楼主: Mr_Jaken
[已解决] CREO导出DWG工程图的配置文件怎么修改
发表于 2022-6-19 13:08 | 显示全部楼层
不错,谢谢分享
 楼主| 发表于 2022-6-22 11:22 | 显示全部楼层
Mr_Jaken 发表于 2021-1-26 15:32
已经调好了,谢谢
table.pnt文件
! color white for pen1轮廓线
pen 1 thickness 0.03 cm; color 0.0 0.0 0.0; drawing_color
! color yellow for pen2 尺寸线
pen 2 thickness 0.005 cm; color 0.0 0.0 0.0; letter_color
! color red for pen3
pen 3 thickness 0.01 cm; color 0.0 0.0 0.0; highlite_color
! color gray for pen4
pen 4 thickness 0.01 cm; color 0.0 0.0 0.0; dimmed_color
! color cyan for pen5
pen 5 thickness 0.03 cm; color 0.0 0.0 0.0; section_color
! color magenta for pen6
pen 6 thickness 0.01 cm; color 0.0 0.0 0.0; magenta_color
! color dark_blue for pen7
pen 7 thickness 0.04 cm; color 0.0 0.0 0.0; background_color
! color green for pen8
pen 8 thickness 0.03 cm; color 0.0 0.0 0.0;
 楼主| 发表于 2022-6-22 11:24 | 显示全部楼层
已经调好了,谢谢
dxf_export.pro
! This is a DXF/DWG export mapping file example.
! It should be used as a reference for mapping
! color/layer/linestyle/text font functionality
map_layer DXF_FORMAT _图框
map_layer DXF_Text _文本批注
map_layer DXF_AXIS _轴线
map_layer DXF_CONTINUOUS_LINE _粗实线
map_layer DXF_DIMENSION _尺寸标注
map_layer DXF_HATCHING _剖面线
map_layer DXF_HIDDEN_LINE _虚线
map_color       BACKGROUND_COLOR          7
! 背景颜色!
map_color       DIMMED_COLOR              3
! 标注尺寸颜色!
map_color       LETTER_COLOR              3
! 字母颜色!
map_color       HIGHLIGHT_COLOR           6
! 突出显示颜色!
map_color       EDGE_HIGHLIGHT_COLOR      6
! 加亮边颜色!
map_color       GEOMETRY_COLOR            7
! 几何图形颜色!
map_color       HIDDEN_COLOR              7
! 隐藏线颜色!
map_color       SHEETMETAL_COLOR          7
!钣金件!
map_color       CURVE_COLOR               7
!曲线!
map_color       VOLUME_COLOR              7
!制造体积块!
map_color       SECTION_COLOR             7
!草绘
map_color       PRESEL_HIGHLIGHT_COLOR    7
!预加亮项!
map_color       SELECTED_COLOR            7
!选中项目!
map_color       SECONDARY_SELECTED_COLOR  7
!二次选择
map_color       PREVIEW_GEOM_COLOR        7
!预览几何!
map_color       SECONDARY_PREVIEW_COLOR   7
!二次预览几何!
map_color       DATUM_COLOR               1
!基准!
map_color       QUILT_COLOR               7
!面组!
map_layer       DXF_AXIS                  1
map_layer       DXF_CONTINUOUS_LINE       2
map_layer       DXF_HIDDEN_LINE           3
map_layer       DXF_DIMENSION             4
map_layer       DXF_TEXT                  5
map_layer       DXF_HATCHING              6
map_layer       DXF_TABLE                 7
map_layer       DXF_BALLOON               8
map_layer       DXF_FORMAT                9
map_line_style  solidfont                 bylayer
map_line_style  phantomfont               bylayer
map_line_style  ctrlfont                  bylayer
map_line_style  bylayerfont               bylayer
map_line_style  dashfont                  bylayer
map_line_style  ctrlfont_s_l              center
map_line_style  ctrlfont_s_s              center
map_line_style  ctrlfont_l_l              bylayer
map_line_style  dashfont_s_s              bylayer
map_line_style  phantomfont_s_s           bylayer
map_line_style  ctrlfont_mid_l            bylayer
map_font        font                      simplex.shx
map_font        filled                    bigfont.shx
map_font        isofont                   arial.ttf
map_font                  cal_alf                  isocp.shx,hzfs.shx
map_font                  cal_grek                 isocp.shx,hzfs.shx
map_font                  chfntf                   isocp.shx,hzfs.shx
map_font                  chfnth                   isocp.shx,hzfs.shx
map_font                  chfntk                   isocp.shx,hzfs.shx
map_font                  font3d                   isocp.shx,hzfs.shx
map_font                  font_chinese_cn          isocp.shx,hzfs.shx
map_font                  font_hebrew              isocp.shx,hzfs.shx
map_font                  font_latin               isocp.shx,hzfs.shx
map_font                  iso30985font             isocp.shx,hzfs.shx
map_font                  isofont                  isocp.shx,hzfs.shx
map_font                  leroy                    isocp.shx,hzfs.shx
map_font                  norm_fonts               isocp.shx,hzfs.shx
map_font                  special characters       isocp.shx,hzfs.shx
map_font                  ttf_font                 isocp.shx,hzfs.shx
map_font                  win_chcn_font            isocp.shx,hzfs.shx
map_font                  win_font                 isocp.shx,hzfs.shx
map_font                  font                     isocp.shx,hzfs.shx
map_font                  filled                   isocp.shx,hzfs.shx
发表于 2022-7-19 08:26 | 显示全部楼层
楼主太优秀了,必须给个赞,这个转CAD始终是个头疼的事,再次感谢楼主的奉献!
发表于 2022-10-31 08:23 | 显示全部楼层
CREO是怎样的,转出CAD是怎样的效果呀?发几张图上来看看吧。
发表于 2022-12-17 17:37 | 显示全部楼层
学习下,谢谢分享
发表于 2023-6-9 16:55 | 显示全部楼层
Dxf_export.pro
发表于 2023-7-28 16:26 | 显示全部楼层
我想问一哈 在那个config.pro 文件里添加路径怎么加啊
发表于 2023-8-9 21:52 | 显示全部楼层
damaogege 发表于 2021-1-26 15:32
自己根据cad映射文件条,看附件说明
感谢,简直完美
发表于 2023-8-10 14:20 | 显示全部楼层
谢谢分享了
GMT+8, 2025-2-19 06:31 , Processed in 0.142762 second(s), 20 queries .
