KeyShot 4.2.35 新功能:- Regrouping - create new groups, drag and drop parts and subassemblies from one group to another. CAUTION: This may limit or even completely disable live linking.
- Transparency slider for Toon material - solid faces can be made transparent while the outline stays opaque.
- Swap material on selected parts (scene tree) - quickly switch a number of parts or and entire assembly to adopt a certain material using the color and possibly other materials of the currently assigned material.
- Update materials in the in-project library - Materials and colors in the in-project material library can now be update by dragging and dropping a material directly onto material in the in-project library.
- Select parts by material with multiple materials selected.
- In-project material library is back in the scene tree and material project tab.
- Axalta (DuPont) color tweaker - this is for the paint expert allowing them to tweak the 9 parameters of the Axalta paint. This is only a delta of the existing value and is happening all numerically. This is in order to protect the actual values of the paint for copyright purposes. The color tweaker is definitely a feature for the paint expert.
- Option in Preferences to link materials of duplicate models/parts
- Dynamic sliders throughout the system - typing in a number in the numbers field will make this value the new mid point of the slider.
- Faster object highlight - a new algorithm for significantly faster object highlight in the realtime window.
- Better accessibility to move tool - the move tool is now painted thicker, and as such easier to grab. When a certain direction is selected, only this arrow/circle is highlighted.
- Autoscroll in the scene tree when moving parts and animations through a long list of parts.
- More presets for image aspect ratio - with the presets of actual aspect ratios found in print and digital media users no longer have to do the math themselves.
- Maintain aspect ratio for cylindrical mapping better - while not yet perfect the label or texture is much closer to its original size when using cylindrical or spherical mapping.
- Copy region in HDRIs - you can now copy areas of an HDRI and place them as pins in the HDRI.
- Improved SW importer - the BETA importer (default on Mac) is getting more robust with the latest build.
- Support for Autodesk Inventor 2014
- New ALIAS import option by OBJECT - You can now import ALIAS files using a third option called "Object". This will allow the user to import the file in their original structure. This may only be useful in certain cases, but at least it is an option now.
- Faster realtime render mode - the realtime render mode (max time / max samples) has been significantly improved and delivers much better results in shorter amount of time.
- Dynamic pivot point for animations - it is now possible to create animations with parts that have moving pivot points which are being used by other parts in the animation.
- Respect order of animations - the order of animations now matters. The order can be changed by dragging and dropping animation into their new place inside the scene tree.
- Animation - Selection of helper object in the realtime window.
- Ability to set # of cores used by KeyShot - inside the preferences, the user can now determine how many cores should be used by KeyShot. The minimum setting is 4.
- Ability to save revisions of a scene - rather than overwriting each scene with users can now save revisions of the same scene which can then be accessed from within KeyShot
- Set a dark color theme - similar to what we had in KeyShot 2, you can now set a dark color theme if you don't want to use the default lighter one.
- Many bug fixes
完整版安装包:
Windows 32位:
http://download.keyshot.com/keyshot_w32_4.2.35.exe
Windows 64位:
http://download.keyshot.com/keyshot_w64_4.2.35.exe
Mac OS X(这是苹果系统的,没破解):
http://download.keyshot.com/keyshot_mac64_4.2.35.pkg
升级安装包(适用于已经安装了4.1的用户,装完整版4.2的不用下载):
Windows 32位:
http://download.keyshot.com/keyshot_w32_4.2.35_update.exe
Windows 64位:
http://download.keyshot.com/keyshot_w64_4.2.35_update.exe
http://download.keyshot.com/keyshot_mac64_4.2.35_update.pkg |
