楼主: peiseqiooo
[求助] proe颜色与外观文件加载问题
发表于 2014-12-6 10:04 | 显示全部楼层
发表于 2015-5-23 10:33 | 显示全部楼层
试试看!!
发表于 2021-3-10 14:42 | 显示全部楼层
谢谢!正好在学习配置这个系统颜色
发表于 2022-5-12 13:24 | 显示全部楼层
学习一下
发表于 2022-7-4 16:36 | 显示全部楼层
太好了,我也需要它呢,谢谢啊
发表于 2022-8-15 16:23 | 显示全部楼层
mapkey $F1 @MAPKEY_NAME新键文件;@MAPKEY_LABEL新键文件;~ Command `ProCmdModelNew`;
mapkey $F2 @MAPKEY_NAME打开文件;@MAPKEY_LABEL打开文件;~ Command `ProCmdModelOpen` ;\
mapkey(continued) ~ Trail `UI Desktop` `UI Desktop` `DLG_PREVIEW_POST` `file_open`;
mapkey $F3 @MAPKEY_NAME清除内存;@MAPKEY_LABEL清除内存;\
mapkey(continued) ~ Command `ProCmdModelEraseNotDisp` ;~ Activate `file_erase_nd` `ok_pb`;
mapkey $F4 @MAPKEY_NAME关闭窗口;@MAPKEY_LABEL关闭窗口;\
mapkey(continued) ~ Select `main_dlg_cur` `MenuBar1`1  `File`;\
mapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;\
mapkey(continued) ~ Activate `main_dlg_cur` `File.psh_close_win`;
mapkey $F5 @MAPKEY_NAME测量距离;@MAPKEY_LABEL测量距离;\
mapkey(continued) ~ Command `ProCmdNaMeasureDistance`;
mapkey $F6 @MAPKEY_NAME测量长度;@MAPKEY_LABEL测量长度;\
mapkey(continued) ~ Command `ProCmdNaMeasureLength` ;~ Trigger `na_length` `curve_rep_` `0`;\
mapkey(continued) ~ Trigger `na_length` `curve_rep_` ``;
mapkey $F7 @MAPKEY_NAME测量直径;@MAPKEY_LABEL测量直径;\
mapkey(continued) ~ Command `ProCmdNaMeasureDiameter` ;\
mapkey(continued) ~ Trigger `na_diameter` `surface_rep_` `0`;\
mapkey(continued) ~ Trigger `na_diameter` `surface_rep_` ``;
mapkey $F8 @MAPKEY_NAME3D;@MAPKEY_LABEL3D;~ Command `ProCmdViewOrient` ;\
mapkey(continued) ~ Activate `orient` `NmViewCheckBtn`1 ;\
mapkey(continued) ~ Input `orient` `namedviewPH.NameVw_IP` `3`;\
mapkey(continued) ~ Input `orient` `namedviewPH.NameVw_IP` `3D`;\
mapkey(continued) ~ Update `orient` `namedviewPH.NameVw_IP` `3D`;\
mapkey(continued) ~ Activate `orient` `namedviewPH.NameVw_PB_Save`;~ Activate `orient` `OkPB`;
mapkey $F12 @MAPKEY_NAMEA3打印;@MAPKEY_LABELA3打印;~ Command `ProCmdModelPrint` ;\
mapkey(continued) ~ Activate `print` `Configure`;\
mapkey(continued) ~ Select `print_config` `r_opt_ctrl`1  `Model_sheet`;\
mapkey(continued) ~ Open `print_config` `o_plot`;~ Close `print_config` `o_plot`;\
mapkey(continued) ~ Select `print_config` `o_plot`1  `Full Plot`;\
mapkey(continued) ~ Update `print_config` `i_scale` `0.`;\
mapkey(continued) ~ Update `print_config` `i_scale` `0.96`;~ Activate `print_config` `OK`;\
mapkey(continued) ~ Activate `print` `OK`;
mapkey 1 @MAPKEY_NAME实体着色;@MAPKEY_LABEL实体着色;\
mapkey(continued) ~ Command `ProCmdEnvMdlDisp`  `Shading`;
mapkey 2 @MAPKEY_NAME实体无隐藏线;@MAPKEY_LABEL实体无隐藏线;\
mapkey(continued) ~ Command `ProCmdEnvMdlDisp`  `No hidden`;
mapkey 3 @MAPKEY_NAME实体隐藏线;@MAPKEY_LABEL实体隐藏线;\
mapkey(continued) ~ Command `ProCmdEnvMdlDisp`  `Hidden line`;
mapkey 4 @MAPKEY_NAME实体线框;@MAPKEY_LABEL实体线框;\
mapkey(continued) ~ Command `ProCmdEnvMdlDisp`  `Wireframe`;
mapkey ex @MAPKEY_NAME拉伸;@MAPKEY_LABEL拉伸;~ Command `ProCmdFtExtrude` ;\
