查看: 3629|回复: 3
[求助] 安装PROE_V4_M180_W64时遇到的问题
发表于 2012-2-20 18:03 | 显示全部楼层 |阅读模式
我在安装PROE_V4_M180_W64时,按照下边说明进行操作,遇到“汉字”标注的问题:
.boot up your pc with windows
.start pro/e setup
.open ptc_licfile.dat with your fav txt-editor
.replace every occurance of 00-00-00-00-00-00 with the one shown in the bottom left corner of the Pro/e setup
(its your mac-id, format: xx-xx-xx-xx-xx)
.install pro/e - pro/m - pro/ds, i dont care which one or in which order
.on license-config screen select "nodelocked license" and point to edited ptc_licfile.dat
.blalala install
next for pro/engineer:
(if u didnt install the complete package, u get "missing file" errors, accept or bleed)
.run ptc.pro engineer.wildfire.4.0-patch.exe, point to <installdir>\x86e_win64\obj folder
.edit <pro/e installdir>\bin\proev.bat(此文件找不到,下边的编辑就不能进行)
  change "%start_cmd% "%CGTECH_JRE%\bin\javaw" -Xms16m -Xmx64m -Xss4m -classpath "%CGTECH_CLASSES%;%CGTECH_CLASSES%\CGTech.jar" Vericut %argstr%" in
        "%start_cmd% "%CGTECH_JRE%\bin\javaw" -Xms16m -Xmx64m -Xss4m -classpath "%CGTECH_CLASSES%;%CGTECH_CLASSES%\CGTech.jar" Vericut %argstr% PTC_KEY=0"
(add PTC_KEY=0)
pro/mechanica:
.run ptc.pro mechanica.wildfire.4.0-patch.exe
.point to <pro/m installdir>\x86e_win64\bin
        <pro/m installdir>\x86e_win64\obj(此文件夹找不到!参考其他文件,应该不需要此项。是否这样?)
        <pro/m installdir>\x86e_win64\ptc
(in this order, after every "missing file" error)
pro/distributed services:
.run ptc.distributed.services.4.0-patch.exe and point to <pro/ds installdir>\x86e_win64\obj
1270
发表于 2012-2-20 21:47 | 显示全部楼层
第一个找不到正常,不用找,第二个找不到你要安装了 mechanic 才有,不用这个模块也可以不找
发表于 2012-5-27 21:24 | 显示全部楼层
路过看看
发表于 2012-8-19 00:05 | 显示全部楼层
大师有没有中文的啊!小弟这里招架不住啊!
GMT+8, 2024-9-30 02:16 , Processed in 0.131850 second(s), 22 queries .
