查看: 127892|回复: 597
[分享] 野火4.0新增加的读入外部数据特征识别工具
嘉宾勋章热心助人勋章优秀会员勋章
发表于 2008-1-7 13:54 | 显示全部楼层 |阅读模式
野火4.0新增加的读入外部数据的特征识别功能,也可以理解为重新参数化,比如IGS或者STEP读入的数据部分特征都可以再进行参数化,目前这个功能在4.0的测试版本里面是采用浮动模块方式加载的,类似于EMX的加载方式,是在PTC公司网站下载的,为了安装简单方便,我自己重新做成安装包,PTC原始的使用方法是手动添加到相应文件夹,然后再手动添加变量等等(见后面的英文说明).感觉比较麻烦,我就自己动手做了这个安装包,重新打包后的安装方法完全同EMX一样.
这是PTC公司的介绍说明:
Feature Recognition Tool Installation Instructions
The Feature Recognition Tool (FRT) is available for download from PTC’s free downloads page (http://www.ptc.com/community/free_downloads.htm).  It is written for 32 bit Windows platforms only.
The tool is configured by default to operate from the Pro/ENGINEER startup directory.  However this is generally a volatile location and the plug-in should be maintained in a safer location.
1.  Extract the FRT zip file contents to a desired safe location (i.e. c:\ptc\frt).
2.  Add the ‘toolkit_registry_file’ config.pro option and give it the path and file name to the frt.dat file (i.e. toolkit_registry_file c:\ptc\frt\frt.dat).
3.  Edit frt.dat and add the full path to the pt_feat_recgn.dll file (exec_file) and the full path to the text directory (text_dir).
Example:
name   feat_recgn_dll
startup dll
exec_file C: \ptc\frt\pt_feat_recgn.dll
text_dir C: \ptc\frt\text
allow_stop true
delay_start false
end
4.  Copy the config.win file to one of the following locations:
a.        < Pro/E loadpoint>/text/
b.        <Home directory> (usually C:\ unless set by the HOME environment variable)
c.        Startup working directory
5.  Start or restart Pro/ENGINEER Wildfire 4.0.
The FRT icons should appear in part mode.  If not, ensure the config.win file extracted from the zip file is the latest version in your startup working directory.
Quick Installation Instructions
It isn’t proper or clean, but it will work.
1.  Extract the contents of the zip file into the Pro/ENGINEER startup directory.
2.  Start or restart Pro/ENGINEER.
下载地址:
游客,如果您要查看本帖隐藏内容请回复
[ 本帖最后由 hycad 于 2008-1-9 07:52 编辑 ]
参与人数 1威望 +3 金钱 +10 收起 理由
野火 + 3 + 10 原创内容
发表于 2008-1-7 20:16 | 显示全部楼层
谢谢 hycad,这个还没用过,有空了要试下,文件已上传到网盘,连接已增加到 1楼。
发表于 2008-1-8 08:22 | 显示全部楼层
好东西啊!
发表于 2008-1-8 20:05 | 显示全部楼层
靠,这么厉害。。一定要看下
一直对4的更新不清楚呢,绝好的机会研究研究
谢谢啦
发表于 2008-1-9 18:41 | 显示全部楼层
4.0有這個功能?展開模型樹後可以看見特征嗎?
发表于 2008-1-19 19:39 | 显示全部楼层
好东西啊,正愁没地方下呢?
发表于 2008-1-19 20:06 | 显示全部楼层
靠,这么厉害。。一定要看下
谢谢啦
发表于 2008-1-19 20:24 | 显示全部楼层
有没有用,看看
有没有用,看看
发表于 2008-1-19 20:30 | 显示全部楼层
有没有用,看看
GMT+8, 2025-2-28 09:42 , Processed in 0.148308 second(s), 23 queries .
