查看: 7290|回复: 3
[已解决] 为啥我做的二次开发程序到PROE中点击按钮选择相应东东就直接退出PROE呢
发表于 2012-7-17 10:08 | 显示全部楼层 |阅读模式
如题:
代码如下
ProError  UsrMenuAction ()
        ProError status;
        int n_sel=0;
        ProSelection *sel;
        ProModelitem feature;
        status=ProSelect("surface",1,NULL,NULL,NULL,NULL,&sel,&n_sel);
        if(status!=PRO_TK_NO_ERROR||n_sel<0)
                return(PRO_TK_USER_ABORT);
        status=ProSelectionModelitemGet(*sel,&feature);
        if (status==PRO_TK_NO_ERROR)
                ProName msg_file;
                ProStringToWstring(msg_file,"Information.txt");
                ProMessageDisplay(msg_file,"USER sel item id is:%0d",feature.id);
        return(PRO_TK_NO_ERROR);
30
发表于 2012-7-17 10:58 | 显示全部楼层
顶一下,太深奥了,看不懂!
 楼主| 发表于 2012-7-17 11:22 | 显示全部楼层
#define PRO_USE_VAR_ARGS 1
Pro/Toolkit includes
#include <stdio.h>
#include "process.h"
#include "stdlib.h"
#include <ProToolkit.h>
#include <ProObjects.h>
#include <ProSolid.h>
#include <ProParameter.h>
#include <ProParamval.h>
#include <ProMdl.h>
#include <ProModelitem.h>
#include <ProDimension.h>
#include <ProMenuBar.h>
#include <ProMessage.h>
#include <ProUtil.h>
#include <ProFeature.h>
#include <ProFeatType.h>
#include <prodgmstruc.h>
//add by hxl 20120516
#include <ProCabling.h>
//add by hxl 20120521
#include <ProMdl.h>
#include <ProDtmPnt.h>
Application includes
#include <TestError.h>
#include <TestParams.h>
#include <ProWstring.h>
#include <ProSelection.h>
typedef enum
  Usr_MODIFY_PARAMETER=1,
  Usr_MODIFY_DIMENSION
} UsrChoice;
typedef struct
        UsrChoice option;
    ProName name;
        double value;
} UsrParam;
int UsrCreatePnt(double OFST_CSYS_X_VAL
                                 ,double OFST_CSYS_Y_VAL
                                 ,double OFST_CSYS_Z_VAL);
void UsrElemtreeElementAdd(ProElemId id
                                                   ,ProElement parent
                                                   ,void* value
                                                   ,ProValueDataType type
                                                   ,ProElement* element);
static ProError status;
FUNCTION: UsrMenuAction
PURPOSE:  Menu button action function for exercise 9
        ProError status;
        int n_sel=0;
        ProSelection *sel;
                ProName msg_file;
        ProMdl cur_mdl;
        ProName name;
        ProModelitem cur_mdlit;
        ProSelection  ref_csys;
        ProElement elem_tree,element,elem_ayyay,elem_const;
        double dvalue;
        ProSolid solid;
        ProModelitem model_modelitem;
        ProSelection mdl_sel;
        ProFeature feature;
        ProErrorlist errors;
        int ivalue;
        ProElementAlloc(PRO_E_FEATURE_TREE,&elem_tree);
        //PRO_E_FEATURE_TYPE
        ivalue = PRO_FEAT_DATUM_POINT;
        UsrElemtreeElementAdd(PRO_E_FEATURE_TYPE,elem_tree
                ,&ivalue,PRO_VALUE_TYPE_INT,&element);
        //PRO_E_DPOINT_TYPE
        ivalue = PRO_DPOINT_TYPE_OFFSET_CSYS;
        UsrElemtreeElementAdd(PRO_E_DPOINT_TYPE,elem_tree
        ivalue = PRO_DTMPNT_OFFCSYS_CARTESIAN;
        UsrElemtreeElementAdd(PRO_E_DPOINT_OFST_CSYS_TYPE,elem_tree
        //PRO_E_DPOINT_OFST_CSYS_REF
        ProMdlCurrentGet(&cur_mdl);
        ProStringToWstring(name,"PRT_CSYS_DEF");
        ProModelitemByNameInit(cur_mdl,PRO_CSYS,name,&cur_mdlit);
        ProSelectionAlloc(NULL,&cur_mdlit,&ref_csys);
        UsrElemtreeElementAdd(PRO_E_DPOINT_OFST_CSYS_REF,elem_tree
                ,&ref_csys,PRO_VALUE_TYPE_SELECTION,&element);
        ivalue = PRO_B_FALSE;
        UsrElemtreeElementAdd(PRO_E_DPOINT_OFST_CSYS_WITH_DIMS,elem_tree
        //PRO_E_DPOINT_OFST_CSYS_PNTS_ARRAY
        ProElementAlloc(PRO_E_DPOINT_OFST_CSYS_PNTS_ARRAY,&elem_ayyay);
        ProElemtreeElementAdd(elem_tree,NULL,elem_ayyay);
        ProElementAlloc(PRO_E_DTMPLN_CONSTRAINT,&elem_const);
        ProElemtreeElementAdd(elem_ayyay,NULL,elem_const);
        //PRO_E_DPOINT_OFST_CSYS_DIR1_VAL
        dvalue = OFST_CSYS_X_VAL;
        UsrElemtreeElementAdd(PRO_E_DPOINT_OFST_CSYS_DIR1_VAL,elem_const
