楼主: 野火
[原创] PTC Creo 2.0 M010~Mxxx~M240 正式版安装步骤图解教程(Win32&64)
发表于 2015-6-16 16:49 | 显示全部楼层
  我下载的怎么没有,CRACK  文件呢, 那位大哥知道是怎么回事,
发表于 2015-6-20 18:48 | 显示全部楼层
感谢分享,几年后回来没想到还用得着了
发表于 2015-6-20 19:00 | 显示全部楼层
1. Open "ptc_licfile.dat" in text editor and replace 00-00-00-00-00-00 in every string HOSTID=PTC_HOSTID=00-00-00-00-00-00 with your real computer hostid
打开许可文件将网卡改成你自己的,有多个网卡的一起改了保存
2. Copy ptc_license.dat to your computer
将证书文件复制到你最后安装路径
3. Create environment variable PTC_LICENSE_FILE=full path to ptc_license.dat
创建证书的完整有效路径如D:\Program Files\ptc_licfile.dat(第二步的文件路径)
4. Install PTC Creo 2.0 Mxxx. If installer can not see ptc_license.dat on your computer drag-n-drop ptc_license.dat to the "License Summary" field of installer window"
安装CREO,如果路径里没有你的证书文件,那么直接将证书文件拖进添加证书的窗口,这么一说第3步有点多余嘛
5. Install PTC Creo 2.0 Mxxx Distributed Services Manager (optional)
安装PTC Creo的2.0 MXXX分布式服务管理器(可选)
6. Run "PTC_Creo_Patcher_0.1_SSQ.exe" (on Vista/Win7 computers be sure to run it as Administrator).
运行“”(破解文件)vista以上系统以管理员身份运行
Click "Look For..", browse to <Creo 2.0 progdir>\Common Files\Mxxx\ (by default C:\Program Files\PTC\Creo 2.0\Common Files\Mxxx\) and click "Look For.." once again
点击【查找】在<Creo 2.0 progdir>\Common Files\Mxxx\安装路径(默认X:\Program Files\PTC\Creo 2.0\Common Files\Mxxx\),再点击【查找】,再点击【查找】..
Click "Start" and wait for patcher info window "All files seem to be patched. Enjoy!"
点击【开始】等待直至出现所有文件似乎全被破解的窗口
Click "OK"
点击 “完成”
7. If you have installed PTC Creo 2.0 Mxxx Distributed Services Manager
如果,你安装了第五步的分布式服务管理器
Click "Look For..", browse to <Creo 2.0 Mxxx Distributed Services Manager progdir> (by default C:\Program Files\PTC\Creo 2.0\Distributed Services Manager\) and click "Look For.." once again
点击【查找】在目标所在路径(默认X:\Program Files\PTC\Creo 2.0\Distributed Services Manager\)点击【查找】
Click "OK"
点击 完成
8. Close "PTC_Creo_Patcher_0.1_SSQ"
关闭 PTC_Creo_Patcher_0.1_SSQ
9. Enjoy
完了
Cracked by Team-SolidSQUAD
SolidSQUAD团队破解
发表于 2015-6-23 10:38 | 显示全部楼层
谢谢,搞定了,
发表于 2015-6-27 19:54 | 显示全部楼层
谢谢楼主,安装成功了,非常感谢。:
发表于 2015-6-29 10:34 | 显示全部楼层
谢谢楼主分享,顺利安装完成!
发表于 2015-7-1 21:10 | 显示全部楼层
我先学习一下  然后再安装
发表于 2015-7-3 08:29 | 显示全部楼层
ok  thanks
乞丐
发表于 2015-7-22 23:33 | 显示全部楼层
111
参与人数 1威望 -1 收起 理由
伪君子的掘墓人 -1 灌水发帖,数码违规,行为卑劣,岂能容你?
发表于 2015-8-1 22:23 | 显示全部楼层
楼主,下的文件包里怎么没有crack这个文件夹,少了好多东西!
GMT+8, 2025-4-20 07:33 , Processed in 0.139075 second(s), 27 queries .
