查看: 3640|回复: 1
[求助] proe5.0安装keyshot接口后出现以下错误
发表于 2011-7-30 04:31 | 显示全部楼层 |阅读模式
proe5.0安装keyshot接口后出现以下错误  求解
    Installing KeyShot Pro/E Plugin Install Results
Moving the file
D:\KeyShot\proe\proe5.0\wf5\protk.dat
To
D:\PTC\proeWildfire 5.0\text\protk.dat
Failed.
The Protk.dat file is needed to allow Pro/E to locate the proper plug-ins
The installer may fail to copy protk.dat to the appropriate location due to one of the following reasons:
** The destination directory is write-protected.
** A copy of protk.dat already exists in the destination location.
** The installer was not able to find Pro/E information in the registry
To complete the installation, please move the file protk.dat
to location of the destination text directory. For example: C:\Program Files\proeWildfire 3.0\text
If the protk.dat file already exists, you need to merge the above mentioned protk.dat file with this file.
Merging can be accomplished by copying the contents of the protk.dat text to the top of the destination file.
109
绘图员
发表于 2011-7-30 08:20 | 显示全部楼层
这不是错误
关于接口的安装,请看下帖的3楼
http://www.proewildfire.cn/thread-72748-1-1.html
GMT+8, 2024-11-20 01:44 , Processed in 0.143914 second(s), 22 queries .