mapkey(continued) ~ Input `main_dlg_cur` `maindashInst0.def_depth1_ip` `1`;\
mapkey(continued) ~ Input `main_dlg_cur` `maindashInst0.def_depth1_ip` `10`;\
mapkey(continued) ~ Input `main_dlg_cur` `maindashInst0.def_depth1_ip` `100`;\
mapkey(continued) ~ Update `main_dlg_cur` `maindashInst0.def_depth1_ip` `100`;\
mapkey(continued) ~ FocusOut `main_dlg_cur` `maindashInst0.def_depth1_ip`;\
mapkey(continued) ~ Activate `main_dlg_cur` `chkbn.extrev_1_placement.0`1;
mapkey r @MAPKEY_NAME旋转;@MAPKEY_LABEL旋转;~ Command `ProCmdFtRevolve` ;\
mapkey(continued) ~ Activate `main_dlg_cur` `chkbn.revolve_1_placement.0`1;
mapkey mi @MAPKEY_NAME镜像;@MAPKEY_LABEL镜像;~ Command `ProCmdFtMirror` ;\
mapkey(continued) ~ Activate `main_dlg_cur` `chkbn.mirror_feat_refer.0`1 ;\
mapkey(continued) ~ Trigger `main_dlg_cur` `maindashInst0.MainDashList` `0`;\
mapkey(continued) ~ Trigger `main_dlg_cur` `maindashInst0.MainDashList` ``;
mapkey p @MAPKEY_NAME阵列;@MAPKEY_LABEL阵列;~ Command `ProCmdFtPattern` ;\
mapkey(continued) ~ Open `main_dlg_cur` `maindashInst0.ui_pat_type`;\
mapkey(continued) ~ Close `main_dlg_cur` `maindashInst0.ui_pat_type`;\
mapkey sc @MAPKEY_NAME草绘;@MAPKEY_LABEL草绘;~ Command `ProCmdDatumSketCurve`;
mapkey l @MAPKEY_NAME草绘直线;@MAPKEY_LABEL草绘直线;~ Command `ProCmdSketLine` 1;
mapkey i @MAPKEY_NAME草绘中心线;@MAPKEY_LABEL草绘中心线;\
mapkey(continued) ~ Activate `main_dlg_cur` `tbLines` `ProCmdSketCenterline.tbLine`;\
mapkey(continued) ~ Command `ProCmdSketCenterline` 1;
mapkey g @MAPKEY_NAME草绘使用边;@MAPKEY_LABEL草绘使用边;\
mapkey(continued) ~ Command `ProCmdSketProject` 1;
mapkey t @MAPKEY_NAME草绘删除段;@MAPKEY_LABEL草绘删除段;~ Command `ProCmdEditDelSeg` 1;
mapkey a @MAPKEY_NAME草绘圆弧;@MAPKEY_LABEL草绘圆弧;\
mapkey(continued) ~ Command `ProCmdSketCenterEnds` 1;
mapkey c @MAPKEY_NAME草绘圆;@MAPKEY_LABEL草绘圆;\
mapkey(continued) ~ Command `ProCmdSketCenterPoint` 1;
mapkey y @MAPKEY_NAME草绘圆角;@MAPKEY_LABEL草绘圆角;~ Command `ProCmdSketCircular` 1;
mapkey d @MAPKEY_NAME草绘标尺寸;@MAPKEY_LABEL草绘标尺寸;\
mapkey(continued) ~ Command `ProCmdSketDimension` 1;
mapkey sk @MAPKEY_NAME壳;@MAPKEY_LABEL壳;~ Command `ProCmdShell` ;\
mapkey(continued) ~ Input `main_dlg_cur` `maindashInst0.OverallThickness` `1`;\
mapkey(continued) ~ Input `main_dlg_cur` `maindashInst0.OverallThickness` `1.`;\
mapkey(continued) ~ Input `main_dlg_cur` `maindashInst0.OverallThickness` `1.5`;\
mapkey(continued) ~ Update `main_dlg_cur` `maindashInst0.OverallThickness` `1.5`;\
mapkey(continued) ~ FocusOut `main_dlg_cur` `maindashInst0.OverallThickness`;
mapkey hh @MAPKEY_NAME孔;@MAPKEY_LABEL孔;~ Command `ProCmdHole` ;\
mapkey(continued) ~ Input `main_dlg_cur` `maindashInst0.diameter_mip_OptionMenu` `4`;\
mapkey(continued) ~ Update `main_dlg_cur` `maindashInst0.diameter_mip_OptionMenu` `4`;\
mapkey(continued) ~ FocusOut `main_dlg_cur` `maindashInst0.diameter_mip_OptionMenu`;\
