经过精心研究,终于安装成功了,而且也成功的安装了proe/m。经过测试,有限元求解一切正常(见图)。现将安装经验贴出来,将顶楼英文说明翻译了过来,而且还进行了补充。是中英文对照。希望对大家有所贡献。详细内容如下:
.start pro/e setup
运行pro/e setup,记下主画面左下角的网卡ID:xx-xx-xx-xx-xx(字母要大写,保留横杠)
.open ptc_licfile.dat with your fav txt-editor
编辑ptc_licfile.dat
.replace every occurance of <HOSTID> with the one shown in the bottom left corner of the Pro/e setup
(its your mac-id, format: xx-xx-xx-xx-xx)
用网卡ID:xx-xx-xx-xx-xx替换文件中所有的<HOSTID>,(xx-xx-xx-xx-xx替换<HOSTID>)并保存这个文件。
.install pro/e - pro/m - pro/ds, i dont care which one or in which order
安装pro/e - pro/m - pro/ds,安装顺序无关。
.on license-config screen select "nodelocked license" and point to edited ptc_licfile.dat
(注意,这是关键点)运行到选择服务器时,选择锁定服务器项,然后指定上面编辑保存的文件。
.blalala install
继续安装。
next for pro/engineer:
接着破解pro/engineer:
(if u didnt install the complete package, u get "missing file" errors, accept or bleed)
.run ptc.pro engineer.wildfire.3.0.m060-patch.exe, point to <installdir>\i486_nt\obj folder
复制ptc.pro engineer.wildfire.3.0.m060-patch.exe到安装目录\i486_nt\obj\下并运行。出现寻找文件时选择否。
.edit <pro/e installdir>\bin\proev.bat
编辑proe安装目录\bin\ptcsetup.bat文件。
change "%start_cmd% "%CGTECH_JRE%\bin\javaw" -Xms16m -Xmx64m -Xss4m -classpath "%CGTECH_CLASSES%;%CGTECH_CLASSES%\CGTech.jar" Vericut %argstr%" in
"%start_cmd% "%CGTECH_JRE%\bin\javaw" -Xms16m -Xmx64m -Xss4m -classpath "%CGTECH_CLASSES%;%CGTECH_CLASSES%\CGTech.jar" Vericut %argstr% PTC_KEY=0"
(add PTC_KEY=0)
更改 set start_cmd=start ""
为"%start_cmd% "%CGTECH_JRE%\bin\javaw" -Xms16m -Xmx64m -Xss4m -classpath "%CGTECH_CLASSES%;%CGTECH_CLASSES%\CGTech.jar" Vericut %argstr% PTC_KEY=0"
pro/mechanica:
接着破解pro/mechanica:
.run ptc.pro mechanica.wildfire.3.0.m060-patch.exe
复制ptc.pro mechanica.wildfire.3.0.m060-patch.exe到安装目录\i486_nt\bin下并运行。 在这个目录和下面的目录里找到提示的文件。细心的找,都能找到。
<pro/m installdir>\i486_nt\obj
<pro/m installdir>\i486_nt\ptc
我安装到此已经成功了,至于proe跟prom的连接我就不用介绍了吧。
(in this order, after every "missing file" error)
pro/distributed services:
.run ptc.distributed.services.m060-patch.exe and point to <pro/ds installdir>\i486_nt\obj
Have Fun Team SHooTERS !!!! |
