查看: 45956|回复: 65
[分享] Proe Mf4.0 M050破解安装方法及破解文件
发表于 2008-10-26 09:18 | 显示全部楼层 |阅读模式
大家好,本次只传上Proe Mf4.0 M050破解安装方法,包括我用机器译的文件,请高手译得更完善和准确些,我是英盲.请谅解.下载软件很容易下载失败,主要原因是下载时容易将破解文件将病毒处理,破解文件下次传上来.安装方法与PROE其他版本一样,只是破解文件安装有点区别.所以reeadme.txt(破解文件安装方法)原文翻译准确的我发给你Proe Mf4.0 M050全部软件.共2.8GB.
文件名如下:
ptc.distributed.services.4.0.win32-patch.exe(破解文件1)(下次上传上来)
ptc.pro engineer.wildfire.4.0.win32-patch.exe(破解文件2)(下次上传上来)
ptc.pro mechanica.widlfire.4.0.win32-patch.exe(破解文件3)(下次上传上来)
ptc_licfile.dat(安装许可证文件)(下次上传上来)
reeadme.txt(破解文件安装方法)原文如下:
.boot up your pc with windows
.start pro/e setup
.open ptc_licfile.dat with your fav txt-editor
.replace every occurance of 00-00-00-00-00-00 with the one shown in the bottom left corner of the Pro/e setup
(its your mac-id, format: xx-xx-xx-xx-xx)
.install pro/e - pro/m - pro/ds, i dont care which one or in which order
.on license-config screen select "nodelocked license" and point to edited ptc_licfile.dat
.blalala install
next for pro/engineer:
(if u didnt install the complete package, u get "missing file" errors, accept or bleed)
.run ptc.pro engineer.wildfire.4.0-patch.exe, point to <installdir>\i486_nt\obj folder
.edit <pro/e installdir>\bin\proev.bat
  change "%start_cmd% "%CGTECH_JRE%\bin\javaw" -Xms16m -Xmx64m -Xss4m -classpath "%CGTECH_CLASSES%;%CGTECH_CLASSES%\CGTech.jar" Vericut %argstr%" in
        "%start_cmd% "%CGTECH_JRE%\bin\javaw" -Xms16m -Xmx64m -Xss4m -classpath "%CGTECH_CLASSES%;%CGTECH_CLASSES%\CGTech.jar" Vericut %argstr% PTC_KEY=0"
(add PTC_KEY=0)
pro/mechanica:
.run ptc.pro mechanica.wildfire.4.0-patch.exe
.point to <pro/m installdir>\i486_nt\bin
                                         <pro/m installdir>\i486_nt\obj
                                         <pro/m installdir>\i486_nt\ptc
(in this order, after every "missing file" error)
pro/distributed services:
.run ptc.distributed.services.4.0-patch.exe and point to <pro/ds installdir>\i486_nt\obj
reeadme.txt(破解文件安装方法)原文机器译成如下:
。启动你的电脑与Windows
。启动Pro / E的安装
。开放ptc_licfile.dat您最喜欢的文本编辑器
。替换每次发生00-00-00-00-00-00同一个显示在左下角的Pro / E的安装
  (你的Mac其标识,格式: XX日至XX - XX日至XX - 20 )
。安装Pro / E的-亲/米-亲/双链,我不照顾哪一个,或在该命令
。许可配置屏幕上选择“ nodelocked许可证” ,并指向编辑ptc_licfile.dat
。 blalala安装
明年的Pro / Engineer的:
