查看: 9788|回复: 2
[求助] 小白想请教一下二次开发时的报错问题
发表于 2022-3-26 23:35 | 显示全部楼层 |阅读模式
今天在模仿一个例子的时候报错出现这个问题,想问下各位大佬如何解决?
https://blog.csdn.net/hisinwang/article/details/79120655?spm=1001.2014.3001.5502 具体用的是这篇帖子里的第一个例子
ProError UserAssembleByDatums(ProAssembly asm_model,
                              ProSolid  comp_model)
    ProError err;
    ProMatrix identity_matrix = {
        { 1.0, 0.0, 0.0, 0.0 },
        { 0.0, 1.0, 0.0, 0.0 },
        { 0.0, 0.0, 1.0, 0.0 },
        { 0.0, 0.0, 0.0, 1.0 } };
    ProAsmcomp asmcomp;
    ProAsmcompconstraint* constraints;
    ProAsmcompconstraint constraint;
    ProBoolean interact_flag = PRO_B_FALSE;
    ProModelitem asm_datum, comp_datum;
    ProSelection asm_sel, comp_sel;
    ProAsmcomppath comp_path;
    ProIdTable c_id_table;
    c_id_table [0] = -1;
    // 参考特征名称
    ProName asm_datums[3];
    ProName comp_datums[3];
    ProStringToWstring(asm_datums[0], "ASM_FRONT");
    ProStringToWstring(asm_datums[1], "ASM_TOP");
    ProStringToWstring(asm_datums[2], "ASM_RIGHT");
    ProStringToWstring(comp_datums[0], "FRONT");
    ProStringToWstring(comp_datums[1], "TOP");
    ProStringToWstring(comp_datums[2], "RIGHT");
    // 组装
    ProAsmcompAssemble(asm_model, comp_model, identity_matrix, &asmcomp);
    // 添加约束
    ProArrayAlloc(0, sizeof(ProAsmcompconstraint), 1, (ProArray*)&constraints);
    for (int i = 0; i < 3; i++)
        err = ProModelitemByNameInit(asm_model, PRO_SURFACE, asm_datums, &asm_datum);
        if (err != PRO_TK_NO_ERROR)
            interact_flag = PRO_B_TRUE;
            continue;
        err = ProModelitemByNameInit(comp_model, PRO_SURFACE, comp_datums, &comp_datum);
            continue;
        // 元件路径
        err = ProAsmcomppathInit(asm_model, c_id_table, 0, &comp_path);
        // 参考
        err = ProSelectionAlloc(&comp_path, &asm_datum, &asm_sel);
        err = ProSelectionAlloc(NULL, &comp_datum, &comp_sel);
        // 约束
        err = ProAsmcompconstraintAlloc(&constraint);
        err = ProAsmcompconstraintTypeSet(constraint, PRO_ASM_ALIGN);
        err = ProAsmcompconstraintAsmreferenceSet(constraint, asm_sel, PRO_DATUM_SIDE_YELLOW);
        err = ProAsmcompconstraintCompreferenceSet(constraint, comp_sel, PRO_DATUM_SIDE_YELLOW);
        err = ProArrayObjectAdd((ProArray*)&constraints, -1, 1, &constraint);
    // 设置元件特征的约束
    err = ProAsmcompConstraintsSet(NULL, &asmcomp, constraints);
    // 重生
    ProSolidRegenerate((ProSolid)asmcomp.owner, PRO_REGEN_CAN_FIX);
    if (interact_flag)
        ProAsmcompConstrRedefUI(&asmcomp);
    // 释放数组空间
    ProArrayFree((ProArray*)&constraints);
    return PRO_TK_NO_ERROR;
// 测试组装
int TestAssembly001(uiCmdCmdId  command,
                    uiCmdValue *p_value,
                    void       *p_push_command_data)
    ProError err;
    // 获取组立档案:ASM0001.ASM
    ProMdl mdlAsm;
    err = ProMdlInit(L"ASM0001", PRO_MDL_ASSEMBLY, &mdlAsm);
    if (PRO_TK_E_NOT_FOUND == err)
        MessageBoxW(NULL, L"未打开ASM0001.ASM", L"www.icaxdev.com", MB_OK);
        return -1;
    // 获取要组装的档案RT0001.PRT
    ProMdl mdlComp;
    err = ProMdlInit(L"RT0001", PRO_MDL_PART, &mdlComp);
        MessageBoxW(NULL, L"未打开PRT0001.PRT", L"www.icaxdev.com", MB_OK);
        return -1;
    // 进行组装
    UserAssembleByDatums((ProAssembly)mdlAsm, (ProSolid)mdlComp);
    return 0;
115
发表于 2022-4-6 16:30 | 显示全部楼层
应该是使用那个函数前 应该先声明下
发表于 2022-4-6 19:53 | 显示全部楼层
环境设置参考自带实例改正一下试试
GMT+8, 2026-3-25 06:50 , Processed in 0.193249 second(s), 27 queries .
