查看: 125441|回复: 67
[下载] Pro/Engineer Wildfire 4.0 M050 补丁包 by SHooTERS
发表于 2008-12-3 14:23 | 显示全部楼层 |阅读模式
.boot up your pc with windows
.start pro/e setup
.open ptc_licfile.dat with your fav txt-editor
.replace every occurance of 00-00-00-00-00-00 with the one shown in the bottom left corner of the Pro/e setup
(its your mac-id, format: xx-xx-xx-xx-xx)
.install pro/e - pro/m - pro/ds, i dont care which one or in which order
.on license-config screen select "nodelocked license" and point to edited ptc_licfile.dat
.blalala install
next for pro/engineer:
(if u didnt install the complete package, u get "missing file" errors, accept or bleed)
.run ptc.pro engineer.wildfire.4.0-patch.exe, point to <installdir>\i486_nt\obj folder
.edit <pro/e installdir>\bin\proev.bat
  change "%start_cmd% "%CGTECH_JRE%\bin\javaw" -Xms16m -Xmx64m -Xss4m -classpath "%CGTECH_CLASSES%;%CGTECH_CLASSES%\CGTech.jar" Vericut %argstr%" in
        "%start_cmd% "%CGTECH_JRE%\bin\javaw" -Xms16m -Xmx64m -Xss4m -classpath "%CGTECH_CLASSES%;%CGTECH_CLASSES%\CGTech.jar" Vericut %argstr% PTC_KEY=0"
(add PTC_KEY=0)
pro/mechanica:
.run ptc.pro mechanica.wildfire.4.0-patch.exe
.point to <pro/m installdir>\i486_nt\bin
                                         <pro/m installdir>\i486_nt\obj
                                         <pro/m installdir>\i486_nt\ptc
(in this order, after every "missing file" error)
pro/distributed services:
.run ptc.distributed.services.4.0-patch.exe and point to <pro/ds installdir>\i486_nt\obj
PTC.Pro.ENGINEER.Wildfire.v4.M050.Win32.DVD-SHooTERS.rar
26.65 KB, 下载次数: 5349
参与人数 1威望 +1 金钱 +4 收起 理由
zmorphis + 1 + 4 感谢分享
141
优秀斑竹勋章宣传大使勋章斑竹勋章希望之星勋章
发表于 2008-12-3 16:55 | 显示全部楼层
感谢分享,丰富资源。
发表于 2008-12-3 20:16 | 显示全部楼层
没有看明白,o(∩_∩)o...
发表于 2008-12-5 23:17 | 显示全部楼层
thanks
good
发表于 2008-12-5 23:57 | 显示全部楼层
这个应该是破解用的,在安装文件中也有的~不过还是谢谢楼主放出~
发表于 2008-12-6 21:43 | 显示全部楼层
谢谢楼主。。。
发表于 2008-12-17 18:30 | 显示全部楼层
楼主怎么不给翻译一下啊。看不东啊
发表于 2008-12-22 11:43 | 显示全部楼层
老大,有没有64位的?
发表于 2008-12-22 17:25 | 显示全部楼层
是啊楼主说一下是什么啊
发表于 2008-12-28 16:31 | 显示全部楼层
谢谢楼主放出~
GMT+8, 2025-4-16 11:22 , Processed in 0.168959 second(s), 30 queries .
