查看: 227932|回复: 325
[下载] Creo Elements/Pro 5.0 M070,...,M170,M180,M200,M220,M250,M260,M270,M280 补....
发表于 2010-12-19 21:54 | 显示全部楼层 |阅读模式
实际上和以前的 M010、M020、M030、M040【32位&64 位】 by ZWT 是一样的,以后的版本补丁应该也一样。
所以安装教程也和下面一样:
proe wildfire 5.0 M010 32 位野火版正式版安装步骤图解教程(含mechanic安装)【5.0 所有版本适用】
http://www.proewildfire.cn/thread-32988-1-1.html
以下是 32 位安装说明:
1) Start Creo Elements/Pro 5.0 setup
2) Open license.dat with any  txt-editor and replace every occurance of 00-00-00-00-00-00 with your computer real HOST_D (same one shown in the bottom left corner of the Pro/e setup). Save the license.dat
3) Install Creo Elements/Pro & Creo Elements/Pro Mechanic -ptc_distributed_services (optional). On license-config screen select "nodelocked license" and point to edited license.dat
Next  apply a patches (if u didn't install the complete package, you will get "File not found" errors, accept or bleed)
for Creo Elements/Pro:
Copy "proe_WF5_Win32_crk.exe" to folder <Creo Elements\Pro5.0 progdir>\i486_nt\obj and click "Next > OK > Next > OK > Next > OK > Next > OK > Finish > OK"
for Creo Elements/Pro Mechanic
Copy "proe_mech_WF5_Win32_#1_crk.exe" to folder <Creo Elements\Pro5.0 progdir>\mech\i486_nt\bin and click "Next > OK > Next > OK > Next > OK > Next > OK > Finish > OK"
Copy "proe_mech_WF5_Win32_#2_crk.exe" to folder <Creo Elements\Pro5.0 progdir>\mech\i486_nt\ptc and click "Start > OK"
for ptc distributed services
Copy "ptc_distributed_services_WF5_Win32_crk.exe" to folder <ptc_distributed_services WF5 Win32 progdir>\i486_nt\obj and click "Next > OK > Finish > OK"
以下是 64 位安装说明:
Copy "proe_WF5_Win64_crk.exe" to folder <Creo Elements\Pro5.0 progdir>\x86e_win64\obj and click "Next > OK > Next > OK > Next > OK > Next > OK > Finish > OK"
Copy "proe_mech_WF5_Win64_#1_crk.exe" to folder <Creo Elements\Pro5.0 progdir>\mech\x86e_win64\bin and click "Next > OK > Next > OK > Next > OK > Next > OK > Finish > OK"
Copy "proe_mech_WF5_Win64_#2_crk.exe" to folder <Creo Elements\Pro5.0 progdir>\mech\x86e_win64\ptc and click "Start > OK"
Copy "ptc_distributed_services_WF5_Win64_crk.exe" to folder <ptc_distributed_services WF5 Win64 progdir>\x86e_win64\obj and click "Next > OK > Finish > OK"
WF5_Win32_crk.rar
69.79 KB, 下载次数: 11930
WF5_Win64_crk.rar
69.79 KB, 下载次数: 17538
1275
 楼主| 发表于 2010-12-21 23:03 | 显示全部楼层
以下是 32 位安装说明 by 野火:
1) 运行 Creo Elements/Pro 5.0 安装程序 setup.exe;
2) 用记事本或写字板打开 WF5_Win32_crk 下 license.dat,用你自己的主机 id (运行setup.exe时左下角提示的主机ID)全部替换文件中的 00-00-00-00-00-00,保存文件;
3) 安装 Creo Elements/Pro & Creo Elements/Pro Mechanic,在指定许可证服务器时选择“锁定的许可证文件”并添加前面保存的 license.dat,继续完成安装。
安装完后不要运行 Creo 首先打补丁:
对 Creo Elements/Pro:
复制 "proe_WF5_Win32_crk.exe" 到 Creo Elements/Pro5.0/i486_nt/obj 下运行,然后点击 "Next > OK > Next > OK > Next > OK > Next > OK > Finish > OK";
对 Creo Elements/Pro Mechanic (这个组件是可选的,没安装的话可以跳过)
复制 "proe_mech_WF5_Win32_#1_crk.exe" 到 Creo Elements/Pro5.0/mech/i486_nt/bin 下运行,然后点击 "Next > OK > Next > OK > Next > OK > Next > OK > Finish > OK";
复制 "proe_mech_WF5_Win32_#2_crk.exe" 到 Creo Elements/Pro5.0/mech/i486_nt/ptc 下运行,然后点击 "Start > OK"。
以下是 64 位安装说明 by 野火:
2) 用记事本或写字板打开 WF5_Win64_crk 下 license.dat,用你自己的主机 id (运行setup.exe时左下角提示的主机ID)全部替换文件中的 00-00-00-00-00-00,保存文件;
复制 "proe_WF5_Win64_crk.exe" 到 Creo Elements/Pro5.0/x86e_win64/obj 下运行,然后点击 "Next > OK > Next > OK > Next > OK > Next > OK > Finish > OK";
复制 "proe_mech_WF5_Win64_#1_crk.exe" 到 Creo Elements/Pro5.0/mech/x86e_win64/bin 下运行,然后点击 "Next > OK > Next > OK > Next > OK > Next > OK > Finish > OK";
复制 "proe_mech_WF5_Win32_#2_crk.exe" 到 Creo Elements/Pro5.0/mech/x86e_win64/ptc 下运行,然后点击 "Start > OK"。
只要上面的步骤操作正确,你的 Creo 就可以正常使用了。
如果对上面的步骤有问题,可以参考下面 proe wildfire 5.0 野火版正式版安装步骤图解教程(含mechanic安装)【5.0 所有版本适用,也适用 Creo Elements/Pro 5.0】
回复 3 0
发表于 2010-12-21 23:08 | 显示全部楼层
32位我等已安装好。
发表于 2010-12-25 13:31 | 显示全部楼层
感谢无私分享,这里有您更精彩。。。
等待验证会员
发表于 2010-12-30 15:26 | 显示全部楼层
新版般的喔試試看
感謝分享
word21xx 该用户已被删除
发表于 2010-12-31 12:37 | 显示全部楼层
发表于 2010-12-31 21:12 | 显示全部楼层
谢谢,楼主是好人啊
发表于 2010-12-31 22:19 | 显示全部楼层
希望可以下载呀
发表于 2010-12-31 22:20 | 显示全部楼层
还是下载不了,奇怪了,难道真的要有钱钱才可以吗?
luwlhq 该用户已被删除
发表于 2011-1-2 02:43 | 显示全部楼层
GMT+8, 2025-4-16 06:16 , Processed in 0.153315 second(s), 31 queries .
