楼主: zkq1975
[下载] CREO 9.0.1.0百度网盘下载
发表于 2022-7-18 09:11 | 显示全部楼层
buyong不用 crack了?都
发表于 2022-7-18 09:25 | 显示全部楼层
谢谢分享 下来用用
 楼主| 发表于 2022-7-18 09:39 | 显示全部楼层
钟汉昌 发表于 2022-7-18 09:11
buyong不用 crack了?都
两个文件夹的文件是复制到安装目录的破解文件,bat文件是生成许可证的批处理文件。安装过程与以前版本一样。
1. Copy folder "PTC.LICENSE.WINDOWS.2022-04-21-SSQ" to temporary directory
   and run "FillLicense.bat". The "PTC_D_SSQ.dat" file near batch script
   contains the license file with correct PTC HOSTID will be generated
   Copy generated license file to folder of choice (for example, C:\Program Files\PTC)
2. Create enviroment variable PTC_D_LICENSE_FILE=<full path to PTC_D_SSQ.dat>
3. Install PTC Creo 9.0.1.0 Win64
4. Overwrite original <Creo 9.0.1.0> program folder
   (by default C:\Program Files\PTC\Creo 9.0.1.0 ) with cracked one
5. Run "SolidSQUADLoaderEnabler.reg" and confirm to add info into Windows Registry
6. ATTENTION!
   License file includes some floating and Super Bundle licenses
   To activate floating and Super Bundle licenses in current Creo session do the next:
    File > Options > Licensing > Refresh License List
   Select desired or all floating licenses and Super bandles and click "OK"
   To activate floating and Super Bundle licenses permanently do the next:
    Run as Administrator <Creo program folder>..\Parametric\bin\reconfigure.exe
    Next > Next > Customaze Applications.. > Command Configuration > Edit >
    open Floating Options list > add desiged licenses to "Startup extentions and
    floating options" tab > OK > Install > OK
7. REBOOT
8. Enjoy!
Cracked by TeAM SolidSQUAD-SSQ
 楼主| 发表于 2022-7-18 09:46 | 显示全部楼层
破解文件已经重新上传
发表于 2022-7-18 10:52 | 显示全部楼层
发表于 2022-7-18 10:53 | 显示全部楼层
感谢分享
发表于 2022-7-18 10:55 | 显示全部楼层
感谢,感谢
发表于 2022-7-18 11:20 | 显示全部楼层
终于可以在百度网盘可以下载了。
VIP 勋章
发表于 2022-7-18 11:43 | 显示全部楼层
下一个试试,谢谢
发表于 2022-7-18 12:54 | 显示全部楼层
谢谢分享,楼主辛苦了!
GMT+8, 2025-4-22 04:38 , Processed in 0.113988 second(s), 21 queries .
