楼主: 沉默的猪
[原创] 在PROE 4.0 上挂EMX 5.0 教程
发表于 2008-9-20 18:27 | 显示全部楼层
下下来试试
发表于 2008-9-20 18:31 | 显示全部楼层
怎么打不开,,,,Winrar  提示   格式未知或文件被破坏   ??????
发表于 2008-9-25 22:27 | 显示全部楼层
64位EMX5.0 F000如何安装 QQ354514088
哪位大侠可指教我的64位EMX5.0  F000  怎么挂不上啊?
操作系统64位VISTA, 已安装64位proe 4.0  M040
EMX我下了很多版本,其它的都是32位的,可在32位系统上安装,可现在我用64位系统了,64位EMX5.0  F000  安装了,就不知道怎么设置。。。。crack 文件说明如下,请高手指教:
PTC Expert Moldbase eXtension(EMX) Release 5.0 F000
This version supports the following 9 kinds of languages:
English, French,German, Italian, Japanese,Korean,Spanish,Simplified Chinese and Traditional Chinese.
Installation:
As an extension pack of Pro/E, You should install Pro/ENGINEER WILFRE2.0 or WILDFIRE 3.0 before you install the EMX5.0  F000 extension pack of pro/E and ensure your pro/e license includes the #192 feature< Feature Expert_Moldbase(192)> of pro/e. Of course, prior to rlz lic gen of Pro/e for WILDFIRE2.0 and 3.0 by ZWT includes the feature.
Attention:
   The EMX 5.0 no longer supports lower version of pro/E, the Pro/ENGINEER 2001 and WILFIRE can't run it enven if you have the right lic!
OK, if the above reday, let's go now:
run setup, choose all installation options and the right language which you need and choose an installing location, e.g. c:\ptc\emx5.0 , then Press Next button till finish.
Copy the following file under the installed emx5.0.F000 directory, e.g.:
c:\ptc\emx5.0\text\config.pro
  and paste it into the following installed directory of pro/e:
  e.g. for wildfire 2.0, please paste it into here:
       \proeWildfire 2.0\text
e.g. for wildfire 3.0, please paste it into here:
       \proeWildfire 3.0\text
P.S. for EMX 5.0 F000 command icons:
If you wanna use and show the EMX R5.0 M350 command icons on the pro/e interface,
please copy the following file
  \emx5.0\text\config.win
to ANY ONE of the following directories:
A. Your HOME Directory ( Use DOS command:   SET HOME   to query your HOME directory)
B. The pro/e  "start in" directory (Check your Pro/e startup icon,right click,properties,start in)
C. Your current working directory which you start the pro/e
OK, now run pro/e wildfire2.0 or 3.0, you'll find the Expert Moldbase Extension can work now.
发表于 2008-10-13 15:16 | 显示全部楼层
我遇到的情况同5楼!望高手解决!
发表于 2008-10-15 12:27 | 显示全部楼层
dohai 该用户已被删除
发表于 2008-10-15 19:54 | 显示全部楼层
发表于 2008-10-20 11:18 | 显示全部楼层
补丁下不了啊 ,那位好心人再发一个啊
发表于 2008-10-23 20:53 | 显示全部楼层
回复 楼主 的帖子
这样的话装上了有什么用呀!不如不装呢!
发表于 2008-10-29 10:30 | 显示全部楼层
之前也有很多朋友介绍过了,再次感谢朋友分享经验!期待发表更多原创
补丁下不了啊 ,那位好心人再发一个啊
GMT+8, 2025-1-31 20:53 , Processed in 0.147426 second(s), 26 queries .
