查看: 59244|回复: 659
[下载] Pro/Engineer Wildfire 4.0 M080 补丁包 by SHooTERS
发表于 2009-4-26 21:08 | 显示全部楼层 |阅读模式
.boot up your pc with windows
.start pro/e setup
.open ptc_licfile.dat with your fav txt-editor
.replace every occurance of 00-00-00-00-00-00 with the one shown in the bottom left corner of the Pro/e setup
(its your mac-id, format: xx-xx-xx-xx-xx)
.install pro/e - pro/m - pro/ds, i dont care which one or in which order
.on license-config screen select "nodelocked license" and point to edited ptc_licfile.dat
.blalala install
next for pro/engineer:
(if u didnt install the complete package, u get "missing file" errors, accept or bleed)
.run ptc.pro engineer.wildfire.4.0-patch.exe, point to <installdir>\i486_nt\obj folder
.edit <pro/e installdir>\bin\proev.bat
  change "%start_cmd% "%CGTECH_JRE%\bin\javaw" -Xms16m -Xmx64m -Xss4m -classpath "%CGTECH_CLASSES%;%CGTECH_CLASSES%\CGTech.jar" Vericut %argstr%" in
        "%start_cmd% "%CGTECH_JRE%\bin\javaw" -Xms16m -Xmx64m -Xss4m -classpath "%CGTECH_CLASSES%;%CGTECH_CLASSES%\CGTech.jar" Vericut %argstr% PTC_KEY=0"
(add PTC_KEY=0)
pro/mechanica:
.run ptc.pro mechanica.wildfire.4.0-patch.exe
.point to <pro/m installdir>\i486_nt\bin
                                         <pro/m installdir>\i486_nt\obj
                                         <pro/m installdir>\i486_nt\ptc
(in this order, after every "missing file" error)
pro/distributed services:
.run ptc.distributed.services.4.0-patch.exe and point to <pro/ds installdir>\i486_nt\obj
看不懂英文补丁说明的,请看下帖中M070的中文补丁说明,一样的。
野火4.0-M070许可证和安装说明
http://www.proewildfire.cn/thread-18962-1-1.html
游客,如果您要查看本帖隐藏内容请回复
主妇
希望之星勋章热心助人勋章
发表于 2009-4-26 22:56 | 显示全部楼层
非常感谢!
发表于 2009-4-26 23:16 | 显示全部楼层
非常感谢
发表于 2009-4-27 09:28 | 显示全部楼层
下一个试试
发表于 2009-4-27 13:10 | 显示全部楼层
M070借来用能用吗?
发表于 2009-4-28 21:25 | 显示全部楼层
xie xie a
发表于 2009-4-29 09:22 | 显示全部楼层
回复 楼主 野火 的帖子
发表于 2009-4-29 09:37 | 显示全部楼层
感谢!
发表于 2009-4-29 19:25 | 显示全部楼层
回复 楼主 野火 的帖子
ddddddddddddd
发表于 2009-4-30 00:26 | 显示全部楼层
不知是不是全模块破解的!
GMT+8, 2025-4-16 11:29 , Processed in 0.129794 second(s), 31 queries .
