查看: 5241|回复: 5
[求助] 还是装标准库的问题,求解答
发表于 2017-3-4 14:47 | 显示全部楼层 |阅读模式
  之前装标准库失败了,找了很久发现是有一个步骤错了,好像是pro_build_library_ctg.bat 运行不了,双击闪一下就退了
时刻保持学习的姿态!
生命不止,学习不息!
I believe i can!
发表于 2017-3-4 16:27 | 显示全部楼层
这是一个批处理文件,可以打开看一下有没有什么问题。
 楼主| 发表于 2017-3-4 16:28 | 显示全部楼层
就是打不开啊,双击就闪一下
时刻保持学习的姿态!
生命不止,学习不息!
I believe i can!
 楼主| 发表于 2017-3-4 16:30 | 显示全部楼层
这是里面的东西;@echo off
set MC=unset
if "%PROCESSOR%" == "INTEL_64" set MC=ia64_nt
if "%PROCESSOR%" == "INTEL_486" set MC=i486_nt
if "%PROCESSOR_ARCHITECTURE%" == "IA64" set MC=ia64_nt
if "%PROCESSOR_ARCHITECTURE%" == "AMD64" set MC=x86e_win64
if "%PROCESSOR_ARCHITECTURE%" == "x86" set MC=i486_nt
if not "%MC%" == "unset" goto mc_done
echo ERROR Cannot detect what machine type you have.
echo Please make one of the following settings:
echo.
echo set PROCESSOR=INTEL_486     - For Windows NT Intel based machines.
echo.
echo set PROCESSOR=INTEL_64      - For Windows Intel Itanium based machines.
echo.
echo set PROCESSOR_ARCHITECTURE=AMD64 - For Windows AMD 64 based machines.
echo.
exit
:mc_done
set PRO_MACHINE_TYPE=%MC%
if "%PROOBJ_START_DIRECTORY%" == "" set PRO_DIRECTORY=
if NOT "%PRO_DIRECTORY%" == "" "%PRO_DIRECTORY%\bin\%MC%_ptc_setvars" %0 "pro_build_library_ctg" bat
if "%PRO_DIRECTORY%" == "" %MC%_ptc_setvars %0 "pro_build_library_ctg" bat
call ptc_setvars.bat
del  ptc_setvars.bat
set start_cmd=start ""
set PRO_DIRECTORY=%PRODIR%
if NOT "%PTCPATH%" == "" goto ptcpathset
set path=%PRO_DIRECTORY%\bin;%path%
set PTCPATH=true
:ptcpathset
"%PRO_DIRECTORY%\%MC%\obj\pro_build_library_ctg" %1 %2 %3 %4 %5 %6
:ptc_end
exit /B %ERRORLEVEL%
时刻保持学习的姿态!
生命不止,学习不息!
I believe i can!
发表于 2017-3-4 18:47 | 显示全部楼层
标准库是分32位和64位的两种版本,会不会版本不对啊?
发表于 2019-5-23 15:11 | 显示全部楼层
谢谢,非常感谢,谢谢
GMT+8, 2025-4-19 10:01 , Processed in 0.147507 second(s), 25 queries .
