查看: 3916|回复: 1
[求助] proe 3.0 M070 安装时遇到许可证的问题
发表于 2008-5-24 10:19 | 显示全部楼层 |阅读模式
我用的是Windows XP操作系统,三台电脑+一个路由器+一个ADSL Modem上网。现在在其中一台电脑上安装Pro/Engineer Wildfire 3.0 M070时出现问题。
完全遵照CD1中Magnitude的解密方式执行,安装server,在安装的最后出现PTC.Setup消息框,如下:
安装期间出现下列警告
条件。这些只是信息
警告:
启动许可证服务器
许可证管理已成功安装,
但不能启动。有关详细信息和错误消息
请参阅日志文件
"C:\Program Files \flexnet\licensing\ptclmgrd.log"。
按弹出消息框打开ptclmgrd.log, 出现以下内容。
8:47:36 (lmgrd) -----------------------------------------------
8:47:36 (lmgrd)   Please Note:
8:47:36 (lmgrd)
8:47:36 (lmgrd)   This log is intended for debug purposes only.
8:47:36 (lmgrd)   In order to capture accurate license
8:47:36 (lmgrd)   usage data into an organized repository,
8:47:36 (lmgrd)   please enable report logging. Use Macrovision's
8:47:36 (lmgrd)   software license administration  solution,
8:47:36 (lmgrd)   FLEXnet Manager, to  readily gain visibility
8:47:36 (lmgrd)   into license usage data and to create
8:47:36 (lmgrd)   insightful reports on critical information like
8:47:36 (lmgrd)   license availability and usage. FLEXnet Manager
8:47:36 (lmgrd)   can be fully automated to run these reports on
8:47:36 (lmgrd)   schedule and can be used to track license
8:47:36 (lmgrd)   servers and usage across a heterogeneous
8:47:36 (lmgrd)   network of servers including Windows NT, Linux
8:47:36 (lmgrd)   and UNIX. Contact Macrovision at
8:47:36 (lmgrd)   www.macrovision.com for more details on how to
8:47:36 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
8:47:36 (lmgrd)   for your enterprise.
8:47:36 (lmgrd)
8:47:36 (lmgrd)
8:47:36 (lmgrd)
8:47:36 (lmgrd) pid 1948
8:47:41 (lmgrd) "jing": Not a valid server hostname, exiting.
8:47:41 (lmgrd) Valid license server system hosts are: "jing.domain"
8:47:41 (lmgrd) Using license file "C:\Program Files\flexnet\licensing\license.dat"
重新启动计算机时,告知LMGRD遇到问题需要关闭。
请各位大侠,帮助解决这个问题。谢谢!
[ 本帖最后由 crazyclean 于 2008-5-24 18:42 编辑 ]
1272
发表于 2008-5-24 19:06 | 显示全部楼层
pro/e wildfire 3.0 M120 野火版安装步骤图解说明教程
http://www.proewildfire.cn/thread-1028-1-1.html
对照上面教程安装,不要安装 ptc license server
GMT+8, 2024-11-26 07:33 , Processed in 0.148868 second(s), 27 queries .
