查看: 7103|回复: 5
[求助] 安装好creo 2.0后用SSQ打补丁时报错了
发表于 2015-3-9 14:57 | 显示全部楼层 |阅读模式
安装好creo 2.0后用SSQ打补丁时报错了 ,如下。求解决方案~~~~
File E:\Program Files\PTC\Creo 2.0\Common Files\M010\i486_nt\obj\cpu_id.exe NOT patched - check if you already patched it?
File E:\Program Files\PTC\Creo 2.0\Common Files\M010\i486_nt\obj\dsq.exe NOT patched - check if you already patched it?
File E:\Program Files\PTC\Creo 2.0\Common Files\M010\i486_nt\obj\plpf_status.exe NOT patched - check if you already patched it?
File E:\Program Files\PTC\Creo 2.0\Common Files\M010\i486_nt\obj\protk_unlock.exe NOT patched - check if you already patched it?
File E:\Program Files\PTC\Creo 2.0\Common Files\M010\i486_nt\obj\xtop.exe NOT patched - check if you already patched it?
File E:\Program Files\PTC\Creo 2.0\Common Files\M010\mech\i486_nt\bin\mdb2mnf.exe NOT patched - check if you already patched it?
File E:\Program Files\PTC\Creo 2.0\Common Files\M010\mech\i486_nt\bin\mnf2mdb.exe NOT patched - check if you already patched it?
File E:\Program Files\PTC\Creo 2.0\Common Files\M010\mech\i486_nt\bin\msengine.exe NOT patched - check if you already patched it?
File E:\Program Files\PTC\Creo 2.0\Common Files\M010\mech\i486_nt\bin\showlic.exe NOT patched - check if you already patched it?
File E:\Program Files\PTC\Creo 2.0\Common Files\M010\mech\i486_nt\ptc\ptcxfce.exe NOT patched - check if you already patched it?
118
发表于 2015-3-9 16:42 | 显示全部楼层
右键管理员权限打开SSQ,look up安装目录
最后看到patch done即可
creo 11.0
发表于 2015-3-9 21:49 | 显示全部楼层
check if you already patched it? 检查是否已经破解,也可以检查下
发表于 2015-7-22 18:18 | 显示全部楼层
楼主,最后问题如何解决的啊??我装3.0也是这样的情况
发表于 2015-7-22 18:19 | 显示全部楼层
最后看到patch done即可
我也是这样的情况,按您这样的操作还是解决不了,还有什么办法吗??
发表于 2016-6-19 02:18 | 显示全部楼层
同样的问题,不知道有没有什什么解决办法
GMT+8, 2025-4-18 12:05 , Processed in 0.120663 second(s), 23 queries .
