楼主: 野火
[原创] 安装PRO/E许可证服务器不能启动需要注意的问题
发表于 2008-2-2 14:30 | 显示全部楼层
我的是这样的:13:25:49 (lmgrd) -----------------------------------------------
13:25:49 (lmgrd)   Please Note:
13:25:49 (lmgrd)
13:25:49 (lmgrd)   This log is intended for debug purposes only.
13:25:49 (lmgrd)   In order to capture accurate license
13:25:49 (lmgrd)   usage data into an organized repository,
13:25:49 (lmgrd)   please enable report logging. Use Macrovision's
13:25:49 (lmgrd)   software license administration  solution,
13:25:49 (lmgrd)   FLEXnet Manager, to  readily gain visibility
13:25:49 (lmgrd)   into license usage data and to create
13:25:49 (lmgrd)   insightful reports on critical information like
13:25:49 (lmgrd)   license availability and usage. FLEXnet Manager
13:25:49 (lmgrd)   can be fully automated to run these reports on
13:25:49 (lmgrd)   schedule and can be used to track license
13:25:49 (lmgrd)   servers and usage across a heterogeneous
13:25:49 (lmgrd)   network of servers including Windows NT, Linux
13:25:49 (lmgrd)   and UNIX. Contact Macrovision at
13:25:49 (lmgrd)   www.macrovision.com for more details on how to
13:25:49 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
13:25:49 (lmgrd)   for your enterprise.
13:25:49 (lmgrd)
13:25:49 (lmgrd)
13:25:49 (lmgrd)
13:25:49 (lmgrd) pid 2436
13:25:49 (lmgrd) Detecting other license server manager (lmgrd) processes...
13:25:50 (lmgrd) Done rereading
13:25:50 (lmgrd) FLEXnet Licensing (v10.8.0.7 build 26147) started on cd (IBM PC) (2/2/2008)
13:25:50 (lmgrd) Copyright (c) 1988-2006 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved.
13:25:50 (lmgrd) US Patents 5,390,297 and 5,671,412.
13:25:50 (lmgrd) World Wide Web:  http://www.macrovision.com
13:25:50 (lmgrd) License file(s): D:\Program Files\flexnet\licensing\license.dat
13:25:50 (lmgrd) lmgrd tcp-port 27000
13:25:50 (lmgrd) Starting vendor daemons ...
13:25:50 (lmgrd) Started ptc_d (pid 3264)
13:25:50 (ptc_d) FLEXnet Licensing version v10.8.0.7 build 26147
13:25:50 (ptc_d) Using options file: "D:\Program Files\flexnet\licensing\ptc.opt"
13:25:50 (ptc_d) Server started on cd for:        PROE_200
13:25:50 (ptc_d) 2DGS-OA_200        ANIMATOR_200        CDM_200
13:25:50 (ptc_d) CDRSRENDER_200        CONCEPT_200        DESIGNER_200
13:25:50 (ptc_d) DS_MANAGER_200        DS_SERVICE_200        FLYTHRU_200
13:25:50 (ptc_d) ICEMAFFS_200        ICEMCADDS_200        ICEMCATIA_200
13:25:50 (ptc_d) ICEMDXF_200        ICEMFFS_200        ICEMIGES_200
13:25:50 (ptc_d) ICEMPLOTSRV_200 ICEMSURF_200        ICEMUG_200
13:25:50 (ptc_d) ICEMVDA_200        ILINK_CLIENT_200 ILINK_TK_ACCESS_200
13:25:50 (ptc_d) ILINK_WEBCLIENT_200 MECBASICENG_200 MECBASICUI_200
13:25:50 (ptc_d) MECEQRUN_200        MECIQRUN_200        MECINTERFCE_200
13:25:50 (ptc_d) MECMOTENG_200        MECMOTUI_200        MECSTRUCENG_200
13:25:50 (ptc_d) MECSTRUCUI_200        MECTHERMENG_200 MECTHERMUI_200
13:25:50 (ptc_d) MECTIREMOD_200        MECUG_200        MOCKUPCONVERTER_200
13:25:50 (ptc_d) MOCKUP_200        MODELVIEW_200        NCPOST_200
13:25:50 (ptc_d) PAINT_200        PDM_200                PROETRAIN_200
13:25:50 (ptc_d) PVIEW_200        REFLEX_200        RSDESIGNER_200
13:25:50 (ptc_d) SSILINKCLIENT_200 TMSINDA_200        VERICUT_200
13:25:50 (ptc_d) WEBPUBLISH_200        10101                10102
13:25:50 (ptc_d) 10103                10104                10105
13:25:50 (ptc_d) 10106                10107                10108
13:25:50 (ptc_d) 10109                10110                10111
13:25:50 (ptc_d) 10112                10113                10114
13:25:50 (ptc_d) 10115                10116                10117
13:25:50 (ptc_d) 10118                10119                10120
13:25:50 (ptc_d) 10121                10122                10123
13:25:50 (ptc_d) 10124                EAS_200                EDACONDUIT_200
13:25:50 (ptc_d) EDACONNECTOR_200 FLYPLUGIN_200        FLYVIEWER_200
13:25:50 (ptc_d) INTERCOMM_200        JLINK_200        PROPACKENG_200
13:25:50 (ptc_d) PROPACKUI_200
13:25:50 (ptc_d) ALL FEATURES: INACTIVITY TIMEOUT set to 7200 seconds
13:25:50 (ptc_d) Report log started (+D:\Program Files\flexnet\licensing\ptcreport.log).
13:25:50 (lmgrd) ptc_d using TCP-port 3268
13:46:34 (ptc_d) TCP_NODELAY NOT enabled
发表于 2008-2-3 12:42 | 显示全部楼层
楼主真好,谢谢帮助,问题解决了
发表于 2008-2-29 11:06 | 显示全部楼层
呵呵 一语道破天机啊  谢谢老大了 我说怎么安装不了呢
发表于 2008-3-14 16:42 | 显示全部楼层
哦, 记下了
发表于 2008-3-16 16:04 | 显示全部楼层
问题还是解决不了
发表于 2008-3-16 16:22 | 显示全部楼层
好贴子
发表于 2008-3-29 16:28 | 显示全部楼层
景仰
老大真是辛苦了。
发表于 2008-4-2 21:21 | 显示全部楼层
现在才看到啊!这个好啊,我就是这个情况
发表于 2008-4-3 10:32 | 显示全部楼层
确保把 __HOSTNAME__ 替换为你的主机名称,包括下划线。
我上次错就错在这个地方。
发表于 2008-4-9 12:42 | 显示全部楼层
VISTA下没装过PROE,应该可以安装
GMT+8, 2024-11-22 16:43 , Processed in 0.151045 second(s), 26 queries .
