野火论坛
查看: 3582|回复: 0
[分享] proeWildfire 5.0
Rank: 1
发表于 2015-6-26 23:13 | 显示全部楼层 |阅读模式
1> open license.dat then displace all string"00-00-00-00-00-00" with your PTC_HOST_ID (Your netcard physical address) then save.
2> Install your pro/E &Pro/M with above modified lic file.Node Locked lic method. No lic server installaion needed.
2.Run patchs!
Put proe-patch.exe under directory :
<Installed location>\proeWildfire 5.0\i486_nt\obj       then apply it.
Put prom-patch1.exe under directory :
<Installed location>\proeWildfire 5.0\mech\i486_nt\bin      then apply it.
Put prom-patch2.exe under directory :
<Installed location>\proeWildfire 5.0\mech\i486_nt\ptc      then apply it.
3.If you want install PTC Distributed Services,access PTC.Setup: other product->PTC Distributed Services, use the modified license.dat at step one with node locked lic method. then
Put prods-patch.exe under directory :
<Installed location>\ptc_distributed_services\     then apply it.
crack.zip
91.73 KB, 下载次数: 11
proeWildfire 5.0
本站为非营利性站点,部分资源为网友搜集或发布,仅供学习和研究使用,如用于商业用途,请购买正版。站内所发布的资源,如有侵犯你的权益,请联系我们,本站将立即改正或删除。
QQ|手机版|小黑屋|野火论坛(©2007~2024) ( 苏ICP备11036728号-2 )苏公网安备 32039102000103号
GMT+8, 2024-6-23 11:03 , Processed in 0.100440 second(s), 34 queries .
