楼主: dwdqbt
[原创] PROE机构仿真分析基础知识
发表于 2011-12-5 13:28 | 显示全部楼层
感谢楼主。学习了。
发表于 2011-12-14 15:31 | 显示全部楼层
好东东
发表于 2011-12-19 11:59 | 显示全部楼层
谢谢斑竹哦
发表于 2011-12-19 13:31 | 显示全部楼层
回复 楼主 dwdqbt 的帖子
蛮好,辛苦了
发表于 2011-12-20 12:47 | 显示全部楼层
楼主辛苦
发表于 2011-12-23 21:36 | 显示全部楼层
bucuoo
发表于 2011-12-25 22:54 | 显示全部楼层
有文档就好了
发表于 2011-12-29 11:56 | 显示全部楼层
学习了
发表于 2011-12-29 17:11 | 显示全部楼层
cheap cocktail dress Spending Your Money On Weddin
depending on the size your wedding your budget for the wedding mementos can be quite important. this will be significant since you might be planning on permitting one favor for each guest or one for each couple. whichever you decide to do,wedding dresses 2012 how to choose the right weddi,cheap cocktail dress, if  you’re using a large number of guests it may greatly impact the amount you are able to afford to  invest on each favor. if you are only have a few guests you may be able to splurge on more costly favors. however,dresses for the beach, if you are having a many guests on the limited budget you  should look at searching for cheap wedding favor ideas.
candles are among the simplest ideas for affordable wedding mementos. you can find simple candles offered at very economical prices. just like endless candles,girls bridesmaid dresses, you are luckily if you got endless promo code.you may even  consider purchasing personalized ribbons to tie pretty bows around the candles. these ribbons usually can be ordered and may  incorporate your names and the wedding date. this may appear to be a pricey item but  if you purchase these ribbons on the reel instead of precut it can be very affordable. a  simple taper candle tied together with your personalized ribbon can be put at each place setting to create a really inexpensive wedding favor.
packets of flower or vegetable seed also make great  wedding favors which are extremely inexpensive. you can stack up a few various kinds of seeds and tie each with a ribbon to create an attractive presentation that won’t blow your  budget. a different way to give flower or vegetable seeds like a wedding favor is to place the  seeds in a small pot. the pot does not have to be large enough to grow the flower or vegetable it  is merely a symbolic gift therefore it can be rather small. the pot only must be large enough to  keep the packets of seeds. this will be significant because small pots can be bought rather inexpensively while larger pots  is going to be significantly more expensive.
candy is yet another cheap wedding favor idea. you get an a few different  methods to hand out candy being an inexpensive wedding favor. you can buy inexpensive endless candy with endless coupon code 2011.one way to do that would be to purchase  a pretty fabric and some ribbon,destin beach weddings ( florida beach weddings ),detachable wedding dresses,gucci evening dresses that main label of rolex wat, cut the pad into small squares,winter wedding dresses, put a few small bits of candy on each square and  pull the corners together and tie using the ribbon. this is not merely an extremely inexpensive wedding favor idea but  it’s also a quite simple idea which may be assembled in the last second. a  different way to use candy as a wedding favor would be to purchase small tins and fill them with the candy of your choice. you can buy the candy in large quantities to maintain the price down and separate the candy into small  portions for each guest. a final way to give candy as a wedding favor is to buy candy bars with personalized  wrappers. the wrappers may include your name and date for the wedding as well as an image of  the two of you. this can be very affordable especially if you are ordering in large  quantities and therefore are only using one design for that wrappers.
spending your money on wedding favors wisely is important
another great idea for any wedding favor also is very economical is pen with the names of the wedding couple along with the wedding date inscribed about the pen. it may often be purchased for hardly any and can be combined with  stationary along with a note encouraging your friends and relatives in which to stay touch. this is such a great idea for any wedding favor because it is something your gests can really use plus by including some  stationary along with a note encouraging the guest in which to stay touch you’re letting them know you truly value  their friendship. you might like to even consider including a self addressed stamped envelop with the favor so your guest  could be more likely to follow your suggestion and give back a minimum of a short note following  the wedding.
乞丐
发表于 2012-1-19 10:39 | 显示全部楼层
你真好
太好了,我也在学习呢
GMT+8, 2025-4-20 19:32 , Processed in 0.165049 second(s), 27 queries .
