查看: 2677|回复: 3
[求助] 懂英文的入---安装步骤
发表于 2008-11-3 21:11 | 显示全部楼层 |阅读模式
PTC Pro/ENGINEER Wildfire 4.0 F000
1> open license.dat then displace all string"00-00-00-00-00-00" with your PTC_HOST_ID(Your netcard physical address) then save.
2> Install your pro/E &Pro/M wildfire4.0 F000 with above modified lic file.Node Locked lic method. No lic server installaion needed.
2.Run patchs!
Put proe-patch.exe under directory :
<Installed location>\proeWildfire 4.0\i486_nt\obj       then apply it.
Put prom-patch1.exe under directory :
<Installed location>\proeWildfire 4.0\mech\i486_nt\bin      then apply it.
Put prom-patch2.exe under directory :
<Installed location>\proeWildfire 4.0\mech\i486_nt\ptc      then apply it.
3.If you want install PTC Distributed Services,access PTC.Setup: other product->PTC Distributed Services, use the modified license.dat at step one with node locked lic method. then
Put prods-patch.exe under directory :
<Installed location>\ptc_distributed_services\     then apply it.
P.S. Regarding embedded Vericut:
Actually, CGtech no longer supports its VERICUT as an embedded software for pro/e and no longer uses PTC lic.FYI, See the CGtech official website said:   http://www.cgtech.com/ptc_update/index.htm  hence don't offer patch for it.
That's all.Enjoy it!
Team ZWT 2008
1272
发表于 2008-11-3 21:14 | 显示全部楼层
论坛有安装图解教程,看置顶帖
优秀斑竹勋章宣传大使勋章斑竹勋章希望之星勋章
发表于 2008-11-3 21:18 | 显示全部楼层
打开license.dat,把00-00-00-00-00-00换成你的主机hostid。
运行keygen.bat,生成一个license.dat文件
太多了....
我靠,自己在论坛上搜索吧,proe4。0安装步骤//
头像被屏蔽
宣传大使勋章
发表于 2008-11-3 21:36 | 显示全部楼层
GMT+8, 2024-11-27 07:39 , Processed in 0.135632 second(s), 27 queries .
