查看: 2878|回复: 4
[求助] proec000的问题
发表于 2008-3-8 21:44 | 显示全部楼层 |阅读模式
我按admin的方法安装成功,但是点出现proe4.0的画面,但是程序没有到可操作的界面,望告之!谢谢
1272
发表于 2008-3-8 21:50 | 显示全部楼层
没进入有什么提示说清楚
 楼主| 发表于 2008-3-9 17:04 | 显示全部楼层
就是出现4.0的画面,但是也没有什么提示,就是到不了使用的界面
 楼主| 发表于 2008-3-9 18:14 | 显示全部楼层
Pro/ENGINEER is running with Unicode string encoding.
get_main_dialog:  no current active dialog (ORDER_DEBUG)
DUMMY - pro_set_input_devices_allowed
DUMMY - putxyres
pglSetStatus: Pgl Session Initialize
DUMMY - putxyres
ProCmdSelBufferAttrSet():  Selection Buffer Attribute loaded 40 commands (INFO MESSAGE)
PFSTFinalizeData:  No types, assuming all files (INFO MESSAGE)
Exception - code was -1073741819.
pro_notification_remove:  event_id 4 was never defined? (INFO MESSAGE)
pro_notification_remove:  event_id 5 was never defined? (INFO MESSAGE)
pro_notification_remove:  event_id 13 was never defined? (INFO MESSAGE)
pro_notification_remove:  event_id 14 was never defined? (INFO MESSAGE)
不好意思,我在bin打开的时候出现的,现在才发现,望高手告之原因,谢谢!
发表于 2008-3-9 19:28 | 显示全部楼层
求教
为什么我的PROE 3.0装上去用不了?
GMT+8, 2024-11-25 17:23 , Processed in 0.146256 second(s), 21 queries .
