查看: 5384|回复: 2
[求助] 求帮助proe5.0加工生成的nc代码很不一样
发表于 2011-11-14 23:56 | 显示全部楼层 |阅读模式
不知道为啥我生成的nc是这样的,是不是哪里出错了,怎么修改
$$*          Pro/CLfile  Version Wildfire 5.0 - M040
$$-> MFGNO / LIANXI1
PARTNO / LIANXI1
$$-> FEATNO / 24
MACHIN / UNCX01, 1
$$-> CUTCOM_GEOMETRY_TYPE / OUTPUT_ON_CENTER
UNITS / MM
LOADTL / 1
$$-> CUTTER / 16.000000
$$-> CSYS / 1.0000000000, 0.0000000000, 0.0000000000, 0.0000000000,  $
            0.0000000000, 1.0000000000, 0.0000000000, 0.0000000000,  $
            0.0000000000, 0.0000000000, 1.0000000000, 0.0000000000
SPINDL / RPM, 1200.000000,  CLW
RAPID
GOTO / 8.0000000000, 0.0000000000, 50.0000000000
RAPID
GOTO / 8.0000000000, 0.0000000000, 3.0000000000
FEDRAT / 3.000000,  MMPM
GOTO / 8.0000000000, 0.0000000000, -2.0000000000
GOTO / -108.0000000000, 0.0000000000, -2.0000000000
RAPID
GOTO / -108.0000000000, 100.0000000000, -2.0000000000
GOTO / 8.0000000000, 100.0000000000, -2.0000000000
RAPID
GOTO / 8.0000000000, 11.1111111111, -2.0000000000
GOTO / -108.0000000000, 11.1111111111, -2.0000000000
RAPID
GOTO / -108.0000000000, 88.8888888889, -2.0000000000
GOTO / 8.0000000000, 88.8888888889, -2.0000000000
RAPID
GOTO / 8.0000000000, 22.2222222222, -2.0000000000
GOTO / -108.0000000000, 22.2222222222, -2.0000000000
RAPID
GOTO / -108.0000000000, 77.7777777778, -2.0000000000
GOTO / 8.0000000000, 77.7777777778, -2.0000000000
发表于 2012-1-11 21:54 | 显示全部楼层
这是没有进行后处理的代码。
发表于 2012-11-8 16:53 | 显示全部楼层
你这不是nc代码,根据不同的系统选择不同的后置处理器。应用程序-nc后处理器
GMT+8, 2025-1-31 22:58 , Processed in 0.100096 second(s), 21 queries .
