查看: 59067|回复: 6
[已解决] proe常用的快捷键
发表于 2007-12-30 00:06 | 显示全部楼层 |阅读模式
悬赏1金钱已解决
我刚学proe,想知道一些关于pore的快捷键.比如:Ctrl+D是标准方向的立做图.
最佳答案
查看完整内容
[/td][/tr][/table] [/td][/tr][/table] 请复制以下内容增加到你的 config.pro 文件末尾,包含的快截键内容如上表格所列
1275
  Views
vd View Default 默认视图显示
vf View Front主视图显示
zwZoom Window窗口放大显示
zsZoom Out缩小显示
zfZoom Fit最佳大小显示
rg Regen重新计算生成
re Repaint重画屏幕
sd Shade按实体显示
wc Window Close关闭窗口
  Start _Files
gr Get Start Part新建零件
gaGet Start Assembly新建装配
gdGet Drawing新建工程图
  Redefine and Info Mapkeys
fr Feature Redefine重定义特征
fs Feature Suppress抑制特征
fd Feature Delete删除特征
fe Feature Resume恢复特征
fm Feature Modify修改特征
fi Feature Information特征信息
  1. !#################### MAPKEYS ####################
  2. ! The mapkeys included have been created to automate standard functions.
  3. ! Review the mapkeys listed below and delete ones that you will not use.
  4. ! Create mapkeys to automate functions you will do frequently.
  5. !#################### VIEWS ####################
  6. mapkey vd @MAPKEY_NAMEView Default Orientation of Model;\
  7. mapkey(continued) @MAPKEY_LABELView Default;\
  8. mapkey(continued) ~ Activate `main_dlg_cur` `ProCmdViewNamePick.view`1 ;\
  9. mapkey(continued) ~ Select `nameviewlist` `nv_list`1 `Default`;
  10. mapkey vf @MAPKEY_NAMEView Front;@MAPKEY_LABELFront;\
  11. mapkey(continued) ~ Activate `main_dlg_cur` `ProCmdViewNamePick.view`1 ;\
  12. mapkey(continued) ~ Select `nameviewlist` `nv_list`1  `FRONT`;
  13. mapkey zw @MAPKEY_LABELzoom window;\
  14. mapkey(continued) ~ Activate `main_dlg_cur` `ProCmdViewZoomIn.view`;
  15. mapkey wc @MAPKEY_NAMEWindow Close;@MAPKEY_LABELwc;\
  16. mapkey(continued) ~ Select `main_dlg_cur` `MenuBar1`1  `Windows`;\
  17. mapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;\
  18. mapkey(continued) ~ Activate `main_dlg_cur` `Windows.psh_win_close`;
  19. mapkey zs @MAPKEY_LABELZoom Out;\
  20. mapkey(continued) ~ Activate `main_dlg_cur` `ProCmdViewZoomOut.view`;
  21. mapkey zf @MAPKEY_NAMEView Refit;@MAPKEY_LABELRefit;\
  22. mapkey(continued) ~ Activate `main_dlg_cur` `ProCmdViewRefit.view`;
  23. mapkey rg @MAPKEY_NAMERegenerate Model;@MAPKEY_LABELRegen;#DONE;#DONE/RETURN;\
  24. mapkey(continued) ~#DONE/RETURN;#REGENERATE;#MODEL;#AUTOMATIC;
  25. mapkey re @MAPKEY_NAMERepaint Screen;@MAPKEY_LABELRepaint;\
  26. mapkey(continued) ~ Select `main_dlg_cur` `MenuBar1`1 `View`;~ Close `main_dlg_cur` `MenuBar1`;\
  27. mapkey(continued) ~ Activate `main_dlg_cur` `View.psh_view_repaint`;
  28. mapkey sd @MAPKEY_NAMEShade Model;@MAPKEY_LABELShade;\
  29. mapkey(continued) ~ Select `main_dlg_cur` `MenuBar1`1 `View`;~ Close `main_dlg_cur` `MenuBar1`;\
  30. mapkey(continued) ~ Activate `main_dlg_cur` `View.psh_view_shade`;
  31. !#################### MODIFY/MEASURE == Updated for R.20  ####################
  32. mapkey fr @MAPKEY_NAMERedefine;@MAPKEY_LABELRedefine;#FEATURE;#REDEFINE;
  33. mapkey fs @MAPKEY_NAMEFeature Suppress\n\n\nFeature Suppress\n;\
  34. mapkey(continued) @MAPKEY_LABELSuppress;#FEATURE;#SUPPRESS;
  35. mapkey fd @MAPKEY_NAMEFeature Delete;@MAPKEY_LABELDelete;#FEATURE;#DELETE;
  36. mapkey fe @MAPKEY_NAMEFeature Resume;@MAPKEY_LABELResume;#FEATURE;#RESUME;
  37. mapkey fm @MAPKEY_NAMEFeature Modify;@MAPKEY_LABELModify;#DONE;#MODIFY;
  38. mapkey fi @MAPKEY_NAMEFeature Information;@MAPKEY_LABELFea Info;\
  39. mapkey(continued) ~ Select `main_dlg_cur` `MenuBar1`1 `Info`;~ Close `main_dlg_cur` `MenuBar1`;\
  40. mapkey(continued) ~ Activate `main_dlg_cur` `Info.psh_info_feature`;
  41. !##################### Start Files ##############################
  42. mapkey gr @MAPKEY_LABELNew Part;\
  43. mapkey(continued) ~ Activate `main_dlg_cur` `ProCmdModelNew.file`;\
  44. mapkey(continued) ~ Input `new` `InputPanel1` ``;~ Update `new` `InputPanel1` ``;;
  45. mapkey ga @MAPKEY_LABELNew Assembly;\
  46. mapkey(continued) ~ Activate `main_dlg_cur` `ProCmdModelNew.file`;\
  47. mapkey(continued) ~ Select `new` `Type`1  `Assembly`;~ Input `new` `InputPanel1` ``;\
  48. mapkey(continued) ~ Update `new` `InputPanel1` ``;;
  49. mapkey gd @MAPKEY_LABELNew Drawing;\
  50. mapkey(continued) ~ Activate `main_dlg_cur` `ProCmdModelNew.file`;\
  51. mapkey(continued) ~ Select `new` `Type`1  `Drawing`;~ Input `new` `InputPanel1` ``;\
  52. mapkey(continued) ~ Update `new` `InputPanel1` ``;;
  53. !##################### END ##############################
复制代码
热心助人勋章宣传大使勋章斑竹勋章
发表于 2007-12-30 00:25 | 显示全部楼层
快捷键可以自己设置的 tools →mapkeys
发表于 2007-12-31 10:56 | 显示全部楼层
谢谢
受用了
 楼主| 发表于 2007-12-31 11:40 | 显示全部楼层
config.pro 在哪.
请复制以下内容增加到你的 config.pro 文件末尾,不会用.
 楼主| 发表于 2007-12-31 23:32 | 显示全部楼层
找到了
原来在文件保存目录.
发表于 2008-1-1 09:28 | 显示全部楼层
弄好了请结贴, 选择最佳答案.
GMT+8, 2025-4-19 13:28 , Processed in 0.116886 second(s), 26 queries .
