显示全部楼层
兄弟,怎么没有下载地址了啊
GMT+8, 2025-4-16 10:52 , Processed in 0.151614 second(s), 31 queries .
