查看: 6249|回复: 5
[求助] 求ProENGINEER Progressive Die Extension (PDX) R5.0 F000 (级进模设计)安装方法?
发表于 2008-8-31 15:08 | 显示全部楼层 |阅读模式
我有原文安装方法如下,但是,启动PRO/E时显示
无效LICENSE,求解决办法
PTC Progressive Die Extension Release 5.0 F000
Notice: This release is Pro/ENGINEER Wildfire 3.0 and Wildfire 4.0 compatible.
        Of couse it also can be used for Pro/ENGINEER 2001/Wildfire/Wildfire2.0
http://www.ptc.com/appserver/wcm ... 8&icg_dbkey=826
Easy and faster creation of custom components for PDX. Also eliminates errors due to syntax problems associated with creating custom components manually.
Users are lead thru the creation of custom components and are asked to provide images to make component identification simpler. This is the latest Rlease 5.0 F000 verison.
It's wildfire 3.0 and wildfire 4.0 compatible.
Installation:
As an extension pack of Pro/ENGINEER, You should install Pro/ENGINEER WILdFRE3.0 or Pro/ENGINEER Wildfire 4.0 before you install the PDX R5.0 F000 extension pack of pro/E and ensure your pro/e license includes the #208 feature< Feature Progressive_Die(208)> of pro/e. Of course, prior to released license gen of Pro/e by us includes the feature.
If you have installed pro/e and the license supported the #208 feature,Here we go.
Run setup, choose all installation options and the right language which you need and choose an installing location, e.g. C:\ptc\pdxRelease 5.0 , then Press Next button till finish.
then:
1. Modify the PDX config.pro file:
Open C:\ptc\pdxRelease 5.0\text\config.pro and modify the following line as per your actual PDX R5.0 installed location:
protkdat _LOADPOINT_\text\protk.dat
here I modify it like this(Instead of  _LOADPOINT_ with your actual installed location)
protkdat C:\ptc\pdxRelease 5.0\text\protk.dat
   then save the modified Config.pro
2. Modify the registry file protk.dat :
Open C:\ptc\pdxRelease 5.0\text\protk.dat and modify the following line as per your actual pro/e version installed:
   exec_file C:\ptc\pdxRelease 5.0\$PRO_MACHINE_TYPE\pdx50.dll
   If you wanna install this PDX R5.0 on pro/e 20/2000i/2001 please skip this step and keep it no any change
   If you wanna install this PDX R5.0 on pro/e wildfire/wildfire 2.0,please  modify this line like this:
   exec_file C:\ptc\pdxRelease 5.0\$PRO_MACHINE_TYPE\pdx50_wildfire2.dll
        then save the protk.dat file.
   If you wanna install this PDX R5.0  on pro/e wildfire 3.0 and wildfire 4.0 ,please  modify this line like this:
   exec_file C:\ptc\pdxRelease 5.0\$PRO_MACHINE_TYPE\pdx50_wildfire4.dll
3.Let pro/e load the PDX R5.0 extension when start
You can use the following any approaches to hook the PDX extension onto pro/e
Method 1) copy the modified Config.pro which you got at step 1 into this folder:
    <proe installed location>\text
Method 2) Append the modified config.pro contents into yourself config.pro file you currently used.
Method 3) copy the modified Config.pro which you got at step 1 into your HOME directory.
Method 4) copy the modified Config.pro which you got at step 1 into your working directory.
4. Add PDX R5.0 icon onto Pro/E UI:
copy
C:\ptc\pdxRelease 5.0\text\config.win
to anyone of the 3 kinds of directories that method 2,3,4 mentioned at step 3.
That's all.
Enjoy this fine release!
Team LND 2008
Team MAGNITUDE 2008
141
优秀斑竹勋章宣传大使勋章斑竹勋章希望之星勋章
发表于 2008-8-31 19:21 | 显示全部楼层
自己多搜索一下论坛吧,一般好多问题都有教程讲解///主动点//
http://www.proewildfire.cn/thread-6383-1-1.html
 楼主| 发表于 2008-9-1 00:45 | 显示全部楼层
原帖由 zmorphis 于 2008-8-31 19:21 发表
你自己看看你回答的是不是我想要的?
发表于 2009-11-25 14:14 | 显示全部楼层
谢谢,。。。。。。。。。。。。。。。
发表于 2010-4-21 18:21 | 显示全部楼层
谢谢,怎样可以下载呀??????
发表于 2011-9-7 15:08 | 显示全部楼层
谢谢,。。。。。。。。。。。。。。。
GMT+8, 2024-11-20 06:26 , Processed in 0.125837 second(s), 28 queries .