mapkey(continued) ~ Input `main_dlg_cur` `maindashInst0.ext_depth_to_value_mip_omnu` `1`;\
mapkey(continued) ~ Input `main_dlg_cur` `maindashInst0.ext_depth_to_value_mip_omnu` `10`;\
mapkey(continued) ~ Update `main_dlg_cur` `maindashInst0.ext_depth_to_value_mip_omnu` `10`;\
mapkey(continued) ~ Activate `main_dlg_cur` `maindashInst0.ext_depth_to_value_mip_omnu`;\
mapkey(continued) ~ FocusOut `main_dlg_cur` `maindashInst0.ext_depth_to_value_mip_omnu`;
mapkey ff @MAPKEY_NAME倒圆角;@MAPKEY_LABEL倒圆角;~ Command `ProCmdRound` ;\
mapkey(continued) ~ Input `main_dlg_cur` `maindashInst0.cir_rad_list` `5`;\
mapkey(continued) ~ Update `main_dlg_cur` `maindashInst0.cir_rad_list` `5`;\
mapkey(continued) ~ Activate `main_dlg_cur` `maindashInst0.cir_rad_list`;\
mapkey(continued) ~ Enter `main_dlg_cur` `dashInst0.gP`;~ Exit `main_dlg_cur` `dashInst0.gP`;\
mapkey(continued) ~ FocusOut `main_dlg_cur` `maindashInst0.cir_rad_list`;
mapkey mm @MAPKEY_NAME边倒角;@MAPKEY_LABEL边倒角;~ Command `ProCmdChamferEdge`;
mapkey sp @MAPKEY_NAME扫描伸出项;@MAPKEY_LABEL扫描伸出项;~ Command `ProCmdProtSwpSld`;
mapkey ss @MAPKEY_NAME扫面曲面;@MAPKEY_LABEL扫面曲面;~ Command `ProCmdSurfSweep`;
mapkey sa @MAPKEY_NAME扫面切口;@MAPKEY_LABEL扫面切口;~ Command `ProCmdCutSwpSld`;
mapkey bp @MAPKEY_NAME混合伸出项;@MAPKEY_LABEL混合伸出项;\
mapkey(continued) ~ Command `ProCmdProtBlendSld`;
mapkey bs @MAPKEY_NAME混合曲面;@MAPKEY_LABEL混合曲面;~ Command `ProCmdSurfBlend`;
mapkey ba @MAPKEY_NAME混合切口;@MAPKEY_LABEL混合切口;~ Command `ProCmdCutBlendSld`;
mapkey hp @MAPKEY_NAME螺旋扫面伸出项;@MAPKEY_LABEL螺旋扫面伸出项;\
mapkey(continued) ~ Command `ProCmdProtHelicSwpSld`;
mapkey hs @MAPKEY_NAME螺旋扫面曲面;@MAPKEY_LABEL螺旋扫面曲面;\
mapkey(continued) ~ Command `ProCmdSurfHelicSweep`;
mapkey ha @MAPKEY_NAME螺旋扫面切口;@MAPKEY_LABEL螺旋扫面切口;\
mapkey(continued) ~ Command `ProCmdCutHelicSwpSld`;
mapkey sb @MAPKEY_NAME扫面混合;@MAPKEY_LABEL扫面混合;~ Command `ProCmdFtSweptBlend` ;\
mapkey(continued) ~ Select `main_dlg_cur` `maindashInst0.solid_surf_radio`1  `Solid`;
mapkey bb @MAPKEY_NAME边界混合;@MAPKEY_LABEL边界混合;~ Command `ProCmdFtBndBlend` ;\
mapkey(continued) ~ Activate `main_dlg_cur` `chkbn.bbl_12curves.0`1 ;\
mapkey(continued) ~ Activate `main_dlg_cur` `chkbn.bbl_12curves.0`0;
mapkey vs @MAPKEY_NAME可变截面扫描;@MAPKEY_LABEL可变截面扫描;~ Command `ProCmdFtLoft` ;\
mapkey(continued) ~ Select `main_dlg_cur` `maindashInst0.SldSrf`1  `sld`;
mapkey za @MAPKEY_NAME造型;@MAPKEY_LABEL造型;~ Command `ProCmdFreestyle`;
piping_appearance_map_file E:\PTC\work\appearance.dmt
pro_spool_dir E:\PTC\work\spool
mapkey zp @MAPKEY_NAME钣金展平;@MAPKEY_LABEL钣金展平;~ Command `ProCmdSmtUnbend` ;\
mapkey(continued) #DONE;@PAUSE_FOR_SCREEN_PICK;#UNBEND ALL;#DONE;\
mapkey(continued) ~ Activate `Odui_Dlg_01` `okay`;
mapkey zh @MAPKEY_NAME钣金展回;@MAPKEY_LABEL钣金展回;~ Command `ProCmdSmtBendBack` ;\
mapkey(continued) @PAUSE_FOR_SCREEN_PICK;#BENDBACK ALL;#DONE;~ Activate `Odui_Dlg_01` `okay`;
GMT+8, 2025-2-5 16:37 , Processed in 0.160572 second(s), 26 queries .
