查看: 2113|回复: 2
[求助] 请教一个有关工程配置的问题
发表于 2011-7-12 09:33 | 显示全部楼层 |阅读模式
这是我在论坛下载的一个工程配置文件的内容,请各位老师帮我看一下:
drawing_text_height 3.000000
text_thickness 0.000000
text_width_factor 0.800000
broken_view_offset 1.000000
create_area_unfold_segmented YES
def_view_text_height 3.000000
def_view_text_thickness 0.000000
default_view_label_placement BOTTOM_LEFT
detail_circle_line_style PHANTOMFONT
detail_circle_note_text DEFAULT
detail_view_boundary_type CIRCLE
detail_view_circle ON
detail_view_scale_factor 2.000000
half_view_line SOLID
model_display_for_new_views FOLLOW_ENVIRONMENT
projection_type first_angle
show_total_unfold_seam YES
tan_edge_display_for_new_views DEFAULT
view_note STD_JIS
view_scale_denominator 3
view_scale_format DECIMAL
crossec_arrow_length 5.000000
crossec_arrow_style TAIL_ONLINE
crossec_arrow_width 2.000000
crossec_text_place AFTER_HEAD
crossec_type OLD_STYLE
cutting_line STD_JIS_ALTERNATE
cutting_line_adapt YES
cutting_line_segment 3.000000
def_xhatch_break_around_text NO
def_xhatch_break_margin_size 0.150000
default_show_2d_section_xhatch ASSEMBLY_AND_PART
default_show_3d_section_xhatch YES
draw_cosms_in_area_xsec NO
remove_cosms_from_xsecs TOTAL
show_quilts_in_total_xsecs NO
datum_point_shape CROSS
datum_point_size 8.000000
hidden_tangent_edges DEFAULT
hlr_for_datum_curves YES
hlr_for_pipe_solid_cl NO
hlr_for_threads YES
location_radius DEFAULT(2.)
mesh_surface_lines ON
pipe_insulation_solid_xsec NO
ref_des_display NO
show_sym_of_suppressed_weld NO
thread_standard STD_ISO_IMP
weld_light_xsec NO
weld_solid_xsec NO
allow_3d_dimensions YES
angdim_text_orientation PARALLEL_ABOVE
associative_dimensioning YES
chamfer_45deg_leader_style STD_ISO
chamfer_45deg_dim_text JIS
clip_diam_dimensions YES
clip_dimensions YES
clip_dim_arrow_style DOUBLE_ARROW
default_dim_elbows YES
dim_fraction_format DEFAULT
dim_leader_length 5.000000
dim_text_gap 0.500000
dim_trail_zero_max_places same_as_dim
draft_scale 1.000000
draw_ang_units ANG_DEG
draw_ang_unit_trail_zeros YES
dual_digits_diff -1
dual_dimensioning NO
dual_dimension_brackets YES
dual_metric_dim_show_fractions NO
dual_secondary_units MM
iso_ordinate_delta YES
lead_trail_zeros STD_METRIC
lead_trail_zeros_scope DIMS
orddim_text_orientation PARALLEL
ord_dim_standard std_ansi
parallel_dim_placement ABOVE
radial_dimension_display STD_ASME
shrinkage_value_display PERCENT_SHRINK
use_major_units NO
witness_line_delta 2.500000
witness_line_offset 0.000000
default_font font
dim_dot_box_style DEFAULT
draw_arrow_length 3.000000
draw_arrow_style FILLED
draw_arrow_width 1.000000
draw_attach_sym_height DEFAULT
draw_attach_sym_width DEFAULT
draw_dot_diameter DEFAULT
leader_elbow_length 5.000000
leader_extension_font SOLIDFONT
set_datum_leader_length 7.500000
axis_interior_clipping YES
axis_line_offset 3.000000
circle_axis_offset 3.000000
radial_pattern_axis_circle YES
asme_dtm_on_dia_dim_gtol ON_GTOL
gtol_datum_placement_default ON_BOTTOM
gtol_datums STD_ANSI
gtol_dim_placement ON_BOTTOM
gtol_display_style STD
gtol_lead_trail_zeros SAME_AS_LEAD_TRAIL_ZEROS
new_iso_set_datums YES
set_datum_triangle_display FILLED
stacked_gtol_align YES
2d_region_columns_fit_text NO
all_holes_in_hole_table YES
dash_supp_dims_in_region YES
def_bom_balloons_attachment EDGE