                ,&dvalue,PRO_VALUE_TYPE_DOUBLE,&element);
        //PRO_E_DPOINT_OFST_CSYS_DIR2_VAL
        dvalue = OFST_CSYS_Y_VAL;
        UsrElemtreeElementAdd(PRO_E_DPOINT_OFST_CSYS_DIR2_VAL,elem_const
        //PRO_E_DPOINT_OFST_CSYS_WITH_DIMS
        dvalue = OFST_CSYS_Z_VAL;
        UsrElemtreeElementAdd(PRO_E_DPOINT_OFST_CSYS_DIR3_VAL,elem_const
        ProMdlCurrentGet((ProMdl*)&solid);
        ProMdlToModelitem(solid,&model_modelitem);
        ProSelectionAlloc(NULL,&model_modelitem,&mdl_sel);
        ProFeatureCreate(mdl_sel,elem_tree,NULL,0,&feature,&errors);
        ProElementFree(&elem_tree);
        ProSelectionFree(&mdl_sel);
        return 1;
        ,ProElement parent
        ,void* value
        ProValueData value_data;
        ProValue pvalue;
        value_data.type = type;
        switch(type)
                case PRO_VALUE_TYPE_INT                :
                        value_data.v.i = *(int*)value;
                        break;
                case PRO_VALUE_TYPE_DOUBLE        :
                        value_data.v.d = *(double*)value;
                        break;
                case PRO_VALUE_TYPE_POINTER        :
                        value_data.v.p = *(void**)value;
                        break;
                case PRO_VALUE_TYPE_STRING        :
                        value_data.v.s = *(char**)value;
                        break;
                case PRO_VALUE_TYPE_WSTRING        :
                        value_data.v.w = *(wchar_t**)value;
                        break;
                case PRO_VALUE_TYPE_SELECTION        :
                        value_data.v.r = *(ProSelection*)value;
                        break;
                case PRO_VALUE_TYPE_TRANSFORM        :
                        value_data.v.t = *(double***)value;
                        break;
                case PRO_VALUE_TYPE_BOOLEAN                :
                        break;
        //设置特征树元素的值
        ProElementAlloc(id,element);
        ProValueAlloc(&pvalue);
        ProValueDataSet(pvalue,&value_data);
        ProElementValueSet(*element,pvalue);
        //将特征元素添加到特征元素树中
        ProElemtreeElementAdd(parent,NULL,*element);
static uiCmdAccessState TestAccessDefault(uiCmdAccessMode access_mode)
    return (ACCESS_AVAILABLE);
    FUNCTION :  user_initialize()
    PURPOSE  :  Pro/TOOLKIT standard initialize - define menus.
int user_initialize (int argc, char* argv [], char* proe_version, char* build_code)
  uiCmdCmdId cmd_id,cmd_id1;
  ProError status;
  ProTestErrlogOpen ("Module9.log", proe_version, build_code);
  status = ProCmdActionAdd ("Exercise9",
                            (uiCmdCmdActFn)UsrMenuAction,
                            uiProe2ndImmediate, TestAccessDefault,
                            PRO_B_TRUE, PRO_B_TRUE, &cmd_id);
  status = ProCmdActionAdd ("Exercise10",
          PRO_B_TRUE, PRO_B_TRUE, &cmd_id1);
  status=ProMenubarMenuAdd ("CHECK", "CHECK","Utilities", PRO_B_TRUE, L"exercise_9.txt");
  status = ProMenubarmenuPushbuttonAdd ("CHECK", "Exercise9", "Exercise9",
                                        "Exercise9", NULL,
                                        PRO_B_TRUE, cmd_id, L"exercise_9.txt");
  ProCmdDesignate(cmd_id,"Exercise9","Exercise9 Help","Exercise9",L"exercise_9.txt");
  ProCmdIconSet(cmd_id,"bolt.gif");
  status = ProMenubarmenuPushbuttonAdd ("CHECK", "Exercise10", "Exercise10",
          "Exercise10", NULL,
          PRO_B_TRUE, cmd_id1, L"exercise_9.txt");
  ProCmdIconSet(cmd_id1,"nut.gif");
  ProCmdDesignate(cmd_id1,"Exercise10","Exercise10 Help","Exercise10",L"exercise_9.txt");
  return (PRO_TK_NO_ERROR);
    FUNCTION :  user_terminate()
    PURPOSE  :  Pro/TOOLKIT standard termination
void user_terminate ()
  ProTestErrlogClose ();
这是完整版的代码 我是新手拿了别人的在上面做了改动  我的目的是选择模型相应的面就能显示出模型面的ID但是选择面之后PROE就自动退出了
主要功能实现的代码在就是之前给出的那个
[ 本帖最后由 wwangyufei 于 2012-7-17 11:24 编辑 ]
 楼主| 发表于 2012-7-19 16:17 | 显示全部楼层
已经解决 啊哈哈
GMT+8, 2025-7-11 07:13 , Processed in 0.136320 second(s), 21 queries .
