楼主: 54yihui
[原创] 【原创精品】AFX资源整合包,大部分原创制作!(持续更新中)
发表于 2023-3-22 08:05 | 显示全部楼层
发表于 2023-3-22 08:27 | 显示全部楼层
谢谢大佬!
发表于 2023-3-22 08:38 | 显示全部楼层
老大,压缩包已损坏!!!!啥情况
发表于 2023-3-22 18:16 | 显示全部楼层
非常感谢!请问需要破解吗
发表于 2023-3-22 19:03 | 显示全部楼层
发表于 2023-3-24 15:50 | 显示全部楼层
发表于 2023-3-26 21:50 | 显示全部楼层
牛逼 格拉斯
发表于 2023-3-26 22:39 | 显示全部楼层
谢谢分享。
发表于 2023-3-26 23:36 | 显示全部楼层
楼主看一下这个start_mdl_layer_configuration.txt 有乱码。
=== AFX Layer configuration ===
It is now possible to do some Layer actions for AFX parts via start_mdl.cfg. First of all here is a List of all existing AFX Layers:
00_CONNECTOR_SURFACE                        For D30 Item Parts. Required for the assembly of connectors
00_PROFIL_DATUM                                General layer with datums
00_PROFIL_END_CSYS                        CS_S and CS_E of beams
00_PROFIL_GEOMETRY                        Geometry of beams
00_PROFIL_IMPORT                                Import geometry
00_PROFIL_QUILT                                Quilts for cuts with beams
00_PROFIL_SIZE_NOTE                        Annotations with profile size information
00_PROFIL_SLOT_CURVE                        Slot curves for bosch and item profiles
00_PROFIL_SUBASM_END_SURFS        Project subasm end surfaces
00_PROFIL_SUBASM_REF_CURVE        Project subasm curve
00_SCREW_POINTS                                Datum points for screw connections
00_PROFIL_DRW_HIDE                        Layer with all datums sorfaces and curves
The following new functions were implemented in the start_mdl.cfg file:
* RENAME_LAYER <OLD_NAME> <NEW_NAME>
        Renames the existing layer to the new given name.
        Optional: RENAME_LAYER_PART / RENAME_LAYER_ASM: to just rename Part or assembly layers
* DELETE_LAYER <LAYERNAME>
        Deletes the given Layer.
        Optional:         DELETE_LAYER_PART / DELETE_LAYER_ASM: to just delete Part or assembly layers
                                DELETE_LAYER ALL: Deletes all layers
* RULE_LAYER_TEMPLATE <TEMPLATE>
        Define the name of a Layertemplate. All rule based layers from that template will be copied to any new AFX part.
        The path for the file is afx/configuration/
        Optional: RULE_LAYER_TEMPLATE_PART / RULE_LAYER_TEMPLATE_ASM: If you want different names for part/asm
CREATE_RULE_LAYER_PARAM YES / NO
        Will create the feature parameter BUW_LAYER_INFO with the name of the layer that the feature is stored on.
        This enables you to create a set of layer rules to collect all features that are specific for AFX on a certain
        layer.
=== AFX Folienkonfiguration ===
Sie haben jetzt die M鰃lichkeit Folienaktionen f黵 AFX Bauteile mit Hilfe der start_mdl.cfg durchzuf黨ren. Vorab hier eine Liste aller existierenden Folien:
00_CONNECTOR_SURFACE                        F黵 D30 Item Teile. Wird f黵 den Einbau von connectors ben鰐igt
00_PROFIL_DATUM                                        Generelle Folie mit Bez黦en
00_PROFIL_END_CSYS                                CS_S und CS_E der Profile
00_PROFIL_GEOMETRY                                Geometrie von Profilen
发表于 2023-3-27 09:34 | 显示全部楼层
谢谢楼主!下来学习!
GMT+8, 2026-3-22 03:48 , Processed in 0.152418 second(s), 23 queries .
