查看: 14608|回复: 3
[求助] creo2.0怎么设置取消隐藏的快捷键,我设置了几次都没成功
发表于 2014-9-5 21:48 | 显示全部楼层 |阅读模式
一,creo2.0怎么设置取消隐藏的快捷键,我设置了几次都没成功
二,creo2.0在装配中打开某个零件的快捷键怎么设置?
请教各位大侠
热心助人勋章优秀会员勋章希望之星勋章嘉宾勋章
发表于 2014-9-6 06:32 | 显示全部楼层
在组件模式中去设置取消隐藏快捷键的录制,打开零件也一样
发表于 2014-9-6 09:25 | 显示全部楼层
1.
mapkey $F2 @MAPKEY_LABELunhide;~ Command `ProCmdViewShow`;
2.
a. cero 2.0 /proe
mapkey dq @MAPKEY_LABELopen;\
mapkey(continued) ~ RButtonArm `main_dlg_cur` `PHTLeft.AssyTree` `node5`;\
mapkey(continued) ~ PopupOver `main_dlg_cur` `ActionMenu`1  `PHTLeft.AssyTree`;\
mapkey(continued) ~ Open `main_dlg_cur` `ActionMenu`;~ Close `main_dlg_cur` `ActionMenu`;\
mapkey(continued) ~ Activate `main_dlg_cur` `OpenModel`;
b. creo 3.0
mapkey(continued) ~ RButtonArm `main_dlg_cur` `PHTLeft.AssyTree` `node19`;\
mapkey(continued) ~ PopupOver `main_dlg_cur` `PM_PHTLeft.AssyTree` 1 `PHTLeft.AssyTree`;\
mapkey(continued) ~ Open `main_dlg_cur` `PM_PHTLeft.AssyTree`;\
mapkey(continued) ~ Trail `UI Desktop` `UI Desktop` `PREVIEW_POPUP_TIMER` \
mapkey(continued) `main_dlg_w1:PHTLeft.AssyTree:<NULL>`;\
mapkey(continued) ~ Close `main_dlg_cur` `PM_PHTLeft.AssyTree`;\
mapkey(continued) ~ Command `ProCmdOpenModel@PopupMenuTree`;
发表于 2014-9-6 09:26 | 显示全部楼层
以上使用组件模式下
GMT+8, 2025-3-6 21:25 , Processed in 0.134926 second(s), 22 queries .
