查看: 3158|回复: 2
[求助] proe许可证的更改
发表于 2010-10-30 12:53 | 显示全部楼层 |阅读模式
请教高手我的版本是proe3.0m230的 我的监听文件如下  不知道如何更改里面那些内容:
# replace <HOSTID> in every-feature with your actual ptc_hostid
# as shown in setup
INCREMENT PROE_DDiTy ptc_d 27.0 permanent uncounted \
        VENDOR_STRING="VSVER=2.0 LO=(0,3,6,7,9,10,14,16,17,19,21,22, \
        23,24,25,26,29,30,31,32,34,35,36,37,40,41,45,47,48,51,52,53, \
        54,55,56,57,59,60,61,62,63,65,66,67,69,71,72,73,74,77,91,92, \
        93,94,97,100,104,106,108,115,116,117,118,119,120,121,122,123, \
        125,126,127,128, 131,133,134,135, 137,139,140,141,148,155,156, \
        158,160,163,164,167,168,187,188,189,190, 191,192,193,194,208,209,210, \
        213,214,218,219,220,221,222,223,224,251,253)" SUPERSEDE \
        HOSTID=PTC_HOSTID=<HOSTID> vendor_info="VIVER=2.0 EXTERNAL_NAME=" ISSUER=ODT \
        ISSUED=2-apr-2006 NOTICE=PTC SN=07071982 SIGN="092F DBD8 F7BA \
        EC9D 51E5 453C 93A1 D63D 0BC7 3126 8493 2C23 32A9 A98F 8BC0 1BEB \
        0F0F 5C63 6933 5B61 613F 0CFB 235B 9C1B B39E 274F 2E5A 60E1 1FEF \
        DE6A" SIGN2="092F DBD8 F7BA EC9D 51E5 453C 93A1 D63D 0BC7 3126 \
        8493 2C23 32A9 A98F 8BC0 1BEB 0F0F 5C63 6933 5B61 613F 0CFB 235B \
        9C1B B39E 274F 2E5A 60E1 1FEF DE6A"
INCREMENT MECBASICUI_12345 ptc_d 27.0 permanent uncounted  \
        VENDOR_STRING="VSVER=2.0 LO=(19,157,211)" SUPERSEDE HOSTID=PTC_HOSTID=<HOSTID> \
INCREMENT MECBASICENG_12345 ptc_d 27.0 permanent uncounted  \
        VENDOR_STRING="VSVER=2.0 LO=(19,161,212)" SUPERSEDE HOSTID=PTC_HOSTID=<HOSTID> \
INCREMENT MECSTRUCUI_12345 ptc_d 27.0 permanent uncounted  \
        VENDOR_STRING="VSVER=2.0 LO=(19,81,157,159,161)" SUPERSEDE HOSTID=PTC_HOSTID=<HOSTID> \
INCREMENT MECSTRUCENG_12345 ptc_d 27.0 permanent uncounted  \
        VENDOR_STRING="VSVER=2.0 LO=(19,82,85,157,161)" SUPERSEDE HOSTID=PTC_HOSTID=<HOSTID> \
INCREMENT MECMOTUI_12345 ptc_d 27.0 permanent uncounted  \
        VENDOR_STRING="VSVER=2.0 LO=(19,86,89,159)" SUPERSEDE HOSTID=PTC_HOSTID=<HOSTID> \
INCREMENT MECMOTENG_12345 ptc_d 27.0 permanent uncounted  \
        VENDOR_STRING="VSVER=2.0 LO=(19,79,87,89)" SUPERSEDE HOSTID=PTC_HOSTID=<HOSTID> \
INCREMENT MECTHERMUI_12345 ptc_d 27.0 permanent uncounted  \
        VENDOR_STRING="VSVER=2.0 LO=(19,83,159)" SUPERSEDE HOSTID=PTC_HOSTID=<HOSTID> \
INCREMENT MECTHERMENG_12345 ptc_d 27.0 permanent uncounted  \
        VENDOR_STRING="VSVER=2.0 LO=(19,84)" SUPERSEDE HOSTID=PTC_HOSTID=<HOSTID> \
INCREMENT MECINTERFCE_12345 ptc_d 27.0 permanent uncounted  \
        VENDOR_STRING="VSVER=2.0 LO=(19,80)" SUPERSEDE HOSTID=PTC_HOSTID=<HOSTID> \
INCREMENT MECTIREMOD_12345 ptc_d 27.0 permanent uncounted  \
        VENDOR_STRING="VSVER=2.0 LO=(19,90)" SUPERSEDE HOSTID=PTC_HOSTID=<HOSTID> \
INCREMENT MECUG_12345 ptc_d 27.0 permanent uncounted  \
        VENDOR_STRING="VSVER=2.0 LO=(19)" SUPERSEDE HOSTID=PTC_HOSTID=<HOSTID> \
INCREMENT MECEQRUN_12345 ptc_d 27.0 permanent uncounted  \
INCREMENT 2DGS-OA_12345 ptc_d 27.0 permanent uncounted  \