(如果ü didn't安装完整的包装厂获得“遗失档案”的错误,接受或出血)
。运行ptc.pro engineer.wildfire.4.0 - patch.exe ,指向<installdir> \ i486_nt \判断文件夹
。编辑<pro/e installdir> \斌\ proev.bat
  改变“ % start_cmd % ” % CGTECH_JRE % \斌\ javaw “ Xms16m - Xmx64m - Xss4m ,类路径” % CGTECH_CLASSES % ; % CGTECH_CLASSES % \ CGTech.jar “ Vericut % argstr % ”的
         “ % start_cmd % ” % CGTECH_JRE % \斌\ javaw “ Xms16m - Xmx64m - Xss4m ,类路径” % CGTECH_CLASSES % ; % CGTECH_CLASSES % \ CGTech.jar “ Vericut % argstr % PTC_KEY = 0 ”
  (新增PTC_KEY = 0 )
亲/力学:
。运行ptc.pro mechanica.wildfire.4.0 - patch.exe
  。指向<pro/m installdir> \ i486_nt \斌
  <pro/m installdir> \ i486_nt \对象
  <pro/m installdir> \ i486_nt \ PTC公司
  (在此命令后,每一个“遗失档案”的错误)
亲/分布式服务:
。运行ptc.distributed.services.4.0 - patch.exe ,并指向<pro/ds installdir> \ i486_nt \对象
[ 本帖最后由 bachsz 于 2008-10-27 00:13 编辑 ]
Proe WF4_CRK (M050).rar
25.82 KB, 下载次数: 3882
PROE MF4.0 M050破解文件
参与人数 1威望 +1 金钱 +3 收起 理由
野火 + 1 + 3 感谢分享
发表于 2008-10-26 09:56 | 显示全部楼层
把你谦虚的那句话删除了,被网监查到可能是非法内容
 楼主| 发表于 2008-10-26 12:08 | 显示全部楼层
回复 2# 的帖子
谢谢,
呵呵,我想我说的是一句真实的且调侃自已的玩笑话,不应当这算反动或者说黄色,也不攻击任何人,算什么条例约束呀?不怪网站,只怪我出生得太早,也许若干年后再来看现在的事就是我们现在看以前的事一样的.
[ 本帖最后由 bachsz 于 2008-10-27 00:16 编辑 ]
发表于 2008-10-26 16:53 | 显示全部楼层
破解文件呢???
 楼主| 发表于 2008-10-27 00:14 | 显示全部楼层
回复 4# 的帖子
已传上来了,请收,
发表于 2008-10-27 01:25 | 显示全部楼层
到底怎么破解 没讲清楚啊···············
发表于 2008-10-30 12:09 | 显示全部楼层
这翻译能看懂?。。
发表于 2008-10-30 20:03 | 显示全部楼层
和前几个版本安装差不多
发表于 2008-10-31 10:37 | 显示全部楼层
>>启动视窗
.start pro/e setup
>>开始执行安装目录中的“setup.exe"文件
>>可以用记事本(notepad)打开”ptc_licfile.dat“文件
.replace every occurance of 00-00-00-00-00-00 with the one shown in the bottom left corner of the Pro/e setup(its your mac-id, format: xx-xx-xx-xx-xx)
>>把”ptc_licfile.dat“文件中的 “00-00-00-00-00-00”替换 成你自己电脑网卡的物理地址(格式为:xx-xx-xx-xx-xx),在刚进入安装界面时在左下角你可以看到这一行代号
>>你也可以在DOS环境中(>开始>运行>cmd,回车即可)输入”ipconfig/all” ,找到它。
>>选择你要安装的组件(无所谓先后顺序)
>>在“指定许可证服务器”窗口请选择“锁定许可证文件”,在路径中选中刚才编辑(替换)的”ptc_licfile.dat“文件
.blalala install
>>往下开始安装
>>在安装目录…\i486_nt\obj 下运行“ptc.pro engineer.wildfire.4.0-patch.exe”这个补丁文件
.edit <pro/e installdir>\bin\proev.bat >> 编辑这个批处理文件
change >>更改下面这一句,在最后加上“PTC_KEY=0“
in
(add PTC_KEY=0)
发表于 2008-10-31 10:58 | 显示全部楼层
有人破解成功了吗?把三个破解破解文档分别放到哪几个文件夹patch?说清楚点哦。
GMT+8, 2025-4-20 22:03 , Processed in 0.149714 second(s), 32 queries .