def_bom_balloons_snap_lines NO
def_bom_balloons_stagger NO
def_bom_balloons_stagger_value 15.240000
def_bom_balloons_view_offset 20.320000
def_bom_balloons_edge_att_sym ARROWHEAD
def_bom_balloons_surf_att_sym INTEGRAL
min_dist_between_bom_balloons 20.320000
model_digits_in_region NO
reference_bom_balloon_text "DEFAULT"
show_cbl_term_in_region YES
show_dim_sign_in_tables YES
sort_method_in_region DELIMITED
zero_quantity_cell_format EMPTY
draw_layer_overrides_model NO
ignore_model_layer_status YES
model_grid_balloon_display YES
model_grid_balloon_size 4.000000
model_grid_neg_prefix -
model_grid_num_dig_display 0
model_grid_offset DEFAULT
model_grid_text_orientation HORIZONTAL
model_grid_text_position CENTERED
pipe_pt_line_style DEFAULT
pipe_pt_shape CROSS
pipe_pt_size DEFAULT
show_pipe_theor_cl_pts BEND_CL
blank_zero_tolerance NO
display_tol_by_1000 NO
symmetric_tol_display_standard STD_ISO
tol_display NO
tol_text_height_factor 0.750000
tol_text_width_factor 0.750000
decimal_marker COMMA_FOR_METRIC_DUAL
default_pipe_bend_note NO
drawing_units MM
harn_tang_line_display NO
line_style_standard STD_ANSI
max_balloon_radius 0.000000
min_balloon_radius 0.000000
node_radius DEFAULT
pos_loc_format %s%x%y, %r
sym_flip_rotated_text NO
weld_symbol_standard STD_ISO
yes_no_parameter_display TRUE_FALSE
model_display_for_new_views DEFAULT       (1)这个选项前面设了,为何这里又设置成不同的值?
drawing_text_height 3.000000                        (2)这个选项是否和前面的重复了?(在drawing前面原来还来一个奇怪的字符,我删了)
! These options control text not subject to other options
! These options control views and their annotations
! These options control cross sections and their arrows
! These options control solids shown in views
! These options control dimensions
! These options control text and line fonts
aux_font                       1 filled
aux_font                       2 chfntf
aux_font                       3 chfnth
aux_font                       4 chfntk            (3)这几个选项会导致出错,是否应作其它相关的设置?应如何设置?
! These options control leaders
! These options control axes
! These options control geometric tolerancing information
! These options control tables, repeat regions, and BOM balloons
! These options control layers
! These options control model grids
! These options control theoretical piping bend intersection
! These options control dimension tolerances
! Miscellaneous options
(4)在dtl文件(用记事本打开)中,设置选项是否有前后次序?
(5)重复设置的选项是如何起作用的?
下面是应用此dtl文件后的std.out文件的内容:
ERROR - F:\soft\CAD_CAM\proe\other\Appendix\CNS-China.dtl, linenum 156: Invalid value 'DEFAULT' for keyword 'MODEL_DISPLAY_FOR_NEW_VIEWS'.
ERROR - F:\soft\CAD_CAM\proe\other\Appendix\CNS-China.dtl, linenum 178:  Keyword 'AUX_FONT' is not valid.
ERROR - F:\soft\CAD_CAM\proe\other\Appendix\CNS-China.dtl, linenum 179:  Keyword 'AUX_FONT' is not valid.
ERROR - F:\soft\CAD_CAM\proe\other\Appendix\CNS-China.dtl, linenum 180:  Keyword 'AUX_FONT' is not valid.
ERROR - F:\soft\CAD_CAM\proe\other\Appendix\CNS-China.dtl, linenum 181:  Keyword 'AUX_FONT' is not valid.
附:我的ProE版本是4.0M140的。
1273
发表于 2011-7-12 21:53 | 显示全部楼层
把你说的那些都删除就行了,配置选项没有次序
 楼主| 发表于 2011-7-13 11:34 | 显示全部楼层
原帖由 野火 于 2011-7-12 21:53 发表
谢谢!部分解决了我的疑问。
GMT+8, 2025-2-3 23:56 , Processed in 0.141523 second(s), 21 queries .
