1. Copy folder "PTC.LICENSE.WINDOWS.2019-03-20-SSQ" to temporary directory and run "FillLicense.bat". The "PTC_D_SSQ.dat" file near batch script contains the license file with correct PTC HOSTID will be generated
Copy generated license file to folder of choice (for example, C:\Program Files\PTC)
2. Create enviroment variable PTC_D_LICENSE_FILE=<full path to PTC_D_SSQ.dat>
3. Install PTC Creo 6.0.0.0 Win64 and PTC Mathcad Prime 5.0.0.0 Win64 (optional)
4. Copy folders "Distributed Services Manager" and "Common Files" from "Creo 6.0.0.0" folder to <Creo 6.0.0.0 program folder>
(by default C:\Program Files\PTC\Creo 6.0.0.0\ ) with overwrite
5. Overwrite original <Mathcad Prime 5.0.0.0 program folder>
(by default C:\Program Files\PTC\Mathcad Prime 5.0.0.0 ) with cracked one
6. Run "SolidSQUADLoaderEnabler.reg" and confirm to add info into Windows Registry