        VENDOR_STRING="VSVER=2.0 LO=(19,169,170,171, \
        172,173,174,175,176,177,178,179,180,181,182,183,184,185,186)" \
        SUPERSEDE HOSTID=PTC_HOSTID=<HOSTID> vendor_info="VIVER=2.0 \
        EXTERNAL_NAME=" ISSUER=ODT ISSUED=2-apr-2006 NOTICE=PTC SN=07071982 \
        SIGN="092F DBD8 F7BA EC9D 51E5 453C 93A1 D63D 0BC7 3126 8493 2C23 \
        32A9 A98F 8BC0 1BEB 0F0F 5C63 6933 5B61 613F 0CFB 235B 9C1B B39E \
        274F 2E5A 60E1 1FEF DE6A" SIGN2="092F DBD8 F7BA EC9D 51E5 453C \
        93A1 D63D 0BC7 3126 8493 2C23 32A9 A98F 8BC0 1BEB 0F0F 5C63 6933 \
        5B61 613F 0CFB 235B 9C1B B39E 274F 2E5A 60E1 1FEF DE6A"
INCREMENT VERICUT_12345 ptc_d 27.0 permanent uncounted  \
        VENDOR_STRING="VSVER=2.0 LO=(19,139,140,141)" \
INCREMENT WEBPUBLISH_12345 ptc_d 27.0 permanent uncounted  \
        VENDOR_STRING="VSVER=2.0 LO=(19)" \
INCREMENT FLYTHRU_12345 ptc_d 27.0 permanent uncounted \
INCREMENT FLYPLUGIN_12345 ptc_d 27.0 permanent uncounted \
INCREMENT FLYVIEWER_12345 ptc_d 27.0 permanent uncounted \
        INCREMENT CONCEPT_12345 ptc_d 5.0 permanent uncounted  \
        VENDOR_STRING="VSVER=2.0 LO=(19,148)" SUPERSEDE HOSTID=PTC_HOSTID=<HOSTID> \
INCREMENT PROPACKENG_12345 ptc_d 27.0 permanent uncounted \
INCREMENT PROPACKUI_12345 ptc_d 27.0 permanent uncounted \
INCREMENT DS_MANAGER ptc_d 27.0 permanent uncounted  \
INCREMENT DS_MANAGER-REP ptc_d 27.0 permanent uncounted  \
INCREMENT DS_SERVICE ptc_d 27.0 permanent uncounted  \
INCREMENT PROETRAIN_12345 ptc_d 27.0 permanent uncounted  \
INCREMENT MOCKUPCONVERTER_12345 ptc_d 27.0 permanent uncounted \
         VENDOR_STRING="VSVER=2.0 \
        LO=(19,149,150,151,152,153,154)" SUPERSEDE HOSTID=PTC_HOSTID=<HOSTID> \
INCREMENT MOCKUP_12345 ptc_d 27.0 permanent uncounted  \
        VENDOR_STRING="VSVER=2.0 LO=(19,142,143,144,145,146,154)" \
        SUPERSEDE HOSTID=PTC_HOSTID=<HOSTID> vendor_info="VIVER=2.0 EXTERNAL_NAME=" ISSUER=ODT \
INCREMENT MODELVIEW_12345 ptc_d 27.0 permanent uncounted  \
INCREMENT PVIEW_12345 ptc_d 27.0 permanent uncounted  \
        VENDOR_STRING="VSVER=2.0 LO=(19,166,195,215)" SUPERSEDE HOSTID=PTC_HOSTID=<HOSTID> \
INCREMENT RSDESIGNER_12345 ptc_d 27.0 permanent uncounted  \
        VENDOR_STRING="VSVER=2.0 LO=(19,214)" SUPERSEDE HOSTID=PTC_HOSTID=<HOSTID> \
INCREMENT TMSINDA_12345 ptc_d 27.0 permanent uncounted  \
        VENDOR_STRING="VSVER=2.0 LO=(19,139,140,141)" SUPERSEDE HOSTID=PTC_HOSTID=<HOSTID> \
INCREMENT INTERCOMM ptc_d 27.0 permanent uncounted  \
        VENDOR_STRING="VSVER=2.0 LO=()" SUPERSEDE HOSTID=PTC_HOSTID=<HOSTID> \
INCREMENT EDACONDUIT ptc_d 27.0 permanent uncounted  \
INCREMENT EDACONNECTOR ptc_d 27.0 permanent uncounted  \
发表于 2010-10-30 13:22 | 显示全部楼层
      请仔细参阅学习下述专题帖(适合对应于Pro/E 3.0 M230):
     【Pro/Engineer Wildfire 3.0 M190 安装图文教程】,
      http://www.proewildfire.cn/thread-19508-1-1.html
发表于 2010-10-30 20:42 | 显示全部楼层
将  <HOSTID>  替换成你的网卡号保存就行了
GMT+8, 2024-11-18 14:01 , Processed in 0.136726 second(s), 21 queries .
