楼主: fjs2008
[分享] 百度网盘分享:PTC Creo Elements/Pro 5.0 M200 32&64位
 火... [复制链接]
发表于 2013-11-15 18:41 | 显示全部楼层
PTC Creo 1.0 (2.0) Mxxx 32/64bit patcher (by SSQ)
1.  Open ptc_licfile.dat with any txt-editor and replace every occurrence of 00-00-00-00-00-00 with you network
card MAC-address (shown in the bottom left corner of the Creo setup)
2.  Install Creo 1.0 (2.0) Mxxx 32/64bit (Parametric, Direct, Simulate, Distributed Services Manager) using
ptc_licfile.dat as node-locked license (no Server running)
3.  Run PTC_Creo_Patcher_SSQ.exe
ATTENTION!  On Vista/Win7 you mast run it as Administrator! (right mouse click > run as Administrator)
4.  Click Look For..
5.  For Creo Parametric, Direct or Simulate browse to <Creo 1.0 (2.0) Mxxx root directory>
(by default C:\Program Files\PTC\Creo 1.0(2.0)\Common Files\Mxxx\) and click Look For..
6.  Be sure that you’ve got a right path in Program Directory tab Click Start
7.  Wait for window All files seem to be patched. Enjoy! Click OK
8.  For Creo  Distributed Services Manager browse to <Creo 1.0 (2.0) Distributed Services Manager root directory>
(by default C:\Program Files\PTC\Creo 1.0(2.0)\Creo Distributed Services Manager \) and click Look For..
9.  Be sure that you’ve got a right path in Program Directory tab Click Start
10. Wait for window All files seem to be patched. Enjoy! Click OK
That’s all… Enjoy!
Team-SolidSQUAD (SSQ)
发表于 2013-11-15 19:28 | 显示全部楼层
谢谢,下载收了
发表于 2013-11-15 21:02 | 显示全部楼层
感谢分享,果断转存,有时间下载个!
发表于 2013-11-16 01:01 | 显示全部楼层
回复看提起吗
发表于 2013-11-16 08:51 | 显示全部楼层
为什么百度网盘每次下载到一半左右时会重新下载呢??是上传的文件有问题还是网盘的问题啊??
发表于 2013-11-16 10:12 | 显示全部楼层
我要快来下载啰
发表于 2013-11-16 14:20 | 显示全部楼层
谢谢LZ
发表于 2013-11-16 14:29 | 显示全部楼层
发表于 2013-11-16 15:19 | 显示全部楼层
谢谢热心分享,下载了
发表于 2013-11-16 19:02 | 显示全部楼层
谢谢啦!辛苦斑竹咯
GMT+8, 2025-4-21 16:23 , Processed in 0.132006 second(s), 28 queries .
